Home » Modeling » GMF (Graphical Modeling Framework) » Custom, non-XML serialization
Custom, non-XML serialization [message #158233] |
Sun, 04 November 2007 12:52  |
Hi everyone,
I need to export the content of a user-created diagram to a file format very
different from the standard EMF XMI. This exported file needs information
from the domain model, the diagram model, and some external file-based data.
I would like to get some pointers on the best (i.e., easy and future-proof)
strategy. So far I figured out the following three alternatives:
* Manual parsing of the GMF-created xml files
This is problematic, because the standard path descriptions in these files
are not interpretable without knowledge of the domain model. A solution here
would be to customise the generation of paths.
* JET
This looks promising, but I have no clue how to use JET from within the GMF
program. I saw that the GMF-created code has an
"org.eclipse.emf.ecore.extension_parser" extension point, so I assume that
JET is already used within GMF to generate the domain model file? But then
where are the JET templates? And how can I plug in my own?
* From the object model
I could also load the Resource and use the EMF API to traverse the object
hierarchy and write the information into a file.
Which one is the best? And how would I get started?
Thanks a lot,
a>
Re: Custom, non-XML serialization [message #158240 is a reply to message #158233] |
Sun, 04 November 2007 13:08   |
André,
This isn't really so much a GMF question. GMF does support storing the
diagram description and the model data itself in separate files. Is
your external file based data an XML file? Is there an XML Schema which
describes it? If so, you could generate your model from that schema
and EMF will automatically be able to read and write it. If not, you
could specialize ResourceImpl.doLoad and doSave to read and write
exactly the format you want; of course you'll have to do all the parsing
and printing yourself. I don't think JET will help at all for this
particular problem. If you look at
https://bugs.eclipse.org/bugs/show_bug.cgi?id=206267 you'll see how I
created a prototype resource implementation that read and writes a
binary serialization rather than an XML/XMI one effectively just by
hooking into the doLoad and doSave methods.
A good answer depends quite a bit on what your file format it so you
might want to describe that a little more...
André Knörig wrote:
> Hi everyone,
> format very different from the standard EMF XMI. This exported file
> needs information from the domain model, the diagram model, and some
> future-proof) strategy. So far I figured out the following three
> alternatives:
> files are not interpretable without knowledge of the domain model. A
> solution here would be to customise the generation of paths.
> * JET
> the GMF program. I saw that the GMF-created code has an
> that JET is already used within GMF to generate the domain model file?
> But then where are the JET templates? And how can I plug in my own?
> object hierarchy and write the information into a file.
> Thanks a lot,
> a>
Re: Custom, non-XML serialization [message #158305 is a reply to message #158240] |
Mon, 05 November 2007 08:46   |
Hi Ed,
thanks for the quick response. The external data is a proprietary text
format that I am parsing manually. I had a look at the ResourceImpl you
supplied, but that's currently way beyond my level of understanding. ;)
So I am now approaching this by "simply" loading the model, traversing
it, and grabbing the correspoding data from the diagram and the external
file.
This leads to a new problem: I would like to parse the model and pull
some layout information corresponding to a node from the diagram. The
only way I have found so far to do this, is to use
viewer.findEditPartsForElement(elementIdStr, editPartClass). However,
not all of my elements have an id.
There must be a simpler way to do this, I assume?
Cheers!
Ed Merks schrieb:
> André,
> André Knörig wrote:
>> Hi everyone,
>> alternatives:
>> * JET
>> Thanks a lot,
>> a>
Re: Custom, non-XML serialization [message #158344 is a reply to message #158305] |
Mon, 05 November 2007 09:26   |
André,
It really sounds to me like it would be best to design a ResourceImpl
that overrides doLoad and doSave to read and write your format. You
don't need all that crap that's in the binary resource impl, the point
of that was just to show how the doLoad and doSave hooks are used. You
effectively must be doing this loading and saving already, but somehow
it sounds like you are doing it in a more complex way. If you set that
up properly, the diagrams will be able to reference things in your
model's resource using standard EMF fragment paths. I'm not sure
exactly what's needed for the API you mention, but it might be the case
that for an EObject x, x.eResource().getURIFragment(x) is all that you need.
André Knörig wrote:
> Hi Ed,
> you supplied, but that's currently way beyond my level of
> understanding. ;)
> external file.
> Cheers!
> Ed Merks schrieb:
>> André,
>> the diagram description and the model data itself in separate files.
>> Is your external file based data an XML file? Is there an XML Schema
>> which describes it? If so, you could generate your model from that
>> schema and EMF will automatically be able to read and write it. If
>> not, you could specialize ResourceImpl.doLoad and doSave to read and
>> write exactly the format you want; of course you'll have to do all
>> the parsing and printing yourself. I don't think JET will help at
>> all for this particular problem. If you look at
>> André Knörig wrote:
>>> Hi everyone,
>>> alternatives:
>>> * JET
>>> assume that JET is already used within GMF to generate the domain
>>> model file? But then where are the JET templates? And how can I plug
>>> in my own?
>>> Thanks a lot,
>>> a>
Re: Custom, non-XML serialization [message #158401 is a reply to message #158344] |
Mon, 05 November 2007 13:30  |
Ed,
okay, maybe I was too timid. The ResourceImpl is obviously a good way to
place this.
The API call that you suggested works, too, but I still do not know how
I can get the layout/notation information for a semantic element. I
guess it's due to the MVC structure that it's easier the other way
around, but there should be some utility to do it this way, too?
Ed Merks schrieb:
> André,
> need.
> André Knörig wrote:
>> Hi Ed,
>> understanding. ;)
>> external file.
>> Cheers!
>> Ed Merks schrieb:
>>> André,
>>> André Knörig wrote:
>>>> Hi everyone,
>>>> alternatives:
>>>> * JET
>>>> in my own?
>>>> Thanks a lot,
>>>> a>
Current Time: Tue Jul 22 15:39:42 EDT 2025
Powered by FUDForum. Page generated in 0.04495 seconds
