Re: Folder in classpath for java project [message #160082 is a reply to message #160051] |
Sat, 22 May 2004 18:48  |
I think that a bug related to this problem has been posted.
don't know if there's a better solution for this. At least i don't know
it. If you ever find another way, please send me an email telling me how.
> Hello Marcos,
> I understand - it isn't possible add folder without workspace , but why ?
> Thanks
> Marcos Lopez wrote:
> > You can create a folder in your project linked to the folder you want to
> > add to the classpath. Then, instead of adding the original folder, add the
> > linked one.
> >> I play with classpath yet - Classpath engine in eclipse try find class in
> >> workspace when path is folder - don't try /home/snpe/classes then
> >> WORKSPACE_HOME/home/snpe/classes (probably need project home too)
> >> It is a problem with test environment - test start in empty workspace and
> >> I have export to jar libraries all dependencies plugins for test project
> >> Is there solution ?
> >> regards
> >> Haris Peco
FUDForum. Page generated in 0.04064 seconds
