| Source folder in Context Menu of JavaEditor [message #158408] |
Wed, 12 May 2004 09:19  |
Hi Eclipse Gurus
I want to add my own actions under the "Source" subfolder of the Java
Editor's context menu, however I don't see any obvious way to do that...
Any suggestions will be greatly appreciated
Thank you !
| Re: Source folder in Context Menu of JavaEditor [message #159346 is a reply to message #158622] |
Tue, 18 May 2004 16:55  |
Hi Tom
You were right, I was on the older driver. It works on the latest one.
Thank you!
"Tom Eicher" <eclipse@tom.eicher.name> wrote in message
news:c808d6$6sj$1@eclipse.org...
> For this to work, you need I20040513_0800 - are you sure you have that?
> -tom
> Leho Nigul wrote:
> > Hi Tom
> > Thank you for your suggestion.
> > I tried it, but still got
> > "Invalid Menu Extension (Path is invalid):
com.example.actions.source.foo"
> > Any other suggestions that I try?
> > Thank you !
> > news:c7vi38$94s$1@eclipse.org...
> >>This will work with the most recent integration builds:
> >><!-- define the foo command -->
> >><!-- the command can then be referenced by various UI elements (actions,
> >>keybindings, toolbar etc.) -->
> >><extension
> >> point="org.eclipse.ui.commands">
> >> <command
> >> name="FooCommand"
> >> description="Executes Foo"
> >> category="org.eclipse.jdt.ui.category.source"
> >> id="com.example.commands.foo">
> >> </command>
> >></extension>
> >><!-- register an action for foo in the source menu -->
> >><!-- note that this will only add an entry to the context menu, not the
> >>main menu -->
> >><extension
> >> point="org.eclipse.ui.popupMenus">
> >> <viewerContribution
> >> targetID="#CompilationUnitEditorContext">
> >> <action
> >> definitionId="com.example.commands.foo"
> >> label="Foo"
> >> menubarPath="org.eclipse.jdt.ui.source.menu/additions"
> >> class="com.example.actions.source.FooAction"
> >> id="com.example.actions.source.foo">
> >> </action>
> >> </viewerContribution>
> >></extension>
> >>-tom
> >>Leho Nigul wrote:
> >>> Hi Eclipse Gurus
that...
> >>>Thank you !
FUDForum. Page generated in 0.04976 seconds
