Home » Modeling » GMF (Graphical Modeling Framework) » Display connections in outline TreeView
Display connections in outline TreeView [message #157864] Wed, 31 October 2007 05:13
Originally posted by: Christoph.Klauss.web.de
Hi all!
we are implementing an GMF based editor with Nodes and Connections.
In the metamodel there are in the toplevel element 2 EReference
(containment:true, 0...*) for the Nodes and one for the Connections.
The editor works fine. We can draw nodes and link them via connections.
The problem is:
In the outline view only the node elements are displayed BUT not the
connections.
We want to have both.
We already found in the newsgroups
http://dev.eclipse.org/newslists/news.eclipse.modeling.gmf/m sg00354.html
that we have to check DiagramOutlinePage , and TreeContainerEditPart.
Unfortunately we can't find those.
Also we don't know which methods to overwrite etc.
A code example would be very helpful!
Thanks a lot in advance!
Christoph
Previous Topic:property sheet attributes customization
Next Topic:How to control/tweak the distance between a connection and its label?
Current Time: Sun Nov 23 01:06:41 EST 2025
Powered by FUDForum. Page generated in 0.04899 seconds
