Unable to use Software Updates from Eclipse 3.2 [message #160167] |
Mon, 10 July 2006 14:35  |
Originally posted by: ajay610.gmail.com
I installed Eclipse 3.2 SDK (linux-gtk) with the following plugins:
GEF-runtime-3.2.zip
JEM-SDK-1.2.zip
emf-sdo-runtime-2.2.0.zip
wtp-sdk-R-1.5.0-200606281455.zip
de.loskutov.anyedit.AnyEditTools_1.4.2.jar
ehep-0.3.0.zip
shelled_1.0.2a.zip
The install of the above mentioned plugins was accomplised by unzipping
their contents in eclipse folder.
Eclipse seem to be working fine, but, when I try to install any plugin /
fetaure through the "Help -> Software Updates -> Find and Install", I get
the following errors:
The current configuration contains errors and this operation can have
unpredictable results.
WST Web Services Core (1.5.0.v200606071530--4hNDDhDhISDhXc) requires
feature "org.eclipse.xsd (2.2.0)", or equivalent.
WST XML Core (1.5.0.v200605151622--3YIAAYAYEPEOOF) requires feature
This happens with any feature that I try to install, here are steps for
svn plugin:
1. Help -> Software Updates -> Find and Install
2. Select "New Remote Site" -> URL=http://subclipse.tigris.org/update_1.2.x
3. Select Finish
4. Drill down the feature in the "Updates" dialog that shows up, select
the feature
5. Experience the error!
At this point "Next", "Finish" is greyed out, and the feature cannot be
installed.
log does not contain anything useful!
Is anyone else getting this error?
Does my set of plugins have something to do with it?
I remember there being a way to launch eclipse without any plugins, but I
can't seem to be able to find it!
Any help would be highly appreciated.
Ajay
Re: Unable to use Software Updates from Eclipse 3.2 [message #160209 is a reply to message #160167] |
Tue, 11 July 2006 01:57   |
You can get the XSD zip file from
http://www.eclipse.org/downloads/download.php?file=/tools/em f/downloads/drops/2.2.0/R200606271057/xsd-SDK-2.2.0.zip
and that might get you past the errors about the WST requiring XSD.
> GEF-runtime-3.2.zip
> JEM-SDK-1.2.zip
> ehep-0.3.0.zip
> shelled_1.0.2a.zip
> get the following errors:
> svn plugin:
> 3. Select Finish
> the feature
> installed.
> I can't seem to be able to find it!
> Thanks
> Ajay
FUDForum. Page generated in 0.33892 seconds
