Home » Newcomers » Newcomers » Eclipse 3.2 with Visual Editor
Eclipse 3.2 with Visual Editor [message #159819] Fri, 07 July 2006 03:37 Go to next message
Originally posted by: i.are.explosion.gmail.com
I'm having a little trouble here, i'm learning java in school and would
like to use the visual editor. so far, i've downloaded all the files for
use with 3.2 and have extracted them, but i hit a bump at the command line
"-clean" command. i started the program with start-> run ->
c:\eclipse\eclipse.exe -clean but i still can't seem to access visual
editor, any help or walkthrough would be really appreciated.
Re: Eclipse 3.2 with Visual Editor [message #159870 is a reply to message #159819] Fri, 07 July 2006 09:48 Go to previous messageGo to next message
> would like to use the visual editor. so far, i've downloaded all the
> files for use with 3.2
What did you download? The Eclipse SDK does not contain a visual editor.
Dani
> and have extracted them, but i hit a bump at the command line "-clean"
Re: Eclipse 3.2 with Visual Editor [message #159888 is a reply to message #159819] Fri, 07 July 2006 11:49 Go to previous message
Originally posted by: jefmyers.us.ibm.com
Jesse,
The preferred method for installing the VE is to use the Update Manager.
The Callisto website has a flash demo of how to install the VE:
http://www.eclipse.org/callisto/java.php
If you're installing manually, you're sure you've downloaded and
installed the required versions of GEF and EMF?
Hope this helps,
- Jeff
Previous Topic:SecondaryId set to null on multiple view.
Next Topic:I'm getting a crash on Solaris (Sparc)
Current Time: Thu Jul 17 21:38:08 EDT 2025
Powered by FUDForum. Page generated in 0.11082 seconds
