Home » Eclipse Projects » Subversive » Tip moving from Subclipse to Subversive w/out disconnecting team provider before change
Tip moving from Subclipse to Subversive w/out disconnecting team provider before change [message #14796] Fri, 21 March 2008 11:08
Originally posted by: eddie.streambase.com
Hello everyone,
I wanted to share something; perhaps the subversive wiki/eclipse.org
pages wish to have this info too...
I had many workspaces that were being shared with Subclipse before,
and so I couldn't really go to each workspace and Team>Disconnect with
subclipse before upgrading to subversive.
I uninstalled subclipse, and installed subversive, and then found that
the workspaces that had subclipse shared projects were not letting me do
either Team>Disconnect, nor re-share.
As I started writing a plug-in to be able to team>disconnect regardless
of the provider (very simple plug-in too), I discovered something --
Subversive is actually capable of re-connecting and fixing the old team
provider connection by doing something very simple:
Close and re-open each project (You can also do the same if you just
re-import into a new workspace each project).
Hope this helps,
- Eddie
Previous Topic:"User Credentials" dialog
Next Topic:Subclipse vs. Subversive
Current Time: Mon Jul 14 02:05:33 EDT 2025
Powered by FUDForum. Page generated in 0.04374 seconds
