Home » Archived » BIRT » pdf generation w/ parameters
pdf generation w/ parameters [message #158906] Fri, 05 May 2006 19:12 Go to next message
I am using BIRT 2.0.0 and experiencing the following issue:
I have made what I believe are the necessary modifications for the PDF
emitter and I am able to get a simple report to render in Acrobat as PDF.
The problem is that when I try to render a report that depends on
parameters (being passed in on the URL) I get a blank page in the
Acrobat viewer. Furthermore if I take the working simple example from
above and add a parameter to the URL I get a blank page.
Just to be clear:
http://localhost/run?__report=table.rptdesign&__format=p df
-this successfully generates the PDF
http://localhost/run?__report=table.rptdesign&__format=p df&__locale=en_US
-this opens acrobat with a blank page, no errors in the logs
Any suggestions?
thanks,
Brian
Re: pdf generation w/ parameters [message #159510 is a reply to message #158906] Tue, 09 May 2006 06:42 Go to previous messageGo to next message
Brian,
Can you try a couple of things?
1 - try adding a parameter and displaying it in a data element.
ie add the data element and set its value to params["myparameter"].
Do this without changing the locale.
2 - Can you try 2.0.1?
Jason
"Brian Kallay" <brian.kallay@bricsnet.com> wrote in message
news:e3gm6c$4fd$1@utils.eclipse.org...
> parameters (being passed in on the URL) I get a blank page in the Acrobat
> viewer. Furthermore if I take the working simple example from above and
> Just to be clear:
> Any suggestions?
> thanks,
> Brian
Re: pdf generation w/ parameters [message #161240 is a reply to message #159510] Mon, 15 May 2006 20:33 Go to previous message
Hi Jason,
Thanks for your suggestions. I am happy to report that this was not a
BIRT issue at all, our application does some post processing on requests
that was causing this issue.
Sorry for the unnecessary traffic on the board.
-Brian
Jason Weathersby wrote:
> Brian,
> Thanks
> Jason
>>Hi,
>>Just to be clear:
>>Any suggestions?
>>thanks,
>>Brian
Previous Topic:probaby the most stupid question
Next Topic:How to send Java Object as parameter to report engine?
Current Time: Sat Jun 28 17:04:32 EDT 2025
Powered by FUDForum. Page generated in 0.03410 seconds
