Home » Eclipse Projects » GEF » Add a toggle action to figure and communicate it to model via CommandStack
Add a toggle action to figure and communicate it to model via CommandStack [message #158565] Thu, 18 November 2004 15:44 Go to next message
Originally posted by: vladimir.bogus.com
I need to be able to toggle the figure state by clicking on its hot spot via
CommandStack and persist the state information in my model. I think this is
doable using the following design, but would like to solicit an imput from
the gurus about whether this is a good approach.
1. Add a (Clickable) toggle to a figure.
2. Add changeListener to the toggle figure in the EditPart.
3. In the changeListener on "pressed" event:
-create a new request of type "TOGGLE";
-call getCommand(request)
-provide a policy that would generate a toggle command on this TOGGLE
request.
4. Toggle command will change the state of the model, which in turn fire a
property change event, which will be received by the editPart and will
refresh the figure. (ugh)
This is a little convoluted, but it seems that it should be able to do the
job. Please let me know what you think. Thanks.
Vladimir
Re: Add a toggle action to figure and communicate it to model via CommandStack [message #158837 is a reply to message #158565] Fri, 19 November 2004 13:04 Go to previous messageGo to next message
Sounds fine to me. Unless the "toggle" is something like expand/collapse,
which generally is not stored in the model and not undoable.
"Vladimir" <vladimir@bogus.com> wrote in message
news:cnj1ip$4sl$1@www.eclipse.org...
> Hello,
via
is
> request.
> Vladimir
Re: Add a toggle action to figure and communicate it to model via CommandStack [message #158860 is a reply to message #158837] Fri, 19 November 2004 14:00 Go to previous messageGo to next message
Thanks. Incidentally, I just finished coding and it works, with one minor
change - I have to listen to "selection" event, because "pressed" is fired
on both mouse up and mouse down.
Vladimir
"Randy Hudson" <none@us.ibm.com> wrote in message
news:cnlcj9$ina$1@www.eclipse.org...
> > Hello,
> via
> is
from
TOGGLE
> > request.
a
the
> > Vladimir
Re: Add a toggle action to figure and communicate it to model via CommandStack [message #159206 is a reply to message #158860] Tue, 23 November 2004 11:25 Go to previous messageGo to next message
Pressed is a state of the button UI, true/false. I think there is an
ActionListener just like other Button implementations.
news:cnlfs4$om7$1@www.eclipse.org...
> Vladimir
expand/collapse,
> > > Hello,
spot
> > via
this
> > is
> from
> TOGGLE
> > > request.
fire
> a
> the
> > > Vladimir
Re: Add a toggle action to figure and communicate it to model via CommandSt [message #209245 is a reply to message #159206] Mon, 13 February 2006 08:59 Go to previous messageGo to next message
Originally posted by: hplaas.gmx.de
Hi.
I actually have a similar problem:
I have a Figure called "state". To this Figure I add a checkBox and to the "stateEditPart I add the changelistener. Now i want to save the checkbox´s state(selected or not) in the Model.
But Vladimirs only works 80%: The getCommand method pushes the Command on the the Commandstack, but it does not execute, although the "canExecute" method returns "true".
And that´s my question: How does the Command will be executed. Do I need an actionClass? Then I´ve the problem to execute the "run" method, because i see no way to hook the action to the selectionTool. (or to call the run-method of the action within the editPart)
Thanks for replies
Heiko
Re: Add a toggle action to figure and communicate it to model via CommandSt [message #209725 is a reply to message #209245] Sat, 18 February 2006 22:44 Go to previous message
Originally posted by: proyslim.gmail.com
I also had almost same problem as yours.
In my case, I solved this problem below.
final CheckBox selector = new CheckBox();
selector.addActionListener(new ActionListener() {
public void actionPerformed(ActionEvent event) {
Request request = new Toggle();
Command cmd = getCommand(request);
if( cmd != null )
getViewer().getEditDomain().getCommandStack().execute(cmd);
It would be good if my reply could help you.
Previous Topic:XYLayoutEditPolicy
Next Topic:How to find an object outside the visual area of a viewer
Current Time: Sat Jul 26 06:06:25 EDT 2025
Powered by FUDForum. Page generated in 0.07098 seconds
