Home » Archived » BIRT » execute report via engine api ,but I get a java.lang.NoSuchMethodError,why? :(
execute report via engine api ,but I get a java.lang.NoSuchMethodError,why? :( [message #159369] Tue, 09 May 2006 04:33 Go to next message
Originally posted by: qq_qiutao.yahoo.com.cn
I executed a report via birt engine api and I get a strange
execption(java.lang.NoSuchMethodError).but the same report can
be executed in the Web View Example of birt-runtime-2_0_1 in
tomcat 5.0.28.
please help me! thanks
the error information:
org.eclipse.birt.report.engine.api.EngineException: Error happened while
running the report at
org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.run (RunAndRenderTask.java:200)
at test.birt.BirtTest.process(BirtTest.java:152)
at test.birt.BirtTest.main(BirtTest.java:264)
Caused by: java.lang.NoSuchMethodError:
org.mozilla.javascript.Parser.<init> (Lorg/mozilla/javascript/CompilerEnvirons;Lorg/mozilla/javas cript/ErrorReporter;)V
org.eclipse.birt.data.engine.impl.ExpressionCompiler.parse(E xpressionCompiler.java:123)
org.eclipse.birt.data.engine.impl.ExpressionCompiler.compile (ExpressionCompiler.java:90)
org.eclipse.birt.data.engine.impl.PreparedQuery.prepareExpre ssion(PreparedQuery.java:320)
org.eclipse.birt.data.engine.impl.PreparedQuery.prepareExpre ssions(PreparedQuery.java:300)
org.eclipse.birt.data.engine.impl.PreparedQuery.prepareGroup (PreparedQuery.java:268)
org.eclipse.birt.data.engine.impl.PreparedQuery.prepare(Prep aredQuery.java:184)
org.eclipse.birt.data.engine.impl.PreparedQuery.<init>(PreparedQuery.java:87)
org.eclipse.birt.data.engine.impl.PreparedDataSourceQuery.<init >(PreparedDataSourceQuery.java:97)
org.eclipse.birt.data.engine.impl.PreparedExtendedDSQuery.<init >(PreparedExtendedDSQuery.java:65)
org.eclipse.birt.data.engine.impl.PreparedDataSourceQuery.ne wInstance(PreparedDataSourceQuery.java:74)
org.eclipse.birt.data.engine.impl.DataEngineImpl.prepare(Dat aEngineImpl.java:409)
org.eclipse.birt.report.engine.data.dte.DteDataEngine.prepar e(DteDataEngine.java:171)
org.eclipse.birt.report.engine.executor.ReportExecutor.execu te(ReportExecutor.java:107)
org.eclipse.birt.report.engine.executor.ReportExecutor.execu te(ReportExecutor.java:89)
org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.run (RunAndRenderTask.java:175)
... 2 more
my code:
public void process(Map paramsMap, String rptName) throws EngineException {
assert paramsMap != null && rptName != null;
IReportRunnable design = openReportDesign(BASE_PATH
+ rptName);
System.out.println(design.getReportName());
IRunAndRenderTask task = engine.createRunAndRenderTask(design);
HTMLRenderContext renderContext = new HTMLRenderContext();
//renderContext.setImageDirectory("image");
HashMap contextMap = new HashMap();
contextMap.put(EngineConstants.APPCONTEXT_HTML_RENDER_CONTEX T,
renderContext);
task.setAppContext(contextMap);
HTMLRenderOption options = new HTMLRenderOption();
options.setOutputFileName("d:/temp.html");
//options.setOutputFormat(RenderOptionBase.OUTPUT_FORMAT_HTM L);
System.out.println(RenderOptionBase.OUTPUT_FORMAT_HTML);
task.setRenderOption(options);
task.setParameterValues(parseParameter(paramsMap, rptName,
Locale.CHINESE,design));
try {
task.run();
} catch (BirtException eBirt) {
eBirt.printStackTrace();
} finally {
task.close();
Re: execute report via engine api ,but I get a java.lang.NoSuchMethodError,why? :( [message #159417 is a reply to message #159369] Tue, 09 May 2006 05:28 Go to previous messageGo to next message
Do you have all the jars in the Report Engine directory in your classpath?
Specifically js.jar?
Jason
"Michael" <qq_qiutao@yahoo.com.cn> wrote in message
news:f05a988f9a7e13243913c5d6b7d4395b$1@www.eclipse.org...
> be executed in the Web View Example of birt-runtime-2_0_1 in tomcat
> 5.0.28.
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 2 more
> my code:
> + rptName);
> renderContext);
> try {
> task.run();
> } finally {
> task.close();
Re: execute report via engine api ,but I get a java.lang.NoSuchMethodError,why? :( [message #159614 is a reply to message #159417] Tue, 09 May 2006 09:21 Go to previous messageGo to next message
Originally posted by: qq.qiutao.gmail.com
yes,I do have the js.jar in my classpath.
I change the report to the test.rptdesign of the Web Viewer Example,then my
program is in work.
why? :(
"Jason Weathersby" <jweathersby@actuate.com> wrote in message
news:e3pnb4$651$1@utils.eclipse.org...
> Jason
>> 5.0.28.
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> ... 2 more
>> my code:
>> + rptName);
>> renderContext);
>> try {
>> task.run();
>> } finally {
>> task.close();
Re: execute report via engine api ,but I get a java.lang.NoSuchMethodError,why? :( [message #159690 is a reply to message #159614] Tue, 09 May 2006 16:44 Go to previous messageGo to next message
Can you post your report?
Jason
"Michael" <qq.qiutao@gmail.com> wrote in message
news:e3q51h$qiv$1@utils.eclipse.org...
> my program is in work.
> why? :(
>> classpath?
>> Jason
>>> 5.0.28.
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> ... 2 more
>>> my code:
>>> EngineException {
>>> + rptName);
>>> renderContext);
>>> try {
>>> task.run();
>>> } finally {
>>> task.close();
Re: execute report via engine api ,but I get a java.lang.NoSuchMethodError,why? :( [message #159762 is a reply to message #159690] Wed, 10 May 2006 10:33 Go to previous message
Jason
thank you very much . today ,I created a new project and moved the java file
into this new project,then it did work. so I think the reason caused the
problem
is my older project environment(somthing is wrong about classpath,but I
can't find the error).
news:e3quuk$6jp$1@utils.eclipse.org...
> Jason
>> why? :(
>>> classpath?
>>> Jason
>>>> 5.0.28.
>>>> while running the report at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> ... 2 more
>>>> my code:
>>>> EngineException {
>>>> + rptName);
>>>> renderContext);
>>>> try {
>>>> task.run();
>>>> } finally {
>>>> task.close();
Previous Topic:How to change the 'extensionID' of a datasource at runtime ?
Next Topic:Timeout or what?
Current Time: Fri Jul 25 10:22:43 EDT 2025
Powered by FUDForum. Page generated in 0.07169 seconds
