Home » Newcomers » Newcomers » Use of SJPP (Simple Java Pre-Processor) within Java classes causes Syntax errors in Eclipse 3.2 (but
Use of SJPP (Simple Java Pre-Processor) within Java classes causes Syntax errors in Eclipse 3.2 (but [message #158681] Wed, 28 June 2006 11:28 Go to next message
I am trying to use Eclipse 3.2 in order to test some new projects (like
the data tools platform).
Some of our Java classes use SJPP to enable conditional compilation
depending on the encoding. All of those classes fail to compile in
Eclipse 3.2RC7 (I20060602-1317) - but they compile just fine in Eclipse
3.1.2.
Where and how do I report this problem - and how can I resolve it?
Chuck
Re: Use of SJPP (Simple Java Pre-Processor) within Java classes causes Syntax errors in Eclipse 3.2 [message #158726 is a reply to message #158681] Wed, 28 June 2006 13:03 Go to previous messageGo to next message
> 3.1.2.
First make sure your compiler settings are the same for both platforms.
(Window -> Preferences -> Java -> Compiler and its sub-items). If you
really do find a code snippet that compiles in Eclipse 3.1.2 and not in
Eclipse 3.2RC7, report it (with the testcase) in Bugzilla:
http://bugs.eclipse.org/bugs
Andrew Jr.
IBM Phoenix Labs (OTI)
2929 North Central Avenue
Phoenix, Arizona, USA 85012
Re: Use of SJPP (Simple Java Pre-Processor) within Java classes causes Syntax errors in Eclipse 3.2 [message #158750 is a reply to message #158726] Wed, 28 June 2006 14:07 Go to previous message
Apparently - someone else *just* discovered and reported this bug today:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=149028
Chuck
>> Eclipse 3.1.2.
> Andrew Jr.
Previous Topic:On coworker gets "AssertionFailedError: No tests found" on simple junit runs
Next Topic:Eclipse Crash on Startup startup.jar
Current Time: Fri Jul 18 01:36:18 EDT 2025
Powered by FUDForum. Page generated in 0.25443 seconds
