Setting the selection of child node to parent node. [message #158752] |
Thu, 08 November 2007 01:23  |
Originally posted by: biju_gopinathan.rediffmail.com
Hi all,
How can we change the selection on clicking a child node to its
parent node. So that I can view the properties of the parent node in the
property view even on selecting child node(which is my requirement).
Thanks, Biju
Re: Setting the selection of child node to parent node. [message #158864 is a reply to message #158760] |
Thu, 08 November 2007 06:42   |
Hi Biju,
You may use isSelectable() method to control selectability of the node.
If the node is not selectable, the node underneath will get selected
(and normally, it is the parent node).
Another solution is to override method getTargetEditPart in your
(non-)resizable edit policy to return getHost().getParent() as the
target edit part for the REQ_SELECTION request.
Your solution is also ok, but seems to leak deleted edit parts for the
lifetime of the graphical viewer.
Boris
biju wrote:
> Hi all,
> Got it, I did it by adding a selection listener and changing the
> selection in the child edit part, as follows.I am calling the following
> method from the createDefaultEditPolicies() function of my child edit
> part.
> Thanks, Biju
> private void addSelectionListener() {
> this.getViewer().addSelectionChangedListener(new
> ISelectionChangedListener(){
> @Override
> public void selectionChanged(SelectionChangedEvent
> selectionEvent) {
> if(selectionEvent.getSelection() instanceof
> StructuredSelection){
> StructuredSelection selection=(StructuredSelection)
> selectionEvent.getSelection();
> if(selection.getFirstElement() instanceof
> ConveyorSlotEditPart){
> getViewer().setSelection(new
> StructuredSelection(((ConveyorSlotEditPart)selection.getFirs tElement()).getParent()));
> biju wrote:
>> Hi all,
>> its parent node. So that I can view the properties of the parent node
>> in the property view even on selecting child node(which is my
>> requirement).
>> Thanks, Biju
Re: Setting the selection of child node to parent node. [message #158970 is a reply to message #158864] |
Thu, 08 November 2007 08:20  |
Hi Boris Blajer,
Thanks for your Idea,
Its working better, and is simple, I just override the
isSelectable() of child edit part to return false.
Thanks, Biju
Boris Blajer wrote:
> Hi Biju,
> Best regards,
> Boris
> biju wrote:
>> Hi all,
>> the selection in the child edit part, as follows.I am calling the
>> following method from the createDefaultEditPolicies() function of my
>> child edit part.
>> Thanks, Biju
>> @Override
>> selectionEvent) {
>> StructuredSelection
>> selection=(StructuredSelection) selectionEvent.getSelection();
>> biju wrote:
>>> Hi all,
>>> requirement).
>>> Thanks, Biju
FUDForum. Page generated in 0.06079 seconds
