Home » Language IDEs » ServerTools (WTP) » How to change Context Root ?
How to change Context Root ? [message #159850] Thu, 09 February 2006 09:31 Go to next message
Originally posted by: yjpark.inops.co.kr
I want to work with WTP1.0, Tomcat 5.0 with context root /
but in wtp project wizard I can't change my project to root.
My project name is Test and I can access by http://localhost:8080/Test,
but can not access by http://localhost:8080,
I changed server.xml as follows
<Context docBase="Test" path="/" reloadable="true"
source="org.eclipse.jst.j2ee.server:Test"/>
but it didn't works and logs as follows
Installing web application at context path from URL
file:G:\eclipse\workspace\.metadata\.plugins\org.eclipse.wst .server.core\tmp0\webapps\ROOT
2006. 2. 9. &#50724;&#54980; 11:32:37
org.apache.catalina.core.StandardHostDeployer install
&#51221;&#48372;: Installing web application at context path /Test from
URL
file:G:\eclipse\workspace\.metadata\.plugins\org.eclipse.wst .server.core\tmp0\webapps\Test
Please help me
Re: How to change Context Root ? [message #160050 is a reply to message #159850] Thu, 09 February 2006 22:04 Go to previous messageGo to next message
i think the path statement needs to be "". but i experienced it is not
working anyway. see other postings concerning the "default server".
let me know if you figure it out.
thx
max
younJung Park wrote:
> Hi I want to work with WTP1.0, Tomcat 5.0 with context root /
> URL
> Please help me
> Thanks
Re: How to change Context Root ? [message #160351 is a reply to message #160050] Sat, 11 February 2006 09:17 Go to previous messageGo to next message
Perhaps you need to use the context ROOT (full uppercase) as that is the
name of the / application in Tomcat?
Frits
> thx
> max
>> from URL
>> Please help me
>> Thanks
Re: How to change Context Root ? [message #160407 is a reply to message #160351] Sun, 12 February 2006 19:48 Go to previous messageGo to next message
Have you tested that or just guessing?
Frits Jalvingh wrote:
> Frits
>> thx
>> max
>>> from URL
>>> Please help me
>>> Thanks
Re: How to change Context Root ? [message #160415 is a reply to message #159850] Sun, 12 February 2006 22:51 Go to previous messageGo to next message
> URL
> Please help me
> Thanks
Because of a bug in the Property editor (Project Properties->J2EE) where
you can't set an empty context root, you'll have to edit
..settings/.component and remove the value _completely_ for the
context-root property so that it looks like
<property name="context-root"/>
You can set the META-INF/context.xml's <Context> path attribute to "/", too.
This should help. Don't ever set your path to "ROOT".
Cary
Re: How to change Context Root ? [message #160457 is a reply to message #160415] Mon, 13 February 2006 01:24 Go to previous messageGo to next message
thx for this clear answer. it works!
cheers
max
>> from URL
>> Please help me
>> Thanks
> too.
> Cary
Re: How to change Context Root ? [message #160666 is a reply to message #160415] Mon, 13 February 2006 23:48 Go to previous messageGo to next message
After setting the path as described I know experince that the context is
actually loaded twice. one in the default directory and one in my
project directory. how can i stop this behaviour?
thx
max
>> from URL
>> Please help me
>> Thanks
> too.
> Cary
Re: How to change Context Root ? [message #160705 is a reply to message #160666] Tue, 14 February 2006 08:59 Go to previous messageGo to next message
It can't be avoided for now. See:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=125364
I'm still working on a patch. The main problem to be addressed in
finishing it, other than finding the time, it how to support the default
context.
Larry
> thx
> max
>>> from URL
>>> Please help me
>>> Thanks
>> where you can't set an empty context root, you'll have to edit
>> "/", too.
>> Cary
Re: How to change Context Root ? [message #160713 is a reply to message #160705] Tue, 14 February 2006 09:21 Go to previous messageGo to next message
Originally posted by: caclark.etechsolutions.net
Larry Isaacs said the following on 2/14/2006 7:59 AM:
> context.
> Cheers,
> Larry
>> is actually loaded twice. one in the default directory and one in my
>> thx
>> max
>>>> from URL
>>>> Please help me
>>>> Thanks
>>> "/", too.
>>> Cary
I sure thought I cured this by setting the autoDeploy="false" and
deployOnStartup="false" in the server.xml <Host> definition.
Re: How to change Context Root ? [message #160728 is a reply to message #160713] Tue, 14 February 2006 10:33 Go to previous messageGo to next message
>> default context.
>> Cheers,
>> Larry
>>> thx
>>> max
>>>>> from URL
>>>>> Please help me
>>>>> Thanks
>>>> "/", too.
>>>> Cary
True. I should have said without manually managing your configuration.
Larry
Re: How to change Context Root ? [message #161055 is a reply to message #160407] Fri, 17 February 2006 08:25 Go to previous message
I have not tested this under Eclipse but i have certainly used this
under Tomcat. You can even see it at work in a default Tomcat
installation: it has a default ROOT application installed in
[tomcat]/webapps/ROOT
Frits
>> the name of the / application in Tomcat?
>> Frits
>>> not working anyway. see other postings concerning the "default server".
>>> thx
>>> max
>>>> from URL
>>>> Please help me
>>>> Thanks
Previous Topic:tomcat runtime classpath
Next Topic:XML Validation question, possibly a bug
Current Time: Fri Jul 18 06:58:47 EDT 2025
Powered by FUDForum. Page generated in 0.06236 seconds
