Home » Language IDEs » C / C++ IDE (CDT) » Using <F2> to go to function implementation on CDT 3.0.1
Using <F2> to go to function implementation on CDT 3.0.1 [message #158025] Mon, 14 November 2005 20:54 Go to next message
We have been using CDT 3.0.0 for some time, and happy in using the <F2> key
to go to a functions implementation (as opposed to "<CTRL> + click" on a
function, which only goes to the functions declaration in a header file).
Upon doing an update to CDT 3.0.1, pressing <F2> while highlighting a
function no longer appears to be working. Is there a new configuration
option that we have missed? Or is this a known issue that is not supported /
broken in CDT 3.0.1?
Many thanks for any advice / assistance in this.
Andrew McGhee
Re: Using <F2> to go to function implementation on CDT 3.0.1 [message #158502 is a reply to message #158025] Fri, 18 November 2005 19:32 Go to previous messageGo to next message
Originally posted by: m.fortner.sbcglobal.net
I was curious about that myself and found out that they switched it to
Ctrl+F3. I'm not sure why they did that; it's still not consistent with
the JDT, and it's actually requires a longer reach on the keyboard to
perform.
Mark Fortner
Andrew McGhee wrote:
> Hello,
> Andrew McGhee
Re: Using <F2> to go to function implementation on CDT 3.0.1 [message #158548 is a reply to message #158502] Sun, 20 November 2005 23:38 Go to previous messageGo to next message
Thanks Mark - that helped us a great deal, and also helped us to look into
finding where the key mappings are.
For reference for others, to change the key binding for "Open Definition"
from CTRL+F3 to some other key:
1. Go to menu "Window" -> "Preferences" -> "General" -> "Keys"
2. Look for "C/C++ Source Open Definition" and change the key mapping from
"CTRL+F3" to "F2" (it doesn't appear to conflict with anything).
3. Delete the old binding for "CTRL+F3" (if desired).
I suspect there must have been a good reason to change the keymapping to
CTRL+F3 in the first place, but I agree with you, I'm not sure why the
change.
"Mark Fortner" <m.fortner@sbcglobal.net> wrote in message
news:dllrs7$a7$1@news.eclipse.org...
> perform.
> Mark Fortner
> > Hello,
key
file).
supported /
> > Andrew McGhee
Re: Using <F2> to go to function implementation on CDT 3.0.1 [message #158637 is a reply to message #158548] Mon, 21 November 2005 15:08 Go to previous message
Andrew,
Thanks for the info about the key mappings. I was wondering where to
change that. There are a few other mappings that I wanted to change as
well. I'm not sure if there's a silo effect going on between the
Eclipse project team but everyone seems to define their own inconsistent
key mappings. Ctrl-O in the JDT for example optimizes imports, and in
the CDT it pulls up the outliner.
Mark
> change.
>>perform.
>>Regards,
>>Mark Fortner
>>>Hello,
> key
> file).
> supported /
>>>Andrew McGhee
Previous Topic:no build with CPP(uppercase)
Next Topic:Third party comparision tool
Current Time: Mon Jul 14 11:29:39 EDT 2025
Powered by FUDForum. Page generated in 0.06947 seconds
