eclipse 3.0 M8 refresh problem [message #159436] |
Wed, 19 May 2004 07:22  |
Originally posted by: mar1u50.yahoo.ca
I'm using eclipse to develop a web application. Appears the F5 int he
tree is not working after upgrading to M8.
I also tried to rightmouse and the to choose refresh. In this case
eclipse display a refresh dialog and appears to do something but the
result is still bad.
If I do a CVS-Synchronize with repository, some modified files are
refusing to be displayed as modified.
Also some of the changed jsps are not reflected as modified.
To summary, refresh is not always working. Please note that other 3
developers has the same problem since M8 was released. The eclipse log
does not contain anything usefull.
Any ideea ?
Best Regards
Marius
Re: eclipse 3.0 M8 refresh problem [message #159746 is a reply to message #159500] |
Fri, 21 May 2004 03:13  |
Darin Swanson wrote:
> F5 for refresh was pretty much broken in M8 from what I remember.
> Try a later integration build (the one from this week) or wait and use M9
> which is due out at the end of the week(
I tried a later intergration build but tomcat plugin is not working
anymore :(
> HTH
> Darins
> "Kevin Barnes" <krbarnes@ca-dot-ibm.com> wrote in message
> news:c8ftv4$ovo$1@eclipse.org...
> > Marius OANCEA wrote:
> > > Hello,
> > > Any ideea ?
> > > Best Regards
> > > Marius
> > F5 is used for refresh and for the Debug Command "Step Into". If you
> > have any debug sessions running, F5 will not refresh. Actually for a
> > time F5 would always call Step Into instead of refresh, but this has
> > been fixed (don't remember if it was fixed pre or post M8 though).
FUDForum. Page generated in 0.05979 seconds
