Home » Archived » XML Schema Definition (XSD) » set annotation to schema object
set annotation to schema object [message #1235] Tue, 01 October 2002 03:51 Go to next message
Originally posted by: kwgkwg.netian.com
I just try to add annotaion to XSD file.
But I can't set annotation to XSDSchema object.
It doesn't exist API.
Is there another way to set annotation to XSDSchema object?
Re: set annotation to schema object [message #1260 is a reply to message #1235] Tue, 01 October 2002 08:45 Go to previous messageGo to next message
Since Documentation is not really part of the infoset model you have to do a
little more work to create documentation
XSDAnnotation annotation = XSDFactory .eINSTANCE.createXSDAnnotation();
xsdSchema.getContents().add(0,annotation);
//This is where the real work comes
Element documentation = annotation.createUserInformation(null);
annotation.getElement().appendChild(documentation);
documentation.appendChild(documentation.getOwnerDocument().c reateTextNode( "m
y documentation"));
Dave Spriet
WebSphere MQ Integration Tooling
"guest" <kwgkwg@netian.com> wrote in message
news:anbk5i$r3e$1@rogue.oti.com...
Re: set annotation to schema object [message #1323 is a reply to message #1235] Wed, 02 October 2002 06:11 Go to previous messageGo to next message
You can do xsdSchema.getContents().add(xsdAnnotation). Schemas can have
many annotations and they are interspersed with the other contents.
There is also a white diamond relation xsdSchema.getAnnotations(); these
are automatically populated from what's added to xsdSchema.getContents()
and is not modified directly by clients.
As Dave points out, the stuff under an annotation is just pure DOM and
you must manipulate it as such.
Re: set annotation to schema object [message #7210 is a reply to message #1323] Sun, 29 December 2002 10:33 Go to previous messageGo to next message
I'm trying to do a similar action, but a get instead of a set.
I parse in the schema, and do a getAnnotations() on the XSDSchema class- I
need to retrieve the xsd:documentation for the annotation. I have an
XSDAnnotation object in my hand and I call the getUserInformation()
method. I then have a list of dom Elements. My list actually contains one
element, and when I call getNodeValue() it returns null, even though there
is content in the xsd:docuementation in there. Do I need to call a flag to
the XSDResourcesSet to tell it to build a DOM object for me so that I can
access the information?
Re: set annotation to schema object [message #7298 is a reply to message #7210] Tue, 07 January 2003 09:32 Go to previous messageGo to next message
No, annotations and their contents should be included in the concrete model (only) by default; you don't need to turn this on.
Very odd. Are you sure you've never called anything like schema.setElement(null) or otherwise caused the concrete model to be
invalidated in your other code? I do have several tests that validate this basic functionality on a selection of schemas.
Try posting a more complete snippet of all your application code that loads and manipulates the schema up to this point if you
need further help.
- Shane
names [message #34551 is a reply to message #7210] Thu, 18 December 2003 10:39 Go to previous messageGo to next message
hyphens (that are acceptable to sqc) in element or type names do not
seem to be handled well by eclipse-emf-esd for editor generation.
norwood sisson
Re: names [message #34586 is a reply to message #34551] Thu, 18 December 2003 11:34 Go to previous messageGo to next message
--------------8B2BFB31116ABFEF02C9D81B
Content-Type: text/plain; charset=us-ascii
Norwood,
Thanks for pointing this out!! The feature names generated for the
DocumentRoot are not being properly validated as Java identifiers. I'm
changing this in XSDEcoreBuilder:
> etools-diff XSDEcoreBuilder.java
1477c1477
< xsdFeature.getName(),
> validName(xsdFeature.getName(), false),
We'll make another 2.0 drop available tomorrow (before I go on holidays
for four weeks).
> norwood sisson
Content-Type: text/html; charset=us-ascii
<!doctype html public "-//w3c//dtd html 4.0 transitional//en">
<html>
Norwood,
<p>Thanks for pointing this out!!&nbsp; The feature names generated for
the DocumentRoot are not being properly validated as Java identifiers.&nbsp;
I'm changing this in XSDEcoreBuilder:
<blockquote>> etools-diff XSDEcoreBuilder.java
<br>1477c1477
<br> &lt;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&a mp;nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;
<br>---
<br>> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;
validName(xsdFeature.getName(), false),</blockquote>
for four weeks).
<br>&nbsp;
<p>norwoods wrote:
<blockquote TYPE=CITE>hyphens (that are acceptable to sqc) in element or
type names do not
<br>seem to be handled well by eclipse-emf-esd for editor generation.
<p>norwood sisson</blockquote>
</html>
--------------8B2BFB31116ABFEF02C9D81B--
Re: set annotation to schema object [message #562712 is a reply to message #1235] Tue, 01 October 2002 08:45 Go to previous messageGo to next message
y documentation"));
Dave Spriet
Re: set annotation to schema object [message #562788 is a reply to message #1235] Wed, 02 October 2002 06:11 Go to previous messageGo to next message
Re: set annotation to schema object [message #564317 is a reply to message #1323] Sun, 29 December 2002 10:33 Go to previous messageGo to next message
Re: set annotation to schema object [message #564395 is a reply to message #7210] Tue, 07 January 2003 09:32 Go to previous messageGo to next message
need further help.
- Shane
names [message #581919 is a reply to message #7210] Thu, 18 December 2003 10:39 Go to previous messageGo to next message
norwood sisson
Re: names [message #581956 is a reply to message #34551] Thu, 18 December 2003 11:34 Go to previous messageGo to next message
Norwood,
1477c1477
for four weeks).
> norwood sisson
<html>
Norwood,
<br>1477c1477
<br>---
for four weeks).
<br>&nbsp;
type names do not
</html>
Re: In AGR While Creating Datapool, "Link to Datapool" is not visible [message #1788207] Wed, 30 May 2018 12:17 Go to previous message
Previous Topic:XSD assert
Next Topic:Creating new xml schema file example ?
Current Time: Sat Jul 26 08:25:41 EDT 2025
Powered by FUDForum. Page generated in 0.06760 seconds
