Confused about Standard Make and Managed Make projects and make stuff in general. [message #158048] |
Tue, 15 November 2005 16:37  |
Originally posted by: me2.nowhere.com
I am confused about what specifically Eclipse does with the Standard
Make and Managed Make projects when I do builds and runs.
Lets say I've got a test project with a makefile:
test.o: test.c
gcc test.c -o test.o
clean:
rm test.o
Now, what happens when I press "build" in a "Standard Make" project.
What happens in the "Managed Make" project ?
In the managed make project there are settings for gcc, command line
options, etc. How are those options utilized ? Do I/should I be
replacing "gcc test.c -o test.o" with CC, CFLAGS, etc.
Next question...
I've got a C project that has a hierarchy of smaller projects in
subdirectories. Right now I only want to build and test a subproject,
yet I want to be working in the main project because in a bit I'll need
to build a project that uses my project.
How do I configure the Working Set for the Build to use a different
makefile or does it just use the makefile from the directory I select
when setting up the Working Set ?
Thanks in advance.
Re: Confused about Standard Make and Managed Make projects and make stuff in gen [message #158073 is a reply to message #158048] |
Tue, 15 November 2005 22:02  |
Originally posted by: bjcbell.gmail.com
To answer your first question,
To use a makfile that you have written you must use standard make.
Managed make will write a makefile for you based on the settings you have
selected in C/C++ Build options and which files you have included/excluded
from your build.
I personally don't use subprojects so I don't know how to answer your
second question. Sorry about that.
> test.o: test.c
> clean:
> rm test.o
> Next question...
> Thanks in advance.
FUDForum. Page generated in 0.03930 seconds
