Home » Modeling » TMF (Xtext) » Mode, Deep and WordRule
Mode, Deep and WordRule [message #14929] |
Mon, 30 June 2008 10:08  |
looking through the TCS features I do not know yet, I am puzzled about
these:
The syntax and metamodel defines deep and mode attributes for
ClassTemplates, yet I have not found an example for either in the zoo.
Also, i notice the Word rule for tokens has an attribute words, which does
not seem to do much. E.g. when I use the SPL example from the zoo, TCS
transforms
token NAME : word(
start = [alpha] | "_",
part = [alnum] | "_"
, words = ("true" : BOOLEAN, "false" : BOOLEAN)
to
NAME @init {}
: (((('A' .. 'Z'| 'a' .. 'z')| '_') ((('A' .. 'Z'| 'a' .. 'z'| '0' ..
'9')| '_'))*))
So what's the meaning of the words attribute?
Re: Mode, Deep and WordRule [message #16517 is a reply to message #14929] |
Wed, 09 July 2008 10:59   |
> these:
My advice is simplicity: if you do not need a feature, then you should
not use it.
Here are description of the two features you mention:
- "mode" can be used to dispatch to specific templates depending on the
context (i.e., you can have several templates for the same class).
- "deep abstract" makes it unnecessary to define many abstract
templates. A single one for the inheritance root is enough (provided you
do not reference the intermediate abstract classes).
> does not seem to do much. E.g. when I use the SPL example from the zoo,
> TCS transforms
> token NAME : word(
> to
> NAME @init {}
> '0' .. '9')| '_'))*))
The "false" and "true" words was necessary with ANTLR 2 when we had a
primitiveTemplate for booleans. Because "false" and "true" were not
defined as keywords in the syntax, the lexer had to have a definition of
them.
Now, the peferred way to deal with booleans is not to use a
primitiveTemplate any more, but to simply use a conditional construct:
template BooleanExp
: (value ? "true" : "false")
As you can see, in this version, "true" and "false" are explicitly
defined as keywords.
Frédéric Jouault
Re: [TCS] Mode, Deep and WordRule [message #16533 is a reply to message #16517] |
I forgot to add (and do) that you should prefix the subject of your
TCS-related posts with [TCS].
Frédéric Jouault
Frédéric Jouault a écrit :
>> these:
> not use it.
>> zoo, TCS transforms
>> token NAME : word(
>> to
>> NAME @init {}
> them.
> template BooleanExp
> Frédéric Jouault
Re: [TCS] Mode, Deep and WordRule [message #16695 is a reply to message #16533] |
Fri, 18 July 2008 08:03   |
thanks for the explanation.
I see this also works for abstract templates, as long as all subtemplates
also specify that mode. I guess it would also work for operatored
templates?
>>> zoo, TCS transforms
So the words attribute is ignored by TCS when using ANTLR 3?
Re: [TCS] Mode [message #18246 is a reply to message #18130] |
Wed, 23 July 2008 11:07  |
Modes currently do not work with operatored templates.
Frédéric Jouault
Thibault a écrit :
> wehn I try using an operatored moded template, i get a NullPointerException
> Such as
> template Expression #test operatored
> : "Test"
> java.lang.NullPointerException
> [am3.saveModel] at
> org.eclipse.m2m.atl.engine.vm.nativelib.AMN.getInt(AMN.java: 53)
> [am3.saveModel] at
> org.eclipse.gmt.tcs.extractor.TCSExtractor.eval(TCSExtractor .java:558)
> [am3.saveModel] at
> org.eclipse.gmt.tcs.extractor.TCSExtractor.eval(TCSExtractor .java:525)
> [am3.saveModel] at
> org.eclipse.gmt.tcs.extractor.TCSExtractor.serializeSeqElem( TCSExtractor.java:503)
> [am3.saveModel] at
> org.eclipse.gmt.tcs.extractor.TCSExtractor.serializeSeq(TCSE xtractor.java:392)
> [am3.saveModel] at
> org.eclipse.gmt.tcs.extractor.TCSExtractor.serialize(TCSExtr actor.java:275)
> [am3.saveModel] at
> org.eclipse.gmt.tcs.extractor.TCSExtractor.serializeProperty (TCSExtractor.java:611)
> [am3.saveModel] at
> org.eclipse.gmt.tcs.extractor.TCSExtractor.serializeProperty (TCSExtractor.java:594)
> [am3.saveModel] at
> org.eclipse.gmt.tcs.extractor.TCSExtractor.serializeSeqElem( TCSExtractor.java:432)
> [am3.saveModel] at
> [am3.saveModel] at
> [am3.saveModel] at
> [am3.saveModel] at
> [am3.saveModel] at
> [am3.saveModel] at
> org.eclipse.gmt.tcs.extractor.TCSExtractor.serializeSeqElem( TCSExtractor.java:506)
> [am3.saveModel] at
> [am3.saveModel] at
> [am3.saveModel] at
> [am3.saveModel] at
> [am3.saveModel] at
> [am3.saveModel] at
> [am3.saveModel] at
> org.eclipse.gmt.tcs.extractor.TCSExtractor.serializeSeqElem( TCSExtractor.java:489)
> [am3.saveModel] at
> [am3.saveModel] at
> [am3.saveModel] at
> org.eclipse.gmt.tcs.extractor.TCSExtractor.extract(TCSExtrac tor.java:210)
> [am3.saveModel] at
> org.eclipse.gmt.am3.tools.ant.toolkit.AM3AntToolKit$2.run(AM 3AntToolKit.java:459)
Current Time: Mon Jul 14 16:05:13 EDT 2025
Powered by FUDForum. Page generated in 0.08996 seconds
