Home » Eclipse Projects » Subversive » Instalation problem "requires org.eclipse.team.svn"
Instalation problem "requires org.eclipse.team.svn" [message #15032] Tue, 25 March 2008 15:53 Go to next message
"Requested operation cannot be performed because it would invalidate the
current configuration. See details for more information.
JDT Ignore Extensions (Optional) (Incubation) (0.7.0.v20080311) requires
feature "org.eclipse.team.svn (0.7.0)", or compatible."
I'm used the Eclipse for J2E developers that I just downloaded. Tried
also the archieved version.
Any ideas?
thanks
Re: Instalation problem "requires org.eclipse.team.svn" [message #15042 is a reply to message #15032] Wed, 26 March 2008 04:50 Go to previous messageGo to next message
Originally posted by: alexander.gurov.polarion.org
The reason of the problem is unclean, could you please provide here
reference to download of Eclipse build which you use and to Subversive
update-site which you tried to install?
Also please try to install latest Subversive version using Help->Software
Updates->Find and Install...->Search for new features to install...
> Any ideas?
> thanks
Re: Instalation problem "requires org.eclipse.team.svn" [message #19805 is a reply to message #15042] Mon, 26 May 2008 03:11 Go to previous message
Originally posted by: tsewen.gmail.com
I am not sure if you still have this problem, but maybe someone else
would. Apparently Subversive has been moved into incubation on the
Eclipse site, so 0.7 is newer than 1.0.x and 1.1.x. The new update site is
http://download.eclipse.org/technology/subversive/0.7/update -site/
There you'll find version 0.7xxxx of org.eclipse.team.svn
Previous Topic:Update site problem
Next Topic:Subversive 0.7 will not install with 3.4RC2
Current Time: Fri Jul 18 03:30:16 EDT 2025
Powered by FUDForum. Page generated in 0.15160 seconds
