selectAddedObject() throws NullPointerException only on Linux [message #160102] |
Thu, 02 December 2004 09:32  |
Originally posted by: bandrews.nospam_bphnx.com
I think this is probably a bug, but I would like to confirm with the
experts here before logging. I have overridden CreationTool to provide
additional functionality to performCreation() method. My class looks
like this:
public class DECreationTool extends CreationTool
public DECreationTool()
super();
* @param aFactory
public DECreationTool(CreationFactory aFactory)
super(aFactory);
/* (non-Javadoc)
* @see org.eclipse.gef.tools.CreationTool#performCreation(int)
protected void performCreation(int button)
CreateCommand command = (CreateCommand)this.getCommand();
if(command.preExecute())
this.setCurrentCommand(command);
try
super.performCreation(button);
catch(NullPointerException $ne)
//TODO I only get this problem on Linux. It happens when
// selectAddedObject() is called.
All the preExecute() method does is gets some information from the user
via a dialog and returns true/false based on whether or not the
information was valid.
The problem is when selectAddedObject() method is called, the
EditPartViewer from getCurrentViewer() is null.
This only happens on Linux. It works fine on Windows. Is it obvious I am
doing something wrong here, or is it a bug in the framework?
many thanks,
Barry
Re: selectAddedObject() throws NullPointerException only on Linux [message #160180 is a reply to message #160127] |
Thu, 02 December 2004 14:35   |
Thanks Randy! Yes, the FocusLost happens when I pop up the Dialog. Makes
sense. I still need to call super because I do like the figure to get
selected after it is created so I just save the viewer before bringing
up the dialog then set it back afterwards. Works like a charm!
So in case anyone is interested, my performCreation() method looks like
this:
EditPartViewer viewer = getCurrentViewer();
setViewer(viewer);
Randy Hudson wrote:
> Sounds like the tool is getting a FocusLost event on Linux, and setting the
> current view to NULL. If you are going to override performCreation(), you
> probably shouldn't call super in this case.
> "Barry Andrews" <bandrews@nospam_bphnx.com> wrote in message
> news:con94b$bpn$1@www.eclipse.org...
>>Hello,
>>like this:
>> super();
>> * @param aFactory
>> super(aFactory);
>> /* (non-Javadoc)
>> try
>>many thanks,
>>Barry
Re: selectAddedObject() throws NullPointerException only on Linux [message #161457 is a reply to message #160210] |
Mon, 13 December 2004 12:39  |
Hi guys,
I have experienced the same problem, when I was running my plugin under
Linux.
Barry, I was thinking of exactly the same solution you have provided
(store and re-set current viewer.)
My code looked more or less like this:
protected void performCreation(int button) {
if (getCurrentCommand().canExecute()) {
InputDialog dlg = ...;
if (dlg.open() == Window.OK) {
CreateComponentCommand cmd = (CreateComponentCommand)
getCurrentCommand();
cmd.setComponentName(dlg.getValue());
So now I know how to fix it.
Milos
Randy Hudson wrote:
> Perhaps on windows, the Canvas gains focus again soon enough to restore the
> current viewer.
> news:conqt6$o0e$1@www.eclipse.org...
>>this:
FUDForum. Page generated in 1.23653 seconds
