Home » Language IDEs » Java Development Tools (JDT) » Remote Debugging j2eesdk1.3.1 with Eclipse
Remote Debugging j2eesdk1.3.1 with Eclipse [message #160090] Sat, 22 May 2004 20:58
Originally posted by: asleson.mn.rr.com
I installed the Java PetStore 1.3.2 application on my Windows XP
computer. The application runs using the J2EE SDK 1.3.1 (using J2SE
1.4.2_04) built-in app server. As a learning exercise I want to debug
through the PetStore appication using Eclipse. For starters I have
imported all of PetStore's source code into Eclipse.
My question: How can I start the J2EE app server in debug mode and
connect to it using Eclipse so I can debug through the application?
I've looked at the Debug Configuration window and under Connection
Properties, I'm guessing I need to supply a host (localhost, I'm
guessing) and a Port. What port do I use? I'm guessing that needs to
be specified when starting the J2EE app server. How do I start the J2EE
app server in debug mode and specify a port?
Thank you very much!!
Ryan
asleson@mn.rr.com
Previous Topic:Folder in classpath for java project
Next Topic:I could not debug JSP file on Eclipse 3.0M8.
Current Time: Sun Jun 08 14:02:31 EDT 2025
Powered by FUDForum. Page generated in 0.02609 seconds
