Home » Language IDEs » ServerTools (WTP) » Webtools 1.0 running on Kanotix/Debian
Webtools 1.0 running on Kanotix/Debian [message #159821] Thu, 09 February 2006 08:11 Go to next message
Originally posted by: eclipse.burchard-net.de
I have Problems running Webtools under Kanotix.
the J2EE perspektiv doesn't work.
Many wizards break with errors...
I post the errorlog. Can somebody help me?
Regards Martin
> !SESSION 2006-02-09 10:25:40.02 ------------------------------------------------
> eclipse.buildId=M20050929-0840
> java.fullversion=GNU libgcj 4.0.3 20060121 (prerelease) (Debian 4.0.2-7j1)
> BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=de_DE
> Command-line arguments: -os linux -ws gtk -arch x86
> !ENTRY org.eclipse.osgi 2006-02-09 10:26:21.945
> !MESSAGE An error occurred while automatically activating bundle org.eclipse.jdt.core (86).
> !STACK 0
> org.osgi.framework.BundleException: Exception in org.eclipse.jdt.core.JavaCore.start() of bundle org.eclipse.jdt.core.
> at org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(org.osgi.framework.BundleActivator) (Unknown Source)
> at org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart() (Unknown Source)
> at org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(boolean) (Unknown Source)
> at org.eclipse.osgi.framework.internal.core.AbstractBundle.star t() (Unknown Source)
> at org.eclipse.core.runtime.adaptor.EclipseClassLoader.findLoca lClass(java.lang.String) (Unknown Source)
> at org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(java.lang.String) (Unknown Source)
> at org.eclipse.osgi.framework.internal.core.SingleSourcePackage .loadClass(java.lang.String) (Unknown Source)
> at org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(java.lang.String, boolean) (Unknown Source)
> at org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(java.lang.String) (Unknown Source)
> at org.eclipse.osgi.framework.adaptor.core.AbstractClassLoader. loadClass(java.lang.String, boolean) (Unknown Source)
> at java.lang.ClassLoader.loadClass(java.lang.String) (/usr/lib/libgcj.so.6.0.0)
> at java.lang.VMClassLoader.resolveClass(java.lang.Class) (/usr/lib/libgcj.so.6.0.0)
> at java.lang.Class.initializeClass() (/usr/lib/libgcj.so.6.0.0)
> at java.lang.reflect.Constructor.newInstance(java.lang.Object[] ) (/usr/lib/libgcj.so.6.0.0)
> at org.eclipse.core.internal.plugins.PluginDescriptor.internalD oPluginActivation() (Unknown Source)
> at org.eclipse.core.internal.plugins.PluginDescriptor.doPluginA ctivation() (Unknown Source)
> at org.eclipse.core.internal.plugins.PluginDescriptor.getPlugin () (Unknown Source)
> at org.eclipse.core.internal.compatibility.PluginActivator.star t(org.osgi.framework.BundleContext) (Unknown Source)
> at org.eclipse.osgi.framework.internal.core.BundleContextImpl$2 .run() (Unknown Source)
> at java.security.AccessController.doPrivileged(java.security.Pr ivilegedExceptionAction) (/usr/lib/libgcj.so.6.0.0)
> Caused by: java.lang.OutOfMemoryError
> <<No stacktrace available>>
> Root exception:
> !ENTRY org.eclipse.osgi 2006-02-09 10:26:22.87
> !MESSAGE An error occurred while automatically activating bundle org.eclipse.jdt.ui (180).
> !STACK 0
> org.osgi.framework.BundleException: Exception in org.eclipse.core.internal.compatibility.PluginActivator.star t() of bundle org.eclipse.jdt.ui.
> at org.eclipse.osgi.framework.internal.core.BundleLoader.loadCl ass(java.lang.String) (Unknown Source)
> at org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(java.lang.String, boolean) (Unknown Source)
> at org.eclipse.osgi.framework.internal.core.AbstractBundle.load Class(java.lang.String) (Unknown Source)
> at org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(org.osgi.framework.Bundle, java.lang.String, java.lang.Object, org.eclipse.core.internal.registry.ConfigurationElement, java.lang.String) (Unknown Source)
> at org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(java.lang.String, java.lang.String, java.lang.Object, org.eclipse.core.internal.registry.ConfigurationElement, java.lang.String) (Unknown Source)
> at org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(java.lang.String) (Unknown Source)
> at org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutableExtension(java.lang.String) (Unknown Source)
> at org.eclipse.ui.internal.registry.PerspectiveDescriptor.creat eFactory() (Unknown Source)
> at org.eclipse.ui.internal.Perspective.loadPredefinedPersp(org. eclipse.ui.internal.registry.PerspectiveDescriptor) (Unknown Source)
> at org.eclipse.ui.internal.Perspective.createPresentation(org.e clipse.ui.internal.registry.PerspectiveDescriptor) (Unknown Source)
> at org.eclipse.ui.internal.Perspective.Perspective(org.eclipse. ui.internal.registry.PerspectiveDescriptor, org.eclipse.ui.internal.WorkbenchPage) (Unknown Source)
> at org.eclipse.ui.internal.WorkbenchPage.createPerspective(org. eclipse.ui.internal.registry.PerspectiveDescriptor) (Unknown Source)
> at org.eclipse.ui.internal.WorkbenchPage.init(org.eclipse.ui.in ternal.WorkbenchWindow, java.lang.String, org.eclipse.core.runtime.IAdaptable) (Unknown Source)
> at org.eclipse.ui.internal.WorkbenchPage.WorkbenchPage(org.ecli pse.ui.internal.WorkbenchWindow, java.lang.String, org.eclipse.core.runtime.IAdaptable) (Unknown Source)
> at org.eclipse.ui.internal.WorkbenchWindow.busyOpenPage(java.la ng.String, org.eclipse.core.runtime.IAdaptable) (Unknown Source)
> Caused by: java.lang.NoClassDefFoundError: while resolving class: org.eclipse.jdt.internal.ui.JavaPlugin
> at java.lang.VMClassLoader.transformException(java.lang.Class, java.lang.Throwable) (/usr/lib/libgcj.so.6.0.0)
> Caused by: java.lang.ClassNotFoundException: org.eclipse.jdt.core.WorkingCopyOwner
> Root exception:
> !ENTRY org.eclipse.ui 4 4 2006-02-09 10:26:22.426
> !MESSAGE Could not create intro part.
> !ENTRY org.eclipse.ui 4 4 2006-02-09 10:26:22.427
> !STACK 1
> org.eclipse.ui.PartInitException: Abnormal Workbench Condition
> at org.eclipse.ui.internal.WorkbenchPage.showView(java.lang.Str ing, java.lang.String, int) (Unknown Source)
> at org.eclipse.ui.internal.WorkbenchPage.showView(java.lang.Str ing) (Unknown Source)
> at org.eclipse.ui.internal.WorkbenchIntroManager.createIntro(or g.eclipse.ui.IWorkbenchWindow) (Unknown Source)
> at org.eclipse.ui.internal.WorkbenchIntroManager.showIntro(org. eclipse.ui.IWorkbenchWindow, boolean) (Unknown Source)
> at org.eclipse.ui.application.WorkbenchWindowAdvisor.openIntro( ) (Unknown Source)
> at org.eclipse.ui.internal.ide.IDEWorkbenchWindowAdvisor.openIn tro() (Unknown Source)
> at org.eclipse.ui.internal.WorkbenchWindow.open() (Unknown Source)
> at org.eclipse.ui.internal.Workbench.busyOpenWorkbenchWindow(ja va.lang.String, org.eclipse.core.runtime.IAdaptable) (Unknown Source)
> at org.eclipse.ui.internal.Workbench.doOpenFirstTimeWindow() (Unknown Source)
> at org.eclipse.ui.internal.Workbench.access$10(org.eclipse.ui.i nternal.Workbench) (Unknown Source)
> at org.eclipse.ui.internal.Workbench$15.run() (Unknown Source)
> at org.eclipse.ui.internal.Workbench$16.run(org.eclipse.core.ru ntime.IProgressMonitor) (Unknown Source)
> at org.eclipse.jface.operation.ModalContext.runInCurrentThread( org.eclipse.jface.operation.IRunnableWithProgress, org.eclipse.core.runtime.IProgressMonitor) (Unknown Source)
> at org.eclipse.jface.operation.ModalContext.run(org.eclipse.jfa ce.operation.IRunnableWithProgress, boolean, org.eclipse.core.runtime.IProgressMonitor, org.eclipse.swt.widgets.Display) (Unknown Source)
> at org.eclipse.jface.dialogs.ProgressMonitorDialog.run(boolean, boolean, org.eclipse.jface.operation.IRunnableWithProgress) (Unknown Source)
> at org.eclipse.ui.internal.Workbench.runStartupWithProgress(int , java.lang.Runnable) (Unknown Source)
> at org.eclipse.ui.internal.Workbench.openFirstTimeWindow() (Unknown Source)
> at org.eclipse.ui.internal.WorkbenchConfigurer.openFirstTimeWin dow() (Unknown Source)
> at org.eclipse.ui.application.WorkbenchAdvisor.openWindows() (Unknown Source)
> at org.eclipse.ui.internal.Workbench.init(org.eclipse.swt.widge ts.Display) (Unknown Source)
> at org.eclipse.ui.internal.Workbench.runUI() (Unknown Source)
> !SUBENTRY 1 org.eclipse.ui 4 0 2006-02-09 10:26:22.494
> !MESSAGE Abnormal Workbench Condition
> !ENTRY org.eclipse.osgi 2006-02-09 10:26:37.411
> !MESSAGE An error occurred while automatically activating bundle org.eclipse.team.core (89).
> !STACK 0
> org.osgi.framework.BundleException: Exception in org.eclipse.team.internal.core.TeamPlugin.start() of bundle org.eclipse.team.core.
> at org.eclipse.core.internal.resources.Workspace.initializeTeam Hook() (Unknown Source)
> at org.eclipse.core.internal.resources.Workspace.getTeamHook() (Unknown Source)
> at org.eclipse.core.internal.resources.Rules.Rules(org.eclipse. core.internal.resources.Workspace) (Unknown Source)
> at org.eclipse.core.internal.resources.Workspace.getRuleFactory () (Unknown Source)
> at org.eclipse.core.internal.events.AutoBuildJob.doBuild(org.ec lipse.core.runtime.IProgressMonitor) (Unknown Source)
> at org.eclipse.core.internal.events.AutoBuildJob.run(org.eclips e.core.runtime.IProgressMonitor) (Unknown Source)
> at org.eclipse.core.internal.jobs.Worker.run() (Unknown Source)
> at .GC_start_routine (/usr/lib/libgcj.so.6.0.0)
> Caused by: java.lang.NoClassDefFoundError: while resolving class: org.eclipse.team.core.Team
> at org.eclipse.team.internal.core.TeamPlugin.start(org.osgi.fra mework.BundleContext) (Unknown Source)
> Caused by: java.lang.ClassNotFoundException: org.eclipse.team.internal.core.FileContentManager
> Root exception:
> !SESSION 2006-02-09 10:30:39.613 -----------------------------------------------
> !ENTRY org.eclipse.ui.workbench 4 2 2006-02-09 10:30:55.110
> !MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.ui.workbench".
> !STACK 0
> java.lang.reflect.InvocationTargetException
> at org.eclipse.ui.internal.Workbench.restoreState(org.eclipse.u i.IMemento) (Unknown Source)
> at org.eclipse.ui.internal.Workbench.access$12(org.eclipse.ui.i nternal.Workbench, org.eclipse.ui.IMemento) (Unknown Source)
> at org.eclipse.ui.internal.Workbench$17.run() (Unknown Source)
> at org.eclipse.core.internal.runtime.InternalPlatform.run(org.e clipse.core.runtime.ISafeRunnable) (Unknown Source)
> at org.eclipse.core.runtime.Platform.run(org.eclipse.core.runti me.ISafeRunnable) (Unknown Source)
> at org.eclipse.ui.internal.Workbench.restoreState() (Unknown Source)
> at org.eclipse.ui.internal.WorkbenchConfigurer.restoreState() (Unknown Source)
> at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(org. eclipse.swt.widgets.Display, org.eclipse.ui.application.WorkbenchAdvisor) (Unknown Source)
> at org.eclipse.ui.PlatformUI.createAndRunWorkbench(org.eclipse. swt.widgets.Display, org.eclipse.ui.application.WorkbenchAdvisor) (Unknown Source)
> at org.eclipse.ui.internal.ide.IDEApplication.run(java.lang.Obj ect) (Unknown Source)
> at org.eclipse.core.internal.runtime.PlatformActivator$1.run(ja va.lang.Object) (Unknown Source)
> at org.eclipse.core.runtime.adaptor.EclipseStarter.run(java.lan g.Object) (Unknown Source)
> at org.eclipse.core.runtime.adaptor.EclipseStarter.run(java.lan g.String[], java.lang.Runnable) (Unknown Source)
> at java.lang.reflect.Method.invoke(java.lang.Object, java.lang.Object[]) (/usr/lib/libgcj.so.6.0.0)
> at org.eclipse.core.launcher.Main.invokeFramework(java.lang.Str ing[], java.net.URL[]) (Unknown Source)
> at org.eclipse.core.launcher.Main.basicRun(java.lang.String[]) (Unknown Source)
> at org.eclipse.core.launcher.Main.run(java.lang.String[]) (Unknown Source)
> Caused by: java.lang.NullPointerException
> at org.eclipse.ui.internal.WorkbenchPage.restoreState(org.eclip se.ui.IMemento, org.eclipse.ui.IPerspectiveDescriptor) (Unknown Source)
> at org.eclipse.ui.internal.WorkbenchWindow.restoreState(org.ecl ipse.ui.IMemento, org.eclipse.ui.IPerspectiveDescriptor) (Unknown Source)
> at org.eclipse.ui.internal.Workbench.doRestoreState(org.eclipse .ui.IMemento, org.eclipse.core.runtime.MultiStatus) (Unknown Source)
> at org.eclipse.ui.internal.Workbench.access$14(org.eclipse.ui.i nternal.Workbench, org.eclipse.ui.IMemento, org.eclipse.core.runtime.MultiStatus) (Unknown Source)
> at org.eclipse.ui.internal.Workbench$19.run() (Unknown Source)
> Root exception:
> !ENTRY org.eclipse.osgi 2006-02-09 10:31:01.197
> !STACK 0
> Root exception:
> !ENTRY org.eclipse.osgi 2006-02-09 10:31:01.351
> !STACK 0
Re: Webtools 1.0 running on Kanotix/Debian [message #160270 is a reply to message #159821] Fri, 10 February 2006 15:35 Go to previous messageGo to next message
>> 4.0.2-7j1)
>> !STACK 0
>> at
....snip...
>> (Unknown Source)
>> at
>> (Unknown Source)
>> Root exception:
The first thing to try is running Eclipse by itself using a JRE
other than gcj. Until the base Eclipse SDK can itself be started
correctly, there's little chance of WTP functioning correctly. If
your Eclipse SDK download came from Eclipse.org, you should be able
to use the -vm switch to point it at a different Java runtime.
- Nitin
Re: Webtools 1.0 running on Kanotix/Debian [message #160383 is a reply to message #160270] Sun, 12 February 2006 10:58 Go to previous messageGo to next message
Nitin Dahyabhai wrote:
> The first thing to try is running Eclipse by itself using a JRE other
> than gcj. Until the base Eclipse SDK can itself be started correctly,
> there's little chance of WTP functioning correctly. If your Eclipse SDK
> download came from Eclipse.org, you should be able to use the -vm switch
I changed the JRE...
*** Date: Sun Feb 12 16:52:57 CET 2006
*** Platform Details:
*** System properties:
eclipse.application=org.eclipse.ui.ide.workbench
eclipse.commands=-os
linux
-ws
gtk
-arch
x86
-launcher
/home/mburchard/eclipse-webtools/eclipse
-name
Eclipse
-showsplash
600
-exitdata
5a8017
-vm
/usr/lib/j2re1.5-sun/bin/java
eclipse.product=org.eclipse.sdk.ide
eclipse.startTime=1139759527116
eclipse.vm=/usr/lib/j2re1.5-sun/bin/java
eclipse.vmargs=-Xms40m
-Xmx256m
-jar
/home/mburchard/eclipse-webtools/startup.jar
eof=eof
But in the Error log...
!ENTRY org.eclipse.update.configurator 2006-02-10 12:45:19.786
!MESSAGE Unable to find feature.xml in directory:
/usr/share/eclipse/features/org.eclipse.gef_2.1.2
!SESSION 2006-02-10 13:06:18.660
Framework arguments: -Xmx256
Command-line arguments: -os linux -ws gtk -arch x86 -Xmx256
!ENTRY org.eclipse.osgi 2006-02-10 13:06:32.59
!STACK 0
(/usr/lib/gcj-4.0/org.eclipse.osgi_3.1.2.jar.so)
I dont't know, why the hack it is using GNU libgjc anymore...
Ideas?
Regards Martin
Re: Webtools 1.0 running on Kanotix/Debian [message #160391 is a reply to message #160383] Sun, 12 February 2006 11:05 Go to previous message
Ignore the posting before... :)
I deleted .eclipse within my homedir.
I started with a new workspace and everything is fine now :)
Thank you...
Previous Topic:Newbie Axis + Webtools installation question
Next Topic:Adding Web library projects for tomcat
Current Time: Mon Jul 07 12:47:25 EDT 2025
Powered by FUDForum. Page generated in 1.04502 seconds
