trouble running 3.0M4 on Solaris [message #157971] |
Mon, 17 November 2003 16:52  |
I can't seem to run Eclipse 3.0M4 on Solaris. I have tried with both the SDK
and the platform runtime, and I get the same result either way. I see the
'completing install' screen and the the splash screen and then I get an
error. Eclipse never comes up. Anybody have any idea what's going on?
uname -a: SunOS ulna 5.8 Generic_108528-23 sun4u sparc SUNW,Sun-Blade-100
cmdline:
cd /public/SunSoftware/eclipse/3.0M4/eclipse
./eclipse -data ~/eclipse/workspaces/blah
result:
java.lang.UnsatisfiedLinkError:
/public/SunSoftware/eclipse/3.0M4/eclipse/plugins/org.eclips e.swt.motif_3.0.
0/os/solaris/sparc/libswt-motif-3024.so: ld.so.1: /usr/bin/java: fatal:
libXp.so.1: open failed: No such file or directory
at java.lang.ClassLoader$NativeLibrary.load(Native Method)
at java.lang.ClassLoader.loadLibrary0(ClassLoader.java:1560)
at java.lang.ClassLoader.loadLibrary(ClassLoader.java:1469)
at java.lang.Runtime.loadLibrary0(Runtime.java:788)
at java.lang.System.loadLibrary(System.java:834)
at org.eclipse.swt.internal.Library.loadLibrary(Library.java:10 0)
at org.eclipse.swt.internal.motif.OS.<clinit>(OS.java:20)
at org.eclipse.swt.widgets.Display.createDisplay(Display.java:6 14)
at org.eclipse.swt.widgets.Display.create(Display.java:600)
at org.eclipse.swt.graphics.Device.<init>(Device.java:126)
at org.eclipse.swt.widgets.Display.<init>(Display.java:350)
at org.eclipse.swt.widgets.Display.<init>(Display.java:347)
at org.eclipse.ui.internal.Workbench.run(Workbench.java:2300)
org.eclipse.core.internal.boot.InternalBootLoader.run(Intern alBootLoader.jav
a:858)
at org.eclipse.core.boot.BootLoader.run(BootLoader.java:461)
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl
..java:25)
at org.eclipse.core.launcher.Main.basicRun(Main.java:299)
at org.eclipse.core.launcher.Main.run(Main.java:765)
at org.eclipse.core.launcher.Main.main(Main.java:599)
Patrick Baker
Stilo Corporation
pbaker@ca.stilo.com
"Hail, twin companionship, children of Mars."
This message, including any attachments, is for the sole use of the
intended recipient(s) and may contain confidential and privileged
information. Any unauthorized review, use, disclosure, copying, or
distribution is strictly prohibited. If you are not the intended
recipient(s) please contact the sender by reply email and destroy
all copies of the original message and any attachments.
Re: trouble running 3.0M4 on Solaris [message #159838 is a reply to message #157971] |
Thu, 20 November 2003 20:14  |
This problem is fixed, you need to get a more recent Eclipse 3.0 release.
See https://bugs.eclipse.org/bugs/show_bug.cgi?id=43811 .
Grant
Patrick Baker wrote:
> cmdline:
> result:
> at
> a:858)
> at
> at
> ..java:25)
FUDForum. Page generated in 0.03650 seconds
