Home » Language IDEs » C / C++ IDE (CDT) » post-build step fails
post-build step fails [message #158450] Fri, 18 November 2005 15:03 Go to next message
Originally posted by: alipowsky.lipowsky.de
eclipse 3.1.1 and cdt 3.0.1 (3.0.0 shows same behaviour)
I have a project, which compiles without error.
As soon as i define a post-build step, i get a strange error.
The error in independant of what i define for the post-build step.
(e.g. postbuild.bat, which should dump something to the console)
The last few lines of my console output are:
'Finished building target: MOD2992-01.elf'
make --no-print-directory post-build
src/eeprom.d:1: *** missing separator. Stop.
make: *** [MOD2992-01.elf] Error 2
make: Target `all' not remade because of errors.
Build complete for project MOD2992-01
Can anybody help ?
Andreas
Re: post-build step fails [message #159982 is a reply to message #158450] Tue, 06 December 2005 14:29 Go to previous messageGo to next message
Originally posted by: email.henningsievert.de
I have the same problem. Did you already solve it?
Re: post-build step fails [message #163415 is a reply to message #159982] Wed, 08 February 2006 03:14 Go to previous messageGo to next message
Originally posted by: oliver.lipowsky.de
Henning wrote:
The problem was an errornous build dependency file. For some reason, the
makefile subdir.mk got make 3.80 to produce a line break and some white
spaces at the wrong place. If you prevent the class
DefaultGCCDependencyCalculator from producing these annoyances, the
subdir.mk files will be parseable again. Simply comment out the lines
98,99,104, 105,107,108,111 so that it produces
echo $(@:%.o=%.d) $(dir $@) && arm-elf-gcc ...
instead of
echo $(@:%.o=%.d) $(dir $@) > $(@:%.o=%.d) && \
Hope that helps
Oliver
icon8.gif  Re: post-build step fails [message #514434 is a reply to message #163415] Mon, 15 February 2010 05:36 Go to previous message
Years later I run in the very same problem. I am using eclipse Galileo on a windows XP PC with cygwin installed. The toolchain is arm-eabi_q4.08 from codesourcery that came with eCos-3.0.
Very similar to your case, I get the following error-message:
..cut...
Finished building target: serial_1.elf
serial_1.d:1: *** multiple target patterns. Stop.
make: *** [serial_1.elf] Error 2
I read your "solution" several times, but do not understand! My eclipse Galileo is a prebuilt version, downloaded from the net, so I see nowhere lines that I can delete?????
Regards Robert
Previous Topic:CDT hover over capability
Next Topic:unable to get eclipse to work with cdt
Current Time: Mon Jul 14 02:18:45 EDT 2025
Powered by FUDForum. Page generated in 0.05121 seconds
