Home » Newcomers » Newcomers » How to import the exist project
How to import the exist project [message #14894] Tue, 25 January 2005 01:34 Go to next message
hi, All.
I'm a newbie of Eclipse. Recently, I met a problem that i tried to import my
exist project into Eclipse to edit, but there are some problems to break me.
1.My project is orgnized by Ant, and the classpath and where to put compiled
file is defined in the ant build.xml and build.properties.
How could i still use the structure after i import the project into Eclipse
2.My project's build.xml import other build.xml, how could make the
build.xml work again
Thanks Advance
Ian Liu
Re: How to import the exist project [message #16029 is a reply to message #14894] Tue, 25 January 2005 10:25 Go to previous messageGo to next message
Originally posted by: Chris_Laffra.ca.ibm.com
I am not sure, but maybe this FAQ helps?
http://www.eclipsefaq.org/chris/faq/html/faq36.html
Chris Laffra, http://eclipsefaq.org
"Ian Liu" <ianl@inetsoft.com> wrote in message
news:ct4p8q$4s2$1@www.eclipse.org...
> hi, All.
my
me.
compiled
Eclipse
> Thanks Advance
> Ian Liu
Re: How to import the exist project [message #16959 is a reply to message #16029] Tue, 25 January 2005 22:31 Go to previous message
thx a lot, resource you provided can solve my problem:)
by the way, in the guide, it said the linked resource could be inserted into
the project, but i found it couldn't be compiled.
"Chris Laffra" <Chris_Laffra@ca.ibm.com> д
Previous Topic:Where to find the WelcomeEditor ?
Next Topic:Setting up a project from scratch.
Current Time: Thu Jul 10 08:09:18 EDT 2025
Powered by FUDForum. Page generated in 0.11066 seconds
