Home » Language IDEs » Java Development Tools (JDT) » Eclipse M8 Ant problem/question
Eclipse M8 Ant problem/question [message #159138] Mon, 17 May 2004 14:26
Originally posted by: newsgroup.salas.com
I am having a problem with getting ant to be pointed at the correct base
directory when it executes a build.xml.
I am running on Windows XP.
The project is called Informa.
Eclipse lives in c:\eclipse.
The project workspace is c:\JavaWork\informa
And now:
1. In Eclipse, External Tools, for the Ant Build, on the Main tab, I specify
the Base directory as ${workspace_loc/informa}
2. By the way I launch Eclipse with the -data switch on the command line
4. And with those settings, it seems that the build.xml thinks that Base
Directory is c:\eclipse
I also noticed something weird, which is in the header area of the Ant
Properties dialog box, when I fill it out as I describe, there is a red X
(Eclipse error) error followed by this cryptic message text displayed right
on the dialog box.
[Targets]: file:c:/JavaWork/informa/build.xml:9: Basedir
C:\eclips\${workspace_loc:\informa} does not exist
It doesn't prevent me from running it but if you look at message there is
something fishy about it.
Any clues that you see?
Thanks.
Previous Topic:unable to restore java source locator
Next Topic:IJavaElementDelta
Current Time: Sat Jul 26 17:58:12 EDT 2025
Powered by FUDForum. Page generated in 0.02516 seconds
