Undo with keyboard [message #158470] |
Thu, 18 November 2004 09:41  |
Originally posted by: arnaud.knowesis.fr
I cannot undo in my gef editor with keyboard but I can delete
I create a keyHandler :
keyHandler = new KeyHandler();
keyHandler.put(KeyStroke.getPressed(SWT.DEL, 127, 0),
getActionRegistry().getAction(ActionFactory.DELETE.getId())) ;
keyHandler.put(KeyStroke.getPressed(26, SWT.CTRL),
getActionRegistry().getAction(ActionFactory.UNDO.getId()));
keyHandler.put(KeyStroke.getPressed(25, SWT.CTRL),
getActionRegistry().getAction(ActionFactory.REDO.getId()));
and I reference it in my configureGraphicalViewer method :
GraphicalViewerKeyHandler keyHandler=new
GraphicalViewerKeyHandler(getGraphicalViewer());
keyHandler.setParent(getCommonKeyHandler(getGraphicalViewer( )));
getGraphicalViewer().setKeyHandler(this.keyHandler);
It works fine with the delet command but doesn t seem to run with the
undo/redo
thx
Re: Undo with keyboard [message #158478 is a reply to message #158470] |
Thu, 18 November 2004 11:19   |
I'm not sure if those are the correct keystrokes for undo. Have you put a
breakpoint in handleKeyPressed to see what the event actually is and if it
gets sent at all?
Undo/Redo are global actions with keybindings associated with the menu
entries. The menu entries might be intercepting the keystrokes (although
I've been told that this isn't the case if the action is disabled). Either
way, you'll want to register action handlers for those global actions since
that allows the user to use the menu as well. The same it true for delete.
KeyHandler is intended for stuff that doesn't appear in menus, although for
previous version of eclipse DELETE was not stolen by hte edit menu
"Arnaud" <arnaud@knowesis.fr> wrote in message
news:cnicai$pa8$1@www.eclipse.org...
> undo/redo
> thx
Re: Undo with keyboard [message #159367 is a reply to message #159126] |
Thu, 25 November 2004 09:03  |
I found the problem ...
the undo action wasn t correctly registered in the workbenchadvisor class
Pratik Shah wrote:
> Are you saying it works from the menu and not via the keyboard? I'm
> assuming you've registered the ActionBarContributor properly in the
> plugin.xml.
> news:cnsf79$c7m$1@www.eclipse.org...
>>I tried some changes :
>>I don t bind CTRL + Z and DEL key with the KeyHandler
>>and I create an ActionBarContributor :
>>protected void buildActions() {
>> IWorkbenchAction
>> undo=ActionFactory.UNDO.create(getPage().getWorkbenchWindow( ));
>> addRetargetAction((RetargetAction) undo);
>> IWorkbenchAction
>> redo=ActionFactory.REDO.create(getPage().getWorkbenchWindow( ));
>> addRetargetAction((RetargetAction) redo);
>> IWorkbenchAction
>> delete=ActionFactory.DELETE.create(getPage().getWorkbenchWin dow());
>> addRetargetAction((RetargetAction) delete);
>>The actionDefinitionId is correctly set, (the key binding is correctly
>>shown in my Edit Menu) but the accelerator CTRL + Z or Del doesnt work...
> a
> it
>>>gets sent at all?
> Either
> since
> delete.
> for
FUDForum. Page generated in 0.09084 seconds
