Eclipse will not start.. please tell me what does my error mean?? [message #159096] |
Wed, 19 November 2003 15:55 |
Originally posted by: mmovafaghi.financialengines.com
This is my first time posting. I have been using eclipse for a year with
no problems. I tried to start eclipse this morning and it told me to
check the .log file. This is the fisrt time eclipse has not started up.
I tried restarting my machine, but that did not work.
I am wondering if anyone can tell me what the following error means (from
my .log) and how my project got into this state. Is there any way to fix
it (as it would be a huge pain to recreate the project)???
Thank you for your consideration,
Matt
!SESSION Nov 19, 2003 12:19:07.125
java.version=1.4.2
Command-line arguments: -os win32 -ws win32 -arch x86 -data d:\workspace
-install file:D:/eclipse/
!ENTRY org.eclipse.core.runtime 4 2 Nov 19, 2003 12:19:07.140
!MESSAGE Problems occurred when invoking code from plug-in:
"org.eclipse.core.runtime".
!STACK 0
org.eclipse.core.internal.dtree.ObjectNotFoundException: Tree element
/ferrari/src/xtier/engine/core/vssver.scc not found.
org.eclipse.core.internal.dtree.AbstractDataTree.handleNotFo und(AbstractDataTree.java:243)
org.eclipse.core.internal.dtree.DeltaDataTree.getData(DeltaD ataTree.java:608)
org.eclipse.core.internal.dtree.DataDeltaNode.asBackwardDelt a(DataDeltaNode.java:54)
org.eclipse.core.internal.dtree.NoDataDeltaNode.asBackwardDe lta(NoDataDeltaNode.java:56)
org.eclipse.core.internal.dtree.DataDeltaNode.asBackwardDelt a(DataDeltaNode.java:51)
org.eclipse.core.internal.dtree.DeltaDataTree.asBackwardDelt a(DeltaDataTree.java:95)
org.eclipse.core.internal.dtree.DeltaDataTree.reroot(DeltaDa taTree.java:819)
org.eclipse.core.internal.dtree.DeltaDataTree.reroot(DeltaDa taTree.java:818)
org.eclipse.core.internal.dtree.DeltaDataTree.reroot(DeltaDa taTree.java:794)
org.eclipse.core.internal.watson.ElementTree.immutable(Eleme ntTree.java:698)
org.eclipse.core.internal.resources.SaveManager.restore(Save Manager.java:511)
org.eclipse.core.internal.resources.SaveManager.startup(Save Manager.java:1033)
org.eclipse.core.internal.resources.Workspace.startup(Worksp ace.java:1734)
at org.eclipse.core.internal.resources.Workspace.open(Workspace .java:1537)
org.eclipse.core.resources.ResourcesPlugin.startup(Resources Plugin.java:268)
org.eclipse.core.internal.plugins.PluginDescriptor$1.run(Plu ginDescriptor.java:728)
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java:889)
org.eclipse.core.internal.plugins.PluginDescriptor.internalD oPluginActivation(PluginDescriptor.java:740)
org.eclipse.core.internal.plugins.PluginDescriptor.doPluginA ctivation(PluginDescriptor.java:188)
org.eclipse.core.internal.plugins.PluginClassLoader.activate Plugin(PluginClassLoader.java:112)
org.eclipse.core.internal.plugins.PluginClassLoader.internal FindClassParentsSelf(PluginClassLoader.java:185)
org.eclipse.core.internal.boot.DelegatingURLClassLoader.find ClassParentsSelf(DelegatingURLClassLoader.java:490)
org.eclipse.core.internal.boot.DelegatingURLClassLoader.load Class(DelegatingURLClassLoader.java:882)
org.eclipse.core.internal.boot.DelegatingURLClassLoader.acce ss$0(DelegatingURLClassLoader.java:876)
org.eclipse.core.internal.boot.DelegatingURLClassLoader$Dele gateLoader.loadClass(DelegatingURLClassLoader.java:90)
org.eclipse.core.internal.boot.DelegatingURLClassLoader.find ClassPrerequisites(DelegatingURLClassLoader.java:554)
org.eclipse.core.internal.boot.DelegatingURLClassLoader.load Class(DelegatingURLClassLoader.java:890)
org.eclipse.core.internal.boot.DelegatingURLClassLoader.load Class(DelegatingURLClassLoader.java:862)
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
at java.lang.Class.getDeclaredConstructors0(Native Method)
at java.lang.Class.privateGetDeclaredConstructors(Unknown Source)
at java.lang.Class.getConstructor0(Unknown Source)
at java.lang.Class.newInstance0(Unknown Source)
at java.lang.Class.newInstance(Unknown Source)
org.eclipse.core.internal.plugins.PluginDescriptor.createExe cutableExtension(PluginDescriptor.java:138)
org.eclipse.core.internal.plugins.PluginDescriptor.createExe cutableExtension(PluginDescriptor.java:167)
org.eclipse.core.internal.plugins.ConfigurationElement.creat eExecutableExtension(ConfigurationElement.java:103)
org.eclipse.core.internal.runtime.InternalPlatform.loaderGet Runnable(InternalPlatform.java:472)
org.eclipse.core.internal.boot.InternalBootLoader.getRunnabl e(InternalBootLoader.java:471)
org.eclipse.core.internal.boot.InternalBootLoader.run(Intern alBootLoader.java:841)
at org.eclipse.core.boot.BootLoader.run(BootLoader.java:461)
at org.eclipse.core.launcher.Main.basicRun(Main.java:291)
at org.eclipse.core.launcher.Main.run(Main.java:747)
at org.eclipse.core.launcher.Main.main(Main.java:583)
!ENTRY org.eclipse.core.runtime 4 2 Nov 19, 2003 12:19:07.171
!MESSAGE Plug-in "org.eclipse.ui" was unable to instantiate class
"org.eclipse.ui.internal.Workbench".
!STACK 0
org.eclipse.core.internal.boot.DelegatingLoaderException:
org.eclipse.core.runtime.CoreException: Problems encountered starting up
plug-in: "org.eclipse.core.resources".
org.eclipse.core.internal.plugins.PluginDescriptor.internalD oPluginActivation(PluginDescriptor.java:746)
!ENTRY org.eclipse.core.runtime 4 2 Nov 19, 2003 12:19:07.187
!STACK 0
!SESSION
!ENTRY org.eclipse.core.launcher 4 0 Nov 19, 2003 12:19:07.203
!MESSAGE Exception launching the Eclipse Platform:
!STACK
java.lang.reflect.InvocationTargetException
Caused by: java.lang.IllegalArgumentException: Application not found:
org.eclipse.ui.workbench.
org.eclipse.core.internal.boot.InternalBootLoader.run(Intern alBootLoader.java:843)
... 7 more
FUDForum. Page generated in 0.03358 seconds
