Can not make a new class. [message #159364] |
Tue, 29 November 2005 17:36 |
Originally posted by: lwatcdr.ATgmail.com
When I try to make a new class I get this error in the Error log.
Also when I am typing the new class name Eclipse hangs after each letter of
the name. Any suggestions?
java.lang.reflect.InvocationTargetException
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:327)
at org.eclipse.jface.wizard.WizardDialog.run(WizardDialog.java: 830)
org.eclipse.cdt.internal.ui.wizards.NewElementWizard.perform Finish(NewElementWizard.java:106)
org.eclipse.cdt.internal.ui.wizards.NewClassCreationWizard.p erformFinish(NewClassCreationWizard.java:66)
org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDi alog.java:676)
org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDi alog.java:349)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.jav a:556)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:90)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1021)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:2867)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2572)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:809 )
at org.eclipse.jface.window.Window.open(Window.java:787)
org.eclipse.ui.internal.actions.NewWizardShortcutAction.run( NewWizardShortcutAction.java:110)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:996 )
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:538)
at org.eclipse.jface.action.ActionContributionItem.access$
(ActionContributionItem.java:488)
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:400)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1699)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1663)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:367)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
Caused by: java.lang.NullPointerException
org.eclipse.cdt.internal.ui.wizards.classwizard.NewClassCode Generator.createClass(NewClassCodeGenerator.java:152)
org.eclipse.cdt.ui.wizards.NewClassCreationWizardPage.create Class(NewClassCreationWizardPage.java:1915)
org.eclipse.cdt.ui.wizards.NewClassCreationWizardPage.create Class(NewClassCreationWizardPage.java:1874)
org.eclipse.cdt.internal.ui.wizards.NewClassCreationWizard.f inishPage(NewClassCreationWizard.java:57)
org.eclipse.cdt.internal.ui.wizards.NewElementWizard$2.run(N ewElementWizard.java:99)
org.eclipse.cdt.internal.core.model.BatchOperation.executeOp eration(BatchOperation.java:34)
org.eclipse.cdt.internal.core.model.CModelOperation.execute( CModelOperation.java:342)
org.eclipse.cdt.internal.core.model.CModelOperation.run(CMod elOperation.java:607)
at org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1719)
at org.eclipse.cdt.core.model.CoreModel.run(CoreModel.java:1222 )
org.eclipse.cdt.internal.ui.actions.WorkbenchRunnableAdapter .run(WorkbenchRunnableAdapter.java:63)
org.eclipse.jface.operation.ModalContext$ModalContextThread. run(ModalContext.java:113)
Root exception:
FUDForum. Page generated in 0.02670 seconds
