Home » Eclipse Projects » GEF » Status Line
Status Line [message #14963] Tue, 23 July 2002 04:35 Go to next message
Originally posted by: g.wagenknecht.intershop.de
Randy,
is it planned to add a status line to the "GraphicalEditor" that can be
easily accessed via #getStatusLineManager()? If not, which way do you
suggest to add a status line to a GraphicalEditor?
Cu, Gunnar
Re: Status Line [message #14971 is a reply to message #14963] Tue, 23 July 2002 08:49 Go to previous messageGo to next message
Originally posted by: none.ibm.com
That's a great idea. In what situations would you like to access the status
line?
The most obvious to me would be from a Tool. Perhaps displaying coordinates
and other data.
"Gunnar Wagenknecht" <g.wagenknecht@intershop.de> wrote in message
news:ahj2bl$fo3$1@rogue.oti.com...
> Randy,
> Cu, Gunnar
Re: Status Line [message #14988 is a reply to message #14971] Tue, 23 July 2002 10:43 Go to previous messageGo to next message
Hi!
"Randy Hudson" <none@ibm.com> schrieb im Newsbeitrag
news:ahjlle$s4s$1@rogue.oti.com...
status
> line?
coordinates
> and other data.
There are many cases. The most important for me are:
- display error or other messages (like information about the current
selection)
- display "read only" or "writeable" file information like the JaveEditor
does
- display a progress monitor
Cu, Gunnar
Re: Status Line [message #15110 is a reply to message #14988] Tue, 23 July 2002 11:56 Go to previous message
You can access the IStatusLineManager by subclassing ActionBarContributor (which
you may already do to add actions to the toolbar) and overriding
contributeToStatusLine(IStatusLineManager). I've never done anything with the
status line, so I'm not sure how it works. Hope this helps.
Eric
news:ahjns4$ttg$1@rogue.oti.com...
> Hi!
> status
> > line?
> coordinates
> > and other data.
> selection)
> does
> Cu, Gunnar
Previous Topic:DialogBox on object creation
Next Topic:[WIKI] standalone version of logic editor available
Current Time: Fri Jul 18 10:25:51 EDT 2025
Powered by FUDForum. Page generated in 0.24272 seconds
