JFreeChart Problem in OS X (Tiger) [message #159159] |
Sun, 02 July 2006 23:43 |
Originally posted by: desmond.runbox.com
I don't know if I'm posting this in the right place but I'm trying to
use JFreeChart in eclipse.
I placed the JFreeChart jar files into the /Library/Java/Extensions
directory and when I launch eclipse I get this error.
Can anyone help?
Thanks.
Desmond
Unable to create view: Plug-in "org.eclipse.ui.ide" was unable to
instantiate class "org.eclipse.ui.views.navigator.ResourceNavigator".
java.lang.NullPointerException at
org.eclipse.jface.dialogs.DialogSettings.load(DialogSettings .java:275)
org.eclipse.jface.dialogs.DialogSettings.load(DialogSettings .java:303)
org.eclipse.jface.dialogs.DialogSettings.load(DialogSettings .java:244)
org.eclipse.jface.dialogs.DialogSettings.load(DialogSettings .java:261)
org.eclipse.ui.plugin.AbstractUIPlugin.loadDialogSettings(Ab stractUIPlugi
n.java:408) at
org.eclipse.ui.plugin.AbstractUIPlugin.getDialogSettings(Abs tractUIPlugin
..java:230) at
org.eclipse.ui.views.navigator.ResourceNavigator.<init>(ResourceNavigator
..java:206) at
sun.reflect.NativeConstructorAccessorImpl.newInstance0(Nativ e Method)
sun.reflect.NativeConstructorAccessorImpl.newInstance(Native ConstructorAc
cessorImpl.java:39) at
sun.reflect.DelegatingConstructorAccessorImpl.newInstance(De legatingConst
ructorAccessorImpl.java:27) at
java.lang.reflect.Constructor.newInstance(Constructor.java:4 94) at
java.lang.Class.newInstance0(Class.java:350) at
java.lang.Class.newInstance(Class.java:303) at
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableE
xtension(ConfigurationElement.java:162) at
xtension(ConfigurationElement.java:142) at
xtension(ConfigurationElement.java:129) at
org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecu
tableExtension(ConfigurationElementHandle.java:48) at
org.eclipse.ui.internal.WorkbenchPlugin.createExtension(Work benchPlugin.j
ava:232) at
org.eclipse.ui.internal.registry.ViewDescriptor.createView(V iewDescriptor
..java:99) at
org.eclipse.ui.internal.ViewReference.createPartHelper(ViewR eference.java
:267) at
org.eclipse.ui.internal.ViewReference.createPart(ViewReferen ce.java:180)
org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartRefer
ence.java:552) at
org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:28 3) at
org.eclipse.ui.internal.ViewPane.setVisible(ViewPane.java:51 2) at
org.eclipse.ui.internal.presentations.PresentablePart.setVis ible(Presenta
blePart.java:126) at
org.eclipse.ui.internal.presentations.util.PresentablePartFo lder.select(P
resentablePartFolder.java:269) at
org.eclipse.ui.internal.presentations.util.LeftToRightTabOrd er.select(Lef
tToRightTabOrder.java:65) at
org.eclipse.ui.internal.presentations.util.TabbedStackPresen tation.select
Part(TabbedStackPresentation.java:391) at
org.eclipse.ui.internal.PartStack.refreshPresentationSelecti on(PartStack.
java:1102) at
org.eclipse.ui.internal.PartStack.createControl(PartStack.ja va:591) at
org.eclipse.ui.internal.PartStack.createControl(PartStack.ja va:528) at
org.eclipse.ui.internal.PartSashContainer.createControl(Part SashContainer
..java:485) at
org.eclipse.ui.internal.PerspectiveHelper.activate(Perspecti veHelper.java
:230) at
org.eclipse.ui.internal.Perspective.onActivate(Perspective.j ava:813) at
org.eclipse.ui.internal.WorkbenchPage.onActivate(WorkbenchPa ge.java:2201)
org.eclipse.ui.internal.WorkbenchWindow$5.run(WorkbenchWindo w.java:2356)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
org.eclipse.ui.internal.WorkbenchWindow.setActivePage(Workbe nchWindow.jav
a:2338) at
org.eclipse.ui.internal.WorkbenchWindow.restoreState(Workben chWindow.java
:1861) at
org.eclipse.ui.internal.Workbench.doRestoreState(Workbench.j ava:2566)
at org.eclipse.ui.internal.Workbench.access$14(Workbench.java:2 515) at
org.eclipse.ui.internal.Workbench$19.run(Workbench.java:1514 ) at
org.eclipse.ui.internal.Workbench$16.run(Workbench.java:1263 ) at
org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.
java:346) at
org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:291) at
org.eclipse.jface.dialogs.ProgressMonitorDialog.run(Progress MonitorDialog
..java:447) at
org.eclipse.ui.internal.Workbench.runStartupWithProgress(Wor kbench.java:1
258) at
org.eclipse.ui.internal.Workbench.restoreState(Workbench.jav a:1512) at
org.eclipse.ui.internal.Workbench.access$12(Workbench.java:1 491) at
org.eclipse.ui.internal.Workbench$17.run(Workbench.java:1374 ) at
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.j
ava:1044) at org.eclipse.core.runtime.Platform.run(Platform.java:783)
at org.eclipse.ui.internal.Workbench.restoreState(Workbench.jav a:1318)
org.eclipse.ui.internal.WorkbenchConfigurer.restoreState(Wor kbenchConfigu
rer.java:183) at
org.eclipse.ui.application.WorkbenchAdvisor.openWindows(Work benchAdvisor.
java:700) at
org.eclipse.ui.internal.Workbench.init(Workbench.java:1034) at
org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1636) at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:36
7) at
org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143) at
org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivat
or.java:226) at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:3
76) at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:1
63) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java
:39) at
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorI
mpl.java:25) at java.lang.reflect.Method.invoke(Method.java:585) at
org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 ) at
org.eclipse.core.launcher.Main.basicRun(Main.java:278) at
org.eclipse.core.launcher.Main.run(Main.java:973) at
org.eclipse.core.launcher.Main.main(Main.java:948)
FUDForum. Page generated in 0.10917 seconds
