Home » Modeling » GMF (Graphical Modeling Framework) » Use of Routing and JumpLinks For Connectors
Use of Routing and JumpLinks For Connectors [message #158477] Tue, 06 November 2007 06:35 Go to next message
Originally posted by: Shwetha.V.in.bosch.com
By default the Routing Style of a Connector is set to Oblique.How can I
change the default value to Rectilinear.Similarly Jump Links Status is
None by default how can I change it All and Jump Type to Chamfered.
I tried to override refereshRoutingStyle() in ConnectorEditPart,but it is
throwing an Exception.Please guide me where to change and which method to
change.
Instead of overriding the code can I change something in gmfgraph or
gmfgen to do the above mentioned changes.
Thanks in advance.
Shwetha
Re: Use of Routing and JumpLinks For Connectors [message #159128 is a reply to message #158477] Fri, 09 November 2007 01:20 Go to previous messageGo to next message
Dear All
We are also stuck with a similar Problem .. Can anyone help us out .. Can
anyone tell us how to configure the Style Values through GmfGraph or
GmfGen Models. If not using the model where should the code be changed.
Any help in this direction would be highly appreciated.
regards
Malai
Re: Use of Routing and JumpLinks For Connectors [message #159173 is a reply to message #159128] Fri, 09 November 2007 04:17 Go to previous messageGo to next message
I managed to find the solution for my query.
To change the style property of the connector I overrided
initializeFromPreferences() in ConnectorViewFactory class generated by GMF
inside factories package.
protected void initializeFromPreferences(View view) {
super.initializeFromPreferences(view);
IPreferenceStore store = (IPreferenceStore) getPreferencesHint()
.getPreferenceStore();
RoutingStyle routingStyle =
(RoutingStyle)view.getStyle(NotationPackage.Literals.ROUTING _STYLE);
if (routingStyle != null) {
// Routing.get(1) is for RECTILINEAR Routing style.
Routing routing = Routing.get(1);
if (routing != null) {
routingStyle.setRouting(routing);
routingStyle.setJumpLinkStatus(JumpLinkStatus.ALL_LITERAL);
routingStyle.setJumpLinkType(JumpLinkType.CHAMFERED_LITERAL) ;
It works for me,but would be happy to know is this the right place.
Thanks and Regards,
Shwetha
Re: Use of Routing and JumpLinks For Connectors [message #173756 is a reply to message #159173] Fri, 22 February 2008 10:08 Go to previous message
Shwetha wrote:
> Hello,
> GMF inside factories package.
> @Override
> Thanks and Regards,
> Shwetha
you can also change to the following code:
public class DiagramPreferenceInitializer extends
AbstractPreferenceInitializer {
* @generated NOT
public void initializeDefaultPreferences() {
IPreferenceStore store = getPreferenceStore();
DiagramPrintingPreferencePage.initDefaults(store);
DiagramGeneralPreferencePage.initDefaults(store);
DiagramAppearancePreferencePage.initDefaults(store);
DiagramConnectionsPreferencePage.initDefaults(store);
DiagramRulersAndGridPreferencePage.initDefaults(store);
// store.setDefault(IPreferenceConstants.PREF_LINE_STYLE,
// Routing.RECTILINEAR);
// store.setValue(IPreferenceConstants.PREF_LINE_STYLE,
// store.setDefault(IPreferenceConstants.PREF_SHOW_CONNECTION_H ANDLES,
// false);
Hope this helps,
Johan
Previous Topic:Routing behavior
Next Topic:Ecore with subpackages
Current Time: Tue Jul 22 13:06:39 EDT 2025
Powered by FUDForum. Page generated in 0.09007 seconds
