Home » Eclipse Projects » GEF » Source code of Randy's GEF tutorial
Source code of Randy's GEF tutorial [message #158939] Sat, 20 November 2004 13:58 Go to next message
I've just read the GEF tutorial located at the IBM developerWorks website.
Does anyone know where I can get the source of that? All I want is a
small plugin to start from where no model is persistently saved. Just a
hardcoded model with a few rectangles to move around.
Thanks for any help.
Christian
Re: Source code of Randy's GEF tutorial [message #158991 is a reply to message #158939] Mon, 22 November 2004 00:34 Go to previous messageGo to next message
Originally posted by: ranjit.notMyId.com
Christian Hauser wrote:
> Hello,
> Christian
There are some simple examples to start at the wiki page.
http://eclipsewiki.editme.com/GEF
The Simple Example from jbonevic is what you may want to look at.
It is the vanilla flavour example with basic shapes to move around.
Re: Source code of Randy's GEF tutorial [message #159085 is a reply to message #158991] Mon, 22 November 2004 14:09 Go to previous messageGo to next message
I'm using Eclipse 3.0.1 and GEF 3.0.1, but get the following error using
jbonevic's plugin when trying to open the Simple GEF Example file Wizard:
The selected wizard could not be started.
Reason:
Plug-in com.bonevich.simplegef.SimpleGefPlugin was unable to load class
com.bonevich.simplegef.wizards.NewSimpleGefWizard.
My build.properties file looks like this:
source.simplegef.jar = src/java/
output.simplegef.jar = target/classes/
bin.includes = plugin.xml,\
META-INF/,\
simplegef.jar,\
icons/
In target/classes/ are the .class files. I don't know what the problem
is, but it just doesn't seen to work for me.
Any help is highly appreciated.
Christian
Re: Source code of Randy's GEF tutorial [message #159102 is a reply to message #159085] Mon, 22 November 2004 15:26 Go to previous messageGo to next message
> META-INF/,\
> simplegef.jar,\
> icons/
Including the directory META-INF (which I had deleted) seems to fix my
problems. However, why should I have to add the MANIFEST.MF file to make
the plugin run?
Thanks anyway to Jeffey for this mini GEF plugin. It really is a good
and very simple starting point.
Christian
Re: Source code of Randy's GEF tutorial [message #159184 is a reply to message #158939] Tue, 23 November 2004 11:17 Go to previous message
The latest 3.1 builds contain a basic "shapes" example.
"Christian Hauser" <c.hauser@active.ch> wrote in message
news:cno42t$ip$1@www.eclipse.org...
> Hello,
> Christian
Previous Topic:how to create a line editpart?
Next Topic:Multipage editor with zoom
Current Time: Thu Jun 05 00:57:42 EDT 2025
Powered by FUDForum. Page generated in 0.24463 seconds
