Home » Language IDEs » Java Development Tools (JDT) » Identifying Memory leaks
Identifying Memory leaks [message #157929] Sun, 09 May 2004 11:23
Originally posted by: tajsingh.hotmail.com
I have done some java development using the Jface environment in Eclipse
and had a question on memory leaks/consumption.
Basically, I have a server and client, with a proxy class in between. I am
stress testing by bombarding the server with lots of requests from many
clients. Now, my question is, Is there a way(plugin or something) for
eclipse that I can use with the java development to identify memory
usage/leaks???
I know there is a function if I was running java program in Sun
Environment.But, at present I am using eclipse in a WinXP env.
I would be grateful for any suggestions/examples.
Taj
Previous Topic:Compiler error for source using 'assert'
Next Topic:I/O Exception when refactor/rename packages
Current Time: Thu Jul 24 15:45:19 EDT 2025
Powered by FUDForum. Page generated in 0.03199 seconds
