Home » Eclipse Projects » GEF » where to store customized palette?
| where to store customized palette? [message #158395] |
Wed, 17 November 2004 18:22  |
Originally posted by: notmymail.mail.net
Ok I got a nice GEF editor with a very customizable palette.
I have implemented saving and reading the palette from an rdf file.
At the moment it is simply saved along with the diagram into the same fi=
le =
as the diagrammodel which is also an rdf file.
Where should I normally store the palette?
In the plugin preferences? or as a propertypage of the resource?
| Re: where to store customized palette? [message #158550 is a reply to message #158462] |
Thu, 18 November 2004 15:41   |
Originally posted by: Lamont_Gilbert.rigidsoftware.com
Frank Dyck wrote:
> On Wed, 17 Nov 2004 18:40:31 -0500, CL [dnoyeb] Gilbert
>>> same file as the diagrammodel which is also an rdf file.
>> I would save it in the preferences. unless you want each editor view
>> to have its own customized palette.
>> Preferences store = yourPlugin.getDefault().getPluginPreferences();
>> //a static method of grabbing your plugin, then getting the
>> preferences from it
> Well actually the palette is more bound the resource you create with it.
> So I´m thinking more property at the moment.
Bound to the resource or the resource type? Is your pallete more like
the outline view in that it presents some data from the Views model?
> But my question is more: How do i store it? It´s an rdf model.
your asking how to store the model or how to store the palette? or both?
> As far as i understand you normally add string properties to a property
> page.
> It also makes not much sense ATM do be able to edit it in either a
> property or preferences page. (Or i´d have to put the whole
> PaletteCustomizer functionality into the page...)
I had properties before I ever made my property editor page. Gotta
start somewhere.
> So at the moment I just want to store the rdf model or file somewhere
> along with the resource, and be able to load it on startup (from
> Editor.java) and get/set it from the customizer´s save/revertToSaved
> methods.
again, im getting mixed up. The rdf is the model, or the palette or is
this the same thing? or is the resource the model?
Respectfully,
CL Gilbert
"Verily, verily, I say unto you, He that entereth not by the door() into
the sheepfold{}, but climbeth up some other *way, the same is a thief
and a robber."
GnuPG Key Fingerprint:
82A6 8893 C2A1 F64E A9AD 19AE 55B2 4CD7 80D2 0A2D
For a free Java interface to Freechess.org see
http://www.rigidsoftware.com/Chess/chess.html
| Re: where to store customized palette? [message #158900 is a reply to message #158712] |
Fri, 19 November 2004 21:53   |
I am beginning to think that when you say palette you just mean model.
When we say palette here we mean a set of tools that are displayed in a
specific view. Such as, line draw tool, selection tool, text tool, etc.
When these are all put together in a sort of tool bar, we call it a
pallette.
If you mean the storable class that gets written to and read from a
file, or some other storage medium, we call that the model.
Is that consistent with what you are thinking?
>>>> view to have its own customized palette.
>>>> preferences from it
>>> with it.So I´m thinking more property at the moment.
>> like the outline view in that it presents some data from the Views
>> model?
> Bound to the resource. There is only one type that my editor opens.
> I think i don`t understand the second question...
> My palette provides tools to generate the views model.
> Store the palette (the palette-model :-))
> Sorry about the misleading terms.
> I convert the gef-palette to an RDFModel object which i can read/write
> to a file.
>>> property page.
>> start somewhere.
> How do you setProperties of a Resource?
> I`m a complete newbie to this.
> I just added the example extension PropertyPage and looked at it a bit.
> As far as i see it without the property page i would do something like
> this,
> where i normally write the palette to a file:
> ResourcesPlugin.getWorkspace().getRoot().setPersistentProper ty(
> new QualifiedName("", PALETTE_PROPERTY),
> someShortStringValue);
> Where the value should be representing the palette.
> But setPersistentProperty says to store short strings as values.
> I want to store an object of the type RDFModel.
> I mean i can convert it to a String but it won`t be under 2KB short!
>>> somewhere along with the resource, and be able to load it on
>>> startup (from Editor.java) and get/set it from the customizer´s
>>> save/revertToSaved methods.
>> is this the same thing? or is the resource the model?
> :-) It`s pretty confusing/misleading.
> I convert the palette to an rdf-model-object(from jena). So that is what
> i want to store.
> (I want to be able to export it later and can already read in palettes
> from rdf files.)
Respectfully,
CL Gilbert
and a robber."
| Re: where to store customized palette? [message #158915 is a reply to message #158900] |
Sat, 20 November 2004 10:57   |
It is the palette-tools that i want to store. But mine have parameters.
In my editor there are only two model classes GenericNode and =
GenericConnection,
which represent rdf Resources. Different rdf-properties are passed as =
parameters to the Generic model=C2=B4s contructors.
So accordingly there are also only two generic ToolEntry types which als=
o =
have to store parameters to pass to the generic model that they create.=
The palette represents an rdf schema, the diagram in the editor pane =
represents an rdf-file that is built from that schema.
So i haven`t got many diffrent toolentry classes but only two with lots =
of =
parameters to store.
> I am beginning to think that when you say palette you just mean model.=
> When we say palette here we mean a set of tools that are displayed in =
a =
> specific view. Such as, line draw tool, selection tool, text tool, et=
c. =
> When these are all put together in a sort of tool bar, we call it a =
> pallette.
> If you mean the storable class that gets written to and read from a =
> Frank Dyck wrote:
>>>>> I would save it in the preferences. unless you want each editor =
>>>>> Preferences store =3D yourPlugin.getDefault().getPluginPreferences=
>>>>> //a static method of grabbing your plugin, then getting the =
>>>>> preferences from it
>>>> Well actually the palette is more bound the resource you create =
>>>> with it.So I=C2=B4m thinking more property at the moment.
>>> Bound to the resource or the resource type? Is your pallete more =
>>> like the outline view in that it presents some data from the Views =
>>> model?
>>>> But my question is more: How do i store it? It=C2=B4s an rdf model.=
>>> your asking how to store the model or how to store the palette? or =
>>> both?
>> I convert the gef-palette to an RDFModel object which i can read/writ=
e =
>> to a file.
>>>> As far as i understand you normally add string properties to a =
>>>> property page.
>>>> It also makes not much sense ATM do be able to edit it in either a =
>>>> property or preferences page. (Or i=C2=B4d have to put the whole =
>>> I had properties before I ever made my property editor page. Gotta =
>>> start somewhere.
>> I just added the example extension PropertyPage and looked at it a bi=
t.
>> As far as i see it without the property page i would do something lik=
e =
>> this,
>>>> So at the moment I just want to store the rdf model or file =
>>>> somewhere along with the resource, and be able to load it on =
>>>> startup (from Editor.java) and get/set it from the customizer=C2=B4=
s =
>>> again, im getting mixed up. The rdf is the model, or the palette or=
>> I convert the palette to an rdf-model-object(from jena). So that is =
>> what i want to store.
>> (I want to be able to export it later and can already read in palette=
s =
>> from rdf files.)
| Re: where to store customized palette? [message #158923 is a reply to message #158915] |
Sat, 20 November 2004 11:13  |
We agree on model, and view as well. But palette, and tool I am not
understanding. a palette is just a set of tools, but yours is more than
that?
Each different file you open (which is an rdf-file) will open a palette
as well. And that palette is setup to match the schema type of that
particular rdf-file?
If this is correct then you can either store data in your file which
will tell your editor which palette to associate with it, or you can
store meta-data on your file in the IFile which represents your file in
the workspace, and use that meta-data to tell your editor which palette
to open, or how to populate it.
For instance, when you open a project, it has natures attached to it
that tell eclipse what tools should be associated with it among other
things.
> GenericConnection,
> parameters to the Generic model´s contructors.
> also have to store parameters to pass to the generic model that they
> create.
> of parameters to store.
>> model. When we say palette here we mean a set of tools that are
>> displayed in a specific view. Such as, line draw tool, selection
>> tool, text tool, etc. When these are all put together in a sort of
>> tool bar, we call it a pallette.
>>>>>> Preferences store =
>>>>>> yourPlugin.getDefault().getPluginPreferences(); //a static
>>>>>> method of grabbing your plugin, then getting the preferences
>>>>>> from it
>>>> model?
>>>> both?
>>> read/write to a file.
>>>>> property page.
>>>>> a property or preferences page. (Or i´d have to put the whole
>>>> Gotta start somewhere.
>>> like this,
>>>> or is this the same thing? or is the resource the model?
>>> palettes from rdf files.)
Respectfully,
CL Gilbert
and a robber."
Current Time: Sun Nov 16 20:34:18 EST 2025
Powered by FUDForum. Page generated in 0.29379 seconds
