Home » Modeling » GMF (Graphical Modeling Framework) » GMF2 propsheet
GMF2 propsheet [message #158465] Tue, 06 November 2007 06:35 Go to next message
"Note : If you have no Property Section Container second root, you can now
use our new feature for “Adding extension models” for gmfgens, available
from the context menu of gmfgen. It should create that second root for
you, when you locate propsheet.ecore and select PropertySectionContainer
to instantiate."
what does it mean? what ecore have I got to set in the popping dialog of
<add extension model>? For sure "propsheet.ecore" is a name of fantasy,
and if I set the name of my only single .ecore I have, it does not like it
and throws errors everywhere.
This since I do not have a "Property section Container" thing.
I'm really freaking out to get just a simple lousy custom tab working!!
p.s. on gmf2
Re: GMF2 propsheet [message #158485 is a reply to message #158465] Tue, 06 November 2007 06:46 Go to previous message
er.. I do not have any "propsheet.ecore" in my whole harddisk anyway...
Previous Topic:Problems with loading a diagram_file
Next Topic:Way to draw gradient on custom figure - possible patch for gmf/draw2d
Current Time: Sat Jul 26 06:02:51 EDT 2025
Powered by FUDForum. Page generated in 0.03983 seconds
