| Integrating Birt into RCP [message #157785] |
Tue, 02 May 2006 10:25  |
Hi everybody,
I am prospecting BIRT for reporting.
Here is my question: I built an app based on RCP, which basically run
analysis and save them into XML files. I would like to know whether it is
possible to intgrate BIRT in such way, that i press a button and it
generate a PDF report from an input XML file, according to a predefinite
design.
I am not using database.
I tried a bit the designer to connect some XML files and so on, but is it
possible to do the connection inside RCP, and then build the report, and
where do I have to check tutorials/snippets?
Thanks a lot for any answer
Gersh
| Re: Integrating Birt into RCP [message #157845 is a reply to message #157785] |
Tue, 02 May 2006 13:57   |
------=_NextPart_000_0050_01C66DF0.68511240
Content-Type: multipart/alternative;
boundary="----=_NextPart_001_0051_01C66DF0.68511240"
------=_NextPart_001_0051_01C66DF0.68511240
Content-Type: text/plain;
charset="iso-8859-15"
If you have predefined the report and just want to run and display it =
this is very simple
Previous post
You can include the BIRT plugins and
call the following lines of code on an action
System.setProperty( "RUN_UNDER_ECLIPSE", "true" );
DtpManifestExplorer.getInstance( ).getExtensionManifests( );
WebViewer.display(reportName , WebViewer.HTML, browser);
Where browser is SWT browser or
WebViewer.display(reportname, WebViewer.HTML,false);
to display in standard browser window.
Attached is an example of using BIRT in a simple RCP applicaiton.
Jason"Gersh" <gershwinou@gmail.com> wrote in message =
news:444b0dc02f5c96b8c09c01131a6df601$1@www.eclipse.org...
> Hi everybody,
>=20
> Here is my question: I built an app based on RCP, which basically run=20
> analysis and save them into XML files. I would like to know whether it =
is=20
> possible to intgrate BIRT in such way, that i press a button and it=20
> generate a PDF report from an input XML file, according to a =
predefinite=20
> design.
>=20
> I tried a bit the designer to connect some XML files and so on, but is =
it=20
> possible to do the connection inside RCP, and then build the report, =
and=20
> where do I have to check tutorials/snippets?=20
>=20
>=20
> Gersh
Content-Type: text/html;
<HTML><HEAD>
charset=3Diso-8859-15">
<META content=3D"MSHTML 6.00.2900.2802" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY>
<DIV>
<P><FONT face=3DArial size=3D2>If you have predefined the report and =
just want to=20
run and display it this is very simple</FONT></P>
<P><FONT face=3DArial size=3D2>Previous post</FONT></P>
<P><FONT face=3DArial size=3D2>+++++++++++++</FONT></P><PRE =
wrap=3D""><FONT face=3DArial size=3D2>You can include the BIRT plugins =
and
Jason</FONT></PRE></DIV>
<DIV><FONT face=3DArial size=3D2>"Gersh" <</FONT><A=20
href=3D"mailto:gershwinou@gmail.com"><FONT face=3DArial=20
size=3D2>gershwinou@gmail.com</FONT></A><FONT face=3DArial size=3D2>> =
wrote in=20
message </FONT><A=20
href=3D"news:444b0dc02f5c96b8c09c01131a6df601$1@www.eclipse.org"><FONT =
face=3DArial=20
size=3D2>news:444b0dc02f5c96b8c09c01131a6df601$1@www.eclipse.org</FONT></=
A><FONT=20
face=3DArial size=3D2>...</FONT></DIV><FONT face=3DArial size=3D2>> =
Hi=20
everybody,<BR>> <BR>> I am prospecting BIRT for reporting.<BR>> =
Here is=20
my question: I built an app based on RCP, which basically run <BR>> =
analysis=20
and save them into XML files. I would like to know whether it is =
<BR>>=20
possible to intgrate BIRT in such way, that i press a button and it =
<BR>>=20
generate a PDF report from an input XML file, according to a predefinite =
<BR>> design.<BR>> I am not using database.<BR>> <BR>> I =
tried a bit=20
the designer to connect some XML files and so on, but is it <BR>> =
possible to=20
do the connection inside RCP, and then build the report, and <BR>> =
where do I=20
have to check tutorials/snippets? <BR>> <BR>> Thanks a lot for any =
answer<BR>> <BR>> Gersh<BR>></FONT></BODY></HTML>
------=_NextPart_001_0051_01C66DF0.68511240--
Content-Type: application/octet-stream;
name="org.eclipse.birt.rcp.viewer.zip"
Content-Disposition: attachment;
filename="org.eclipse.birt.rcp.viewer.zip"
UEsDBAoAAAAAAKp7cDQAAAAAAAAAAAAAAAAcAAAAb3JnLmVjbGlwc2UuYmly dC5yY3Audmlld2Vy
L1BLAwQUAAAACACpe3A0DI1YXLMAAABTAQAAJgAAAG9yZy5lY2xpcHNlLmJp cnQucmNwLnZpZXdl
ci8uY2xhc3NwYXRorZDNCsIwEITPCr5Dyd2oNw+tIqKgB5VSz1KTpY3GTdwk om9v/SkV9OhtZ/lm
2Nl4fD3p6ALklMGEDXifRYDCSIVFwrbZvDtk41GnHQudO2dzX1ai1ShAT7fo qFAmzJFg0WP5Gnu/
SLhaQx4q2lMA9nYKg7XTUMFBaGUd8IP0XOcBRVldw5fpbDddr7LJYjVL/5Bu JXBhCDjBOSgCudGh
UOia6O+KJngbfJ22V/iE497nd+5QSwMEFAAAAAgAqXtwNHZjWZTrAAAAsAIA ACQAAABvcmcuZWNs
aXBzZS5iaXJ0LnJjcC52aWV3ZXIvLnByb2plY3S9ks1OAyEUhdea+A7N7IW6 c0GniZruNCbVB6Bw
HW8z/OTCTPv4AqE6TZvGhXE19xzO4SMwYrk3/WwECujsorlj82YGVjmNtls0 72+r2/tm2d5cC09u
Cyo+QVCEPqZ0cq+ElQZaRx0D1aMPwDZIkZHybETYAQmeEyWqnDFgYyt4nbJ7 2DcUwY/UZsBerz2o
rKp8TFVpdXHO0Lc6MuUoDXKUpXA4Qm1I6obMDlXzqZH1lPJ7rtfAnqXFDwjx 4X+xa/UJRv4JNDs/
V555cSAo6SpO8a/90KF9KYuJXr6TwoXnsSedNH8TBT/7x30BUEsDBAoAAAAA AKl7cDQAAAAAAAAA
AAAAAAAgAAAAb3JnLmVjbGlwc2UuYmlydC5yY3Audmlld2VyL2Jpbi9QSwME CgAAAAAAqXtwNAAA
AAAAAAAAAAAAACQAAABvcmcuZWNsaXBzZS5iaXJ0LnJjcC52aWV3ZXIvYmlu L29yZy9QSwMECgAA
AAAAqXtwNAAAAAAAAAAAAAAAACwAAABvcmcuZWNsaXBzZS5iaXJ0LnJjcC52 aWV3ZXIvYmluL29y
Zy9lY2xpcHNlL1BLAwQKAAAAAACpe3A0AAAAAAAAAAAAAAAAMQAAAG9yZy5l Y2xpcHNlLmJpcnQu
cmNwLnZpZXdlci9iaW4vb3JnL2VjbGlwc2UvYmlydC9QSwMECgAAAAAAqXtw NAAAAAAAAAAAAAAA
ADUAAABvcmcuZWNsaXBzZS5iaXJ0LnJjcC52aWV3ZXIvYmluL29yZy9lY2xp cHNlL2JpcnQvcmNw
L1BLAwQKAAAAAACqe3A0AAAAAAAAAAAAAAAAPAAAAG9yZy5lY2xpcHNlLmJp cnQucmNwLnZpZXdl
ci9iaW4vb3JnL2VjbGlwc2UvYmlydC9yY3Avdmlld2VyL1BLAwQUAAAACACp e3A00WCIsHcCAAB+
BAAATQAAAG9yZy5lY2xpcHNlLmJpcnQucmNwLnZpZXdlci9iaW4vb3JnL2Vj bGlwc2UvYmlydC9y
Y3Avdmlld2VyL0FwcGxpY2F0aW9uLmNsYXNzjVJNUxNBEH1DNllZw4dBlAgI iEISkPELLYlFVUqx
KmUUDRH1ZG02YxhcdlOzu6D/xiPelINQWqV3f5RlzwYkwgEu3T09r7tfz7zf f77/BDCHuwzTvmpy
4biyFQhelyrkymnxTSm2hOKlVsuVjh1K3zPBGPrX7U2bu7bX5Mv1deGEJhIM hc4Wjq8EV5EXyg3B
y89dO3znq41q5Hl23RUmkgypB9KT4SJDIpdfZTAe+g2RhokzFgxYDH0V6Yln 0UZdqJouYshUfMd2
V20l9Xk/aYRrMmDIV065QZEGEjGGqVzl6B7F/LEUwa2lD45o6VqaM3AI+Jc2 McCQ7ZwfSX6w88uy
iUGGHkcJOxSPZNBy7Y8Mk7n/GQdbId+SjaYIA74PKqZxEUMWLiDLcO+U673y 1fu68Jy1UmNTBr4y
MWxhRL/nYJtByWtUo0MYw4vciUQqR3azD+fxowOL+XIalzGmeY8zpJdel2tv q0srtVK1Rs/X8cBl
LxRNoWjNK5jsRgpXGcwYvvwkjal2bpph7AR6JvJU2KCDH5CCZrSCCpgladiq SV+WOf6pGn/wExMn
rk8SUCKMlKclysDKlFjxI+WIx1JLsL/j/ef0LEygi0TMiD8oYlrVZLvpxMkz 8snCLs5+ja/TZFNx
0kIP2XQbgF70kaf2OEeoDMW65fm4zS4SMMkX93Dp6ewPjLzZxegeJhZHjU/o 3cG1hdQ2stnUlx3k
dNhL4UJyG6ls8teCMfsN1z8bMcdRzFCbceTIH5ApwCLbT7cZsgMYpKHj9J0z pMcbyOI2+XkM4T7F
PTHe0FTahONoTu9J2XuEv4ku6jKMW1SXoOydeM78X1BLAwQUAAAACACpe3A0 1B/ct4oDAABBCAAA
XQAAAG9yZy5lY2xpcHNlLmJpcnQucmNwLnZpZXdlci9iaW4vb3JnL2VjbGlw c2UvYmlydC9yY3Av
dmlld2VyL0FwcGxpY2F0aW9uQWN0aW9uQmFyQWR2aXNvci5jbGFzc51UbVca RxR+Bl+AlTYJbdL0
LTGGCIKysdUaY2oCJkYS0FjfavppWEacuO5yhkXbn9WeVk/qOf0B/VE9vTNL kNYjoT0cZu/cufc+
z32Z+fOv3/8AkMcPDHO+qtvCcWWjKeyqVIGtnIZ9JMWxUHah0XClwwPpewVH r0WuCrUj2fRVFIwh
1+3ckjY/t7cvOgwwWOJHGYQnBF3+t7s5aLZdl2nrq59SpR1fHVSF5+yH+gWG EV71W504w4+kJ4NF
hplMuQehUofRku/tyXpLCbUwsc0wuOTXRAIxxC0MYoThSll6YrV1WBVqk1dd wZAs+w53t7mSet9W
Dgb7sskwX/6fJaRELKdDhWH6P7OnShzyAxEeEZXUhQKcF29HejX/2CSc6qfu UVynFNe3SpsM4311
aiGBT3Azjhv4lJriKMEDqtLrPjj1Ff7CIBDe5/jCIrwvExjCcBwR3GaIKVGX zUBX9N4/sd/scUeY
4OcFpYIkcAdjFjnfZRgqFNe2NhO4FyYynkA0DJyhlI4NXYY7782IGrMnXbci vFaRE5FsLyLaqsI9
Xm/PY+pS0y7LKPLEdnxZuiKG+9SpPSN9xZDOlN/wI2673KvbG4GSXn3hgsak HcOMBRuzOtCKcBsx
zFGgfSPNU/X6ohwFZTvAazUGu1eWNLaEXG3pXSkQh4bBt1gcwSM87pX0c+W3 GhWuDjRWgSFOWNLM
RwxLDNczlyX3zEIRywxjl4beEA2ueKAfpxVKIhP6vbBQwktdmcea4ZiWVhmi h++6me6zmTSLuita
pe9QP23VProBWtUeoiXfdw3sVK/ytq265yjqvPPM9u9Ib9KG31KO0JPFMNrj /crrutPdidCrCVoj
+hIaKaq/pGX6UaXVot2itqDvcDZ3isTPxu4DWi2jvUu+KXxI0o3QCldwlb5a uoYkGEX7CB+3Yx1g
wFils7/gs9wJbv2G0Wz2V4yeIEWqdKia0KoJUrXBTPAhWqcwgjyFu49bmMY4 ZrqA0yGwkbLIGeBJ
8giB39JOJ7t+Bns3OZ38+hTfVIz8IPmQ5NXc5Fs8iSB3huJu8ukpnofbKfOZ PENp9xTlE1QmQ7Zr
UyHFtQ5FohOndQ4JPMBNPMRtuh95GsNZPKFfASt4ild4ZihnQzIdyut0sk5U E3T+HTYQoQjz2CRp
gCy3sN1OY1aj0Z+dww6D0VruqgQLwxppB9+D0W/X2L/+G1BLAwQUAAAACACp e3A0DTIBidcBAAAU
BAAAXQAAAG9yZy5lY2xpcHNlLmJpcnQucmNwLnZpZXdlci9iaW4vb3JnL2Vj bGlwc2UvYmlydC9y
Y3Avdmlld2VyL0FwcGxpY2F0aW9uV29ya2JlbmNoQWR2aXNvci5jbGFzc51T 227TQBA9G6dpY3oN
bbi1UJ6aUOF9RFCKVIUgWbJQRCpXfUIbZ3EXjG2t7fS34KkSSHwAH4UYX5RU AVWQl5nduZw5OzP7
89e3HwAs7DM8i7TPpReoOJF8pHTKtRfziZKXUvOTOA6UJ1IVhWeR/jSSoXdx Mp6oJNLLYAyH15Mz
xcUsnv+ZYDCsD/rvhoN+79R2++/t1wwt56OYCB6I0OfDVKvQP2JY60Vhkoow dUWQSYYDKmNVZayc
o0UcrZKjFUudxNJL1USuYIWh8VKFKn3FYHS6LkO9F43lKkzcMlHHGsOGo0L5 Nvs8kvpUjAKZc4g8
EbhCq/xeGevphUoYnjsL9oeesetpKVI59ZypcBxdVn6GoOPc0D57Lo1a8kH5 mZb6qOv8S9vLtBmb
4/99SAkwnd4Ow4uFGbv5BO6YaOMug+lNPbR/C0Iy7PkytWnUSgSldzDbBHvM sN3p/m25zGGUaU++
UfmU92+YoJUn4zFqqNNnYbiPJTRIL9OthiYMOtNakVwlCyfNSC89ucL61yJk g2QjN1LAZi7LAGyh
VQDexnaVfExgNdLN72ifH17h3pc5gK0CoF0GlQD5iTg9KOruYq+CelrxMFrN eZCdayyMKYuHRdSj
31BLAwQUAAAACACpe3A0lXDV1ksCAACABQAAYwAAAG9yZy5lY2xpcHNlLmJp cnQucmNwLnZpZXdl
ci9iaW4vb3JnL2VjbGlwc2UvYmlydC9yY3Avdmlld2VyL0FwcGxpY2F0aW9u V29ya2JlbmNoV2lu
ZG93QWR2aXNvci5jbGFzc6WT624SQRTH/8NVtqUtvWC9FdsqbEFZazSN1tbU JiYkRE0w1PrJZRlh
LO5uZpeS+BQ+in6xqU18AB/KeIalCzERFXeTMzuz5/zOnNv3H1+/ASjjLsOO I1sGtzrC9bjRENI3
pOUax4L3uDT2XLcjLNMXjn3gyKMGt632gbCbTm+veSw8RybBGDZHEV1hmEMr 43dmUYbEI2ELf5fh
oV4dQ6j8gth37Lei1ZVcbm/UGWL7TpNPI46EhhguMMxWhc2fdd83uHxpNjqc Yb7qWGanbkqh9oPD
mN8WHsPj6n/Fv82gWeGFGLYmjIQha0lu+nzPUqpPTBk4IOSb8dkJDUbzMs4i NBiGsPWXOQhNwzLO
M9yb4H51VbBFDQtYovb5Z3uGtCt5kMTnLrcZorrqhYUW989TO6zJA31jwqpM 4zKuaIjgKsPKKMLr
+UZLmm5bWJ7xwhG2n8QKQ1yvVILYrmvIYZXh/kSOk1hnmPG4X6EBEWanJj5Q x67r1fF36Of1JvJT
uIFCAKi1FdfpUP6o5fXXSmMDRaVRYsgMNGq+6Xc9NTfTuB38LVNj15yutPhT ocYl/8dRKL8zj02s
UrZiUE8UTE0lySTtduk8QmuiWDpB6jNAO42k1j9VKUtjir6ygRadpGlVXzOY BaN3DpkBa4fYSit1
hoVDwmU/neOUO5JzI6hUiEoR6mIftYxLA9QROVZaheIXXKuWzpA7zEReZdjH E6ydQo+gFD3FrWAx
Ihjcuw+Pk1wkuYRl2uUInSfs0HEhcEwaa2EMd/r2mz8BUEsDBBQAAAAIAKl7 cDTteNyreQEAAM8C
AABSAAAAb3JnLmVjbGlwc2UuYmlydC5yY3Audmlld2VyL2Jpbi9vcmcvZWNs aXBzZS9iaXJ0L3Jj
cC92aWV3ZXIvTmF2aWdhdGlvblZpZXckMS5jbGFzc5VRTU8CMRB9RRTBVRAV v28YAQ3Vg4mJxgvR
xGTFA4R7WSuULLtkt4D+LA/GxIM/wB9lnFYS9WKkSTszrzNvvt4/Xt8AVLHL cBhGHS49Xw1iydsq
0jzyBnyk5FhGvC5GqiO0CoMWAcXjFBhDridGgvsi6PDbdk96OoUZhr2fPPFY czmSgY75TXin7h9d
FWsZyCiFWYY53VVx8Yhyu/9PfsaQbjwGuiu18ojjXAVKXzDw0jQk5RZDshbe SYaZUrnlIIPFDJJY
cpDCfBoJ5Biyrgpkfdhvy6gp2j755t3QE35LRMrYEzBp2mCoTpG/eExtZPp2 JE35oBn2S+6fg7s0
hi2bUcrif5wpQyMcRp68UqbMld8lVM32GJzrgNZR80UcyxhH1HgSNFW6OTMJ kmmYk6CbwQLZDmmn
ZFuk8oJs5eAZy0/WJ28w+1O3PCukOSQNuoo1kgwFrE9YTia87Dt4zjo3bGDh 6/Mr0Gob2KQ3gS3r
v40dQ2wRc/KfUEsDBBQAAAAIAKl7cDSPWAtA8wIAADMGAABSAAAAb3JnLmVj bGlwc2UuYmlydC5y
Y3Audmlld2VyL2Jpbi9vcmcvZWNsaXBzZS9iaXJ0L3JjcC92aWV3ZXIvTmF2 aWdhdGlvblZpZXck
Mi5jbGFzc5VU61LTQBT+FoKlJdzKTRQvYIW0lAYRFQFR5KJoAGcKnUH/mKZr GwxpJ1kuvozv4IwW
R0d/8sM38GUcz6YVEEEgM+3uOfvlO985e05+/PryHUAKywzJopfXueXYJZ/r WdsTumeV9C2bb3NP
XzK37Lwp7KKbIUdsJATGMHD4DX9b6HyLu8LX09zhlsRO58yS4F4ItQwXRMH2 Y8MUxzh7oAmGcPqd
Kwpc2BZxTNquLaYYdO08JPEMgzJTzHGGWi2eUVGPhggUqCrqcCGMGjQxNBu2 y5c2N7LcWzGzDmGj
RtEynYzp2dKuOhWZBkPqHPFjI5RG07ady3NRKQ3PMSQ047TyzUk7UN93FBqw EXbedvisbTrFfAid
RHp2VSFcZKg3LYv7wbUY5yupcZKiFb4jJlRcwuUIutHD0PM/ZAhXSYUsTIE7 DkOvdjJzACHq6+iN
4Br6qCzaKeDKZcci6MJNhpZ1c8vUHdPN62nh2S7VbIChIZHySiLHfTvv1iPO 0OZzQXWlxp3bEdz1
KWe68U7tlXH0/YB/EEnJP8QQosgyKYZ2Lf4PmJTrGJbKb1EbkWtDxW3p0DBK re1wNy8KQYcuqLiL
e/JgjKFxX80LU553aMfLGMeElDFJ3MUSd1VMETc5HpIuv6JLxTSBSMBjBsZp fs/YgaQuF/QYQ8w4
vRPl0PI/laNyHlM3ugu/OglyyEQAjB6Hi6SLm57FJTtR/d2FKYlnUBdcl3sz jun73McwjbNC3zQK
Iaeb1hDkU0O/eoTJjtBujGzpiSR20ZgY/ITmDwGmRfqCkzUohG2lnUqr9EbR FvC2o6PK8pMwdbTm
v6JrLfERzZ9xpYwbu+hfVL5BW6uNJtJLyaEyUvuHI3uIHRhl3Cnj/nu0Jg/7 HiTLeDSudCt7aK76
u5UyZg4k9iNM/69JkokeZNELi+72DZaxjlW8xUtskFUM5I9WJFbkB7tZzFEC UULO4wlqiOE5nmIB
tVgl7zOyFPIaQbRFLAXJM9rLJ/obUEsDBBQAAAAIAKp7cDTvKSWOxwEAAIcD AABSAAAAb3JnLmVj
bGlwc2UuYmlydC5yY3Audmlld2VyL2Jpbi9vcmcvZWNsaXBzZS9iaXJ0L3Jj cC92aWV3ZXIvTmF2
aWdhdGlvblZpZXckMy5jbGFzc5WSXWsTQRSG35PEbrJd2zS19fuzAdNVMpUi CIoIVUFY6kUk95PN
mE7Z7padyQZB8M7/IyiKF/4Af5R4ZrfU6I3pLMP52LPPe+bM/vz1/QeAPrYI 97N8IlSc6GOjxEjn
VuTxsSi0mqlc7MtCT6TVWTrkRHfXAxHah7KQIpHpRLweHarYeqgTevMcM7NC FSq1RgxUwiVMiLSx
KlW5h3OEJXugTXeH5aPF9R8TWoN3qT1QVsfMeKJTbZ8SRO8skO0hobGXjRWh 3tseBvBx3kcDKwE8
NFuooU1YjXSq9qdHI5W/kaOEaztRFstkKHPt4pNkwx2D0D+DfneXj7Ey0+OJ stVs1JgQ9qL/ze+F
i8vuw8XVPFwiNGUcK2O6DwJcwbKPy7hKIG7/7oKihI2q4efqrZwmc337g2ya x+qldtNY/1u77/4T
QvAq5VvfS6QxymAHNZ41Xx7vths42xbcqvP2scxxwN4jrqu5TPgVq+G9L1j7 xFENHZcr3xQlZ529
gK3LXsAGW8ImLp5QnrF1tc3wM9a+4dq/jPfcwYeSsVnVVYzSu44bIH5untIe uq+dwh/MUin9cQ5B
pwiqEJy9Vdbfxh0nXGbc6vwGUEsDBBQAAAAIAKp7cDQH00n63AEAAAoEAABS AAAAb3JnLmVjbGlw
c2UuYmlydC5yY3Audmlld2VyL2Jpbi9vcmcvZWNsaXBzZS9iaXJ0L3JjcC92 aWV3ZXIvTmF2aWdh
dGlvblZpZXckNC5jbGFzc5WS227TQBCG/0lMnbiGQArlfKwhrkFxhXqBVIQE BSSkqKoUlAvuNs7K
WRTsaHebiJfgAi7gNZA4iQsegIdCjJ1ccCZZy9qZ3zPf7Mz667fPXwC0ERJu 5DqNZTJSYyPjvtI2
1sk4nig5lTreExOVCqvyrMdCsO2CCK0fM8zUxn2dTw1Hd/KkjL07EGMrtYsq YcUOlQm2uE5n8UI7
hHr3eWaH0qqEGbdVpuwdQhwuA9nsEZzdfCAJ1XCz56OGVQ8OfB+HsFJHBUcI jY7K5N7Bs77Uj0V/
xLHNoo1RT2hV+HPRKdogtJeoH2xzG24yFFkqB4Qo7Pxvbg8mMrPlsaPFy7hY J9REkkhjgpuE7nIz
+u1QUzVIpTXxvs5Tzcx7Qu/4OIXTHk7iDGFjgQQX5wiekbanjJrNL3xS3MAF XPRwHpcIxGJrwYlw
f+UYVZYytpsf6EQ+VAV27ed22k/FRBD8R1km9e5IGCMNtviiHf7bCUeLe+fd RbGq/NZQZ99j6xZH
VXj3oo84HF1/j8Zb9iqcw1r55QUcjj3Gls97oTaxVnKP48Sccn9O8aN3aHzC 2eoHXP6V8xKreFVy
1mexM05pXcEGiJ/gr0TnD8TXTHzzLyKrV8uca2gVWaVSrOZ3UEsDBBQAAAAI AKp7cDQP49+m2g0A
ABkfAABQAAAAb3JnLmVjbGlwc2UuYmlydC5yY3Audmlld2VyL2Jpbi9vcmcv ZWNsaXBzZS9iaXJ0
L3JjcC92aWV3ZXIvTmF2aWdhdGlvblZpZXcuY2xhc3OtWQl4HFd9//11zWp2 JcuS42ST2JYTJ1lL
Wm18JI7XjmNLlmwla9lYRolMEjOSxqtx1rub3ZEUp+VKKClXCFcg4QhHqcNl EhOtLAQhJJS2tNAA
pRBIKS20pVBaQkuBQBN+/5nVZUn2+oNP3868ee9/n+89ffmFzzwOoFVuEzRl csmYPZBysnk71u/k
3FhuIBsbcexROxfrtkacpOU6mXQvJwyI4OLZ8MNOLGsRRVf3cWCgXFDWtVNQ nzhijVixlJVOxnrc
nJNObhHUtGfSeddKu71Watj2ebcWabUq71bybvV5t6bn8A4gIKjN2dlMzk1k Brx5wcrEbGnyo25s
1BlM2m4+dsC+wyXH+v5cZjRvd2ZSg3aubdh1FatxUSwfgnhGiurYaVdw6aLA 7Zmj2UzecW3CB5I5
Z3Cn5VqC1fMQUtaxzLAb21UEIXh1W9f+A4d2793TQQbtcc/u0dxw2nWO2tH1 h648tC6231O1sSOd
dNJ2AA2C4P6OfXuJ1tmVINpKorl23vUePdbRbMre2daay7qDdt5JpgNYTi18 7XMLCVVcirX57y2k
n81lkjk7n2+ziHHZonrvmwZTrKqtTtpxtwnKI2t7BRXtmUE7hIuxwkQFVoVg IliNMqwOIYQaHV0q
WJKgTt3DR/vt3AGrP2XTT+rTVK+Vc/S7OFnhDjl5QUui9BClQEsHcrbl2hqO DDc3l0kJLo+U4MW1
vSHUYonK2EyLncGLCW9oIGqiFasIe1biBq6k1/O266PS64tL5IN44qzHBhPr sFGw6ixBZeBqGizS
pVgX4xoTm7A5hDosVXVolRWLcCOBzHDWwLWCK0oxUpHBdSa2YTszssdO2QNu o5+Y8QDaGHVUk+lH
Jc+LzK8Cir8THYrfKaiMdB30Ke5WW3ZxWrWtmbaU6nYaob39R8jSI5TAHsXo VnVXUZqhTM65k063
Uj1Zi5kuXSG8BPurudxzBhskrH47ZeClJnpVKbNzOJVq3Ge5Q1ToJp3s1Ec3 i9+Zyo2Bm03cgu18
KGxL6VG7Zp2BlwtikXOJdN9s/SYsDDDqrcHBPZlB5/CxhJN37bQmfdN8h9oj dprizoX0SNk4rIIn
WVnOXB0NOOWMKSb2ETVWeWtrawBH9avz3JRebyBr4naVfhml9yJJF2cUiC6q wDTwHB3ycFWOYbpw
/3C60S+hAYyem1wbDBwzcafKteosVdPAH5t4BbaHcAHCmmmv4ue5On+jgbtM 3K38GmgHrYRnNcOU
HAo8zwx/gtepGPcwFSNdXQeLCfZ6TZI30DRDtpMccnc7aTeEN/nJ8WYWJ3rZ HfJn3+LP3scyVUIT
MPA2E29XI1yIi9QI79TPbnJiFvc6eccv5hFPjnfjAV19ULB+vok8f01Zadh1 Uo7r2PnYjXa/GkrN
/V4tLy5L+3BWsCZy1q6mLN+Ph0y8Dx9gr8oWm3pZcpD9zufnFUC6OnHGCqmd LjVVuxNn7Q0Er0xp
VVHCZyw7W9ROQ5lRP1i5k6DROjMDw3lWwWzOpjGml4zkVGFdFlk7v7KG8Emc 0Bz+lKDu9FUDj6oG
djrpDnm9mpXx03jMxEmMMcLOFK77fCnaOL3DyzkD4yZOYZVfp33puq2jbPuf QYeuTPq+LzohhM/h
IZ1+nIy5yQnhCazQ7y9QpUEnz85C1Kf8uS9SytyUvkX9WRkT5yTgFj+TfMm4 EaBsrp2jRXeV0uLO
un/TfU4DkebT71ug4f1hOIbwN/hbk8n1lTNkju1tFmNW1on5+8aOOwbsrO+y v6NPpj8paqxkItxF
HXYYQF838Y0pp/sruzPq9G+iQ1f+oTSantGK+Aa+LdgYSZSANluUYuv7joln 8F3GeiZrp32yO729
r2D3QhuPUth0+XTYPdK6B2VO/SO+p3z+iccGf2O5y55x+U77MHe/atEDVp6H qZGSdDmNSYmSLc6X
Uv4z/kWl/IFg2+9Hy8C/cjORnLuu8RKOHPRrjleYGbypYgcm93/Hj4L4N/wH C9NCEAZ+wrrmkJbl
ZtjPlkdmU+oqzpPOT/FfQfwn/pvngfnrBp5jF0lP1b95G0Li/w/+N4if4xeC q0qxwhwV26w84/GX
gqvPCdVrDsSnkr+eW3aPsSMfNfAbFj2va5znS+xkWK/YZXtcRtNRCv3/eKEa v8WLtMvpMds2fPgw
u54IXTLNsdFjGW8MSLlmQYcpZVLpNQe/CIuBE0E8LwFWUivL1GCra1kwHxZm tyUkpgSVaoheczP+
WkhqcUInl7D2LaCIIUu1YOtEKh2SBpWrXpaxyyZt7xym2zbB+XNcvyOXs7xd KHkul/NV6guU/HwA
Qy405SKNjE2luKeHh0krN8e/hqzgeaA6IKuCslKNYwxZ+W5Gk9cND4bkErmU wSNrgviVLtcm7anz
44FjWZr1CjymmBF6mUtzNqC61Z5v4MXSRZqkmekiLYKtpSgzrcY0z/ahjDNg G9KqFw+2d5tCAa9k
9EtM1vmT3uYiJBtwQic3Ut8RBdt7WE/D85Nnof2EXC2buEGQa7hhikYDEmde Fq8lstNNLx6Qrbwt
OMCjevEU2DiYsfON6YzbOGSN2LNAWwOyjfuigZQ2fNmOFWqFHboJsPO087GQ tOsm4BnZqYlOJEbw
gFfxBetKqZFzmgSR/aUSkWc3JkUeLPaSjaUgn17S9fLC6wjbS8JevB6rJJ4F mTzLFwwo5aW1lVVx
oapKg3v4zJySRJlXFJVC0t8jX3NuFKZrI0mUOeupSV7zkpJuLonQAlm8Rbcf s1NPiaZ89WcWqDz1
3VYSk0Wyy1N7xL+mND0DFs8JAWtggOeeNbzPSZzbef1sd5XVPcfS7pDtOgMz XNaF8AnNiTIZnJmk
JXv+QKzn3uWZPZnh3IDd6eiBrWEukVaNLUGoK81jZnvKyuftPFZzQ1rBm+Rq hFGJKjCX+VXG77v0
4o/ju/TaT+f0ak3feifFdxj1s+CX8fu8Wd/n88cTtY71UOlxEL1U5HMlvzo4 L3wvaRpHY5OM4RJ9
rHnUQ7iMz3pPrDV8Roi6FrUcX86ZkI+GKxDhW7jS5JMsu4nsDU7d2tQ8hpbm SbT2jSNWwFWT2NS3
tBzjiO9pahnD1kls62s2xrGjO1rfXsAuhawsH8f18YpouKKAG2YhRFsK2Mtv ktq3p6VyDAcm0dsX
JfSN8cpwZX1fAQfDlQR6WdMkbumLLg0Q7VaqM5vpY7iEEIf45rTVR5UHCxgi wpG+aP1t40hRcy6u
qU8XkNHBJG5XqFwBIx5QXYBA8apwVf0dhAhXTeJOXf8jrpPKK/qaKc8rx/Bq j6lRR6a+rKT1anJ+
Dd9cu1txXlvAnypYVWU5kd64p6XOHMO9LXWDY3grab29r7lyHO8Yw/3EuZ+4 79J3eQHvURqn8MEZ
Dz3o+WMTw+YahsRmOjmORmyhP7biSlzL0TbswHW84tvOK7w29KEdt9LxDjqR xW6M4HpedNyA+wjx
bnTjOG7EGG7C44T8CvLcDLv4PqF+ijfgebxRKvEmMXnRUY97ZTXeI1G8j83x /bIZD0knLwe68UHp
xUfkFlJSyXb70eBHijf6EJYwVi5ik/owllKLJtmIP8NHUM771Uvx58SroHS/ wMP4KLV6htJ9DDVe
UH98OnCblZT+ZgxR5U2cmBWeoky99U9MI97Dr3K+oxoGBTySaC6g8AAaJ3GK wTWxp4Xfn21RKxfw
eRr+Sf7+YobJJQjweZLPx6jFGBOswHQaZ1acIqsJtGDSE6DRZ1IUIEDcL3kC ns/0/Ev8Fcr499f4
clGoLKEr+V5WFKo72txyCl89jsp4xaMQ4i/l39NzcvIJzj7J2afQQIrKs8mb X+bz1JFvaW9Up5Ym
RkjlIDdTj8Gc+RpXKwjztMpRfhvHdbTbU5P4Bq3x98zMZQV8axLP9EXH8Wy8 IlzRVMD3mXIV4coC
fqi5UDGBH5chboSNCfxMEA8cl2A4MIH/E4r4q3h1uPoLeP4BpMLVT+D5uHlS eKtR1tcgFeNSFTYn
pFpQkJqC1BXkPP0O6/fF8eBxtISDPhlZGQ9N4zUqXmhCVs/CI6BcJnjwxaeP 414yIoIyCldPyOUE
8wmvZX//gKZtcXpCopQ7GA5+ibUj6AsfOo6dJO5zjcVrwjUTsl4VORmv1fFV hFlSFCW85JRspjAN
soWChGtnpAkVpTkVDvijF56bql3TRU8N0yDXzql7Zrg6bM4tfOHqBStfuFpL nwrfINcVVH6tfeGq
CeH/DVg8pWMmZE+ihc+v0vlfY/n+OvvBNxme32LJ/jY24DssE8+yPHwPNzDN e/ADHMQPMcqj6N34
EV6HH+Nt+Ak+xfFn8RyD7ed4mqn5XfySs7/Gz/AbHrlekABe1DOKrOAR61oe 1XbhWXmJGNJH9w7y
GJSSoIzyHPRKqZHXS628RerkXTzpvFca5GFiPsJjS4Fnls/R/U/KhRrOlGi5 hiKLShW/OPLDWUdT
4SyTskt2M5wvkI9Ll1zP8G2UD8sNkmA6rZUHZY90E3uD3Cd7ZR8L0Va5h3Lt R4Da/lZ65ACqqW+/
vJQlS6+ON8uNXA1S5xVyk/RBr9Ne641M6nuzHCSVIPXulpcRLkS9r5KbWepq ZBn53UpetbKC1n2Y
oyUyiENyiIWtWkaR8AqbKQ/jIq+wBSn9y8XihqRftdP0o7fES9dKLQOPnFbY IrjcmwERB9C/COK4
2KdXxEdmIR6W5KIc7z+dY2wKkShD3tORI14NrIDFt1ai24vvO4vvu/337wBQ SwMEFAAAAAgAqntw
NGdzhk7kAwAA2wcAAE8AAABvcmcuZWNsaXBzZS5iaXJ0LnJjcC52aWV3ZXIv YmluL29yZy9lY2xp
cHNlL2JpcnQvcmNwL3ZpZXdlci9QYXJhbWV0ZXJWaWV3LmNsYXNzjVRrUxs3 FD3iZcc2JHFJStrw
CgnYBu8m9B0S2mJMcesAxdRpPzFrW5il9q5HK4d+6B/Jz+hMkwztTKf52h/V 6dHaARMKYXZW0pWu
zr3nPvTPv3/8BcDCjwJpX9VtWW24rUDaFVdpW1Vb9jNXHkplbznKaUotVZly BELgdq9627VbDm+Y
0y0uIugXmH5Lo1CSDVnVru8V3UBLT6oIBgX6CqsCyeKB88yxG45Xt0tauV59 SWA453uBdjxddhpt
2fHQ6gJaxkOLHlodD61Wr4dRxASurBS2d3bXN5/kBWZyD0NOWdX2tNuU2cXd +7sP7G3Z8pWeynt1
15NRDAvEt/Nbm7y2Vijy2gSvaRnocCg5zVZDrq5YqqVrMnDrXhTXBGIqBNmg dYHBhlORDYHJYi/5
4FDbh26tLnVgF40CyQ09cj1XLwv0p9JlgYGcX5MJ3MDNGAYwJoAoPkggiegV 9OG2wNUiXdxoNytS
7TiVhjQx86tOo+wo18jdzQG97wYC88VLZ5O+XK8q6WhpMseQa+WTwWzqXAo5 v9nyA1fLJeP5+IVM
I7grMHcZrEK6bPjPxnAPcwm8h1HDPM0y2PGnKnKq5nvSsqwo5gUigdQ78hct cCN1tnIMUBaWAbKZ
UdoxPEs0wrJNpYtv1+Wb06UEHmAxRqsfCYydpxXBJ3SAoFtOnYDT/wP41Fc/ V6RX3aeKQf0Mn8fx
Kb5gsC5SJTSTMerUamc6JczHO/spZP4Yy3E8wpcsMfaE9BikmUuEn3FmULd7 ankoLGxej/Jgza+2
WVfXgjc2c/uMuKwJrKcu4q/00qnjgz2nKrt1GPRQCEvJukhTq3ZVt5U8CU4E 6+yLOp1zVaDzDdkM
2Y6m0j01sVk5oDaT8C2+i6OAIrv6vGistLU2sBvsI/OesY/fwY2vzHFEmKPL UeUzsWc8ZgufdZQP
Sslvq6pcc8MmP9WrllHHNCt0AEwQBnELEb4UdAPgbpxyokceoXy1R77On0+K WZsG4zzIMz46HN+n
9Jj7gnM88wq3MskPX2D8t1B5guMI+jkmMECYGOdJI3XUMUWnwPUdzHSh9gjd x3k28yfu/TTf/wqp
F8hkfkcmufAS9zMv8fERHgpkjvBVH06sJIkPIgxjjG6Ns4cnQks3O2gdS+Hq a6xA8MvB6tpcpo7R
GsrMn/I8Fu5O06M7PVhDHaxwtWqCxC9/HIp5w8f8JzBD4cZcD3FxTHwN33Qv /mqyw/nuwmsUnmNy
4W8UjvBEYCP7GpvPMWJiwH+cUTjGptnB0GgECwxvluRthnIxtJXp4HVshast fE9rZrWNUpjXJHbw
A/q5Ww4xn/4HUEsDBBQAAAAIAKp7cDRQQsemrAIAAIMFAABNAAAAb3JnLmVj bGlwc2UuYmlydC5y
Y3Audmlld2VyL2Jpbi9vcmcvZWNsaXBzZS9iaXJ0L3JjcC92aWV3ZXIvUGVy c3BlY3RpdmUuY2xh
c3ONU9tO20AQPZuEOAVzC1AoUCj0gpOATe+UUCilBCGlFIkqD7xtnG1YZOzI cVLxTX3qU5U+9AP6
UVVnbQORAoiXvczOnDNndubvv99/AJjYY1jy/LolbEc2msKqSj+wfLthtaX4 LnzrUPjNhrAD2RYa
GMPIKW9zy+Fu3fpSPaUHDUmGxW6IlrT2u8JK3A48/1xDH0N6Q7oy2GRIGrkK Q2rHqwkdGjL9SKGf
YbgsXXHQOqsK/yuvOoIhW/Zs7lS4L9U9NqaCE9lkyJXvmHmRYcz2BQ/EPtFL 7pT5udcKGOaNck/m
vC6i56JKcfrGd1KeZRisi2C3JknhNhEwjBu58lWJjgJfuvWijnFMDGAM98mh 2R1QkU0ZSTKOcxUd
U3ig/KYZ8kRsxsSm0maSNjPSZrq8Les8kJ5bIUMGs6kt+k2GUV6rHQXcrXHH c4V6IyCjN6Hj/VKv
UfHP45HiX2Dob3Cfn4mAqpjBYwY9KmDJc2rCZyhdg3otaE+BI4S4xDqe4pli XGIo3Kb4Mhslaj2f
QY5h9jZoDQWGIarHocNtcRKnPWFcr3sF5gCWYVFT3TmLDJ4zaMSgLjpeRhCv op5QtosuWzXuUhcV
cVmVN3irqrIWNmCv34XEdfoX6qcdx2sKNRo6NlQDFfGeZs2J6Wdv63H6aNHV vtneTAnpW1y9uRs+
8wrryGv5tihJ1dIjXRNoKlgsIEFzToAAnZgafFrv0c2indHel/+FgZ/hs05r WhnJaZBWPXLAEIZp
J3iMxsE/yC9F+16hg0mGz4VkBzMJFLIPk6ns3HIHi2m6PEmHZ6MPByvZfAer CaxkX3TwOvTs4F0C
FLeZwBX9IlGDCDWiHCK6GfoSg2Z5FRNYwyRKmApTy0f0UWrhaQsflD5at/GR 0AyarB18QpKsuyF+
6T9QSwMEFAAAAAgAqntwNFXXyXrUAwAAzggAAFMAAABvcmcuZWNsaXBzZS5i aXJ0LnJjcC52aWV3
ZXIvYmluL29yZy9lY2xpcHNlL2JpcnQvcmNwL3ZpZXdlci9QcmV2aWV3Qmly dEFjdGlvbi5jbGFz
c6VUbXNSRxQ+myAQxBqx2toXNTaxkGi21b7YxoZKgooSkoKBTvvBuVxWssnl XmbvEppP/Tn97Exr
M/3QH9Af1emz995ABGrS6dxhd9k9+5znPOfs+evvP/4komWqMrrtqTYXtiO7 vuBNqTRXdpfvS9EX
im8pYVYFbD+wtfTcBDFGs7vWvsUdy23zzeausHWCpkeAepKXGp7aawrX3mlI t+X1Q4B14Yi2pUWC
zjCK94MTRnPlEy6vMEop0fWUrlgdwShTHnKoaSXdNiwSTeX1faFG8fy+5tER L4QzrOP3pSv1KqPp
bK7OKLbmtUSaztFbKYrRLKPzZemKSq/TFOqZ1XQCp55tOXVLSfM/2ozpHekz 4uX/pCP8n/OFrh4L
6VJ2PKZcPU0zlJqhKXoXjEMFIAWuFo5inc+eGKyBOUtpA/Mh4m2qPkbVcxkt vH5594VlC24FFHkp
omrUuVDdrjzfrqwXq8+La+XSVq2YpBsmeNUTSZp/rSZqB74WnQTdZHQWRLeU 1xVKHzC6NyHCCTGP
b6UpS7kUfUyLjFbGdG5Z2uJey+I9LR3esVz5Qviar+vuRrQu/tR1PCVUgm6B U1vokutry7Whej6b
K/8PRFBbJp6i2/QJMtgWONDC9SHbkSVq42k29+NxJwG+9jzH57bnugIy70t9 MMHjGBr83aG7xt9n
UH9Hd5wkfcHozlgIYalE9RegSi2FzxuiWQ/2EnQPL6Yl/a5jITePT5WbU1Xa 17SSoq/oPqOLAwBE
Yotu2EFW8ba6gNM1bdl7z5Rl4919a95dnh6gysPyY3Tj5NJkxMzLKY/4ic5m fTSbwHBtB2eihVSc
ot7HLSIZfV6qAXH4KmaMg4jtzdNdizT3fNM6TAMyD/jE7mdkTVDSPOAKnn/N 6ylbPJSm/1we6y3L
Rg2ag22MICdNY4XLaPhTppmY2XQDzEmco+FhPI9/dzEzzGcWf6cLLwOzDMYU ZkI+Y0jsRazSoRG9
TZcwgwC9EwGswtLYxheXfqMrowiruJMPEC6HViFCsHoPNsb5+/TBJKyro1gF YK39C9Y1wxDfdZqL
sH6GBNOYFzIfZRYOaalxSJ++os8bi7/SlcyXGK8e0je/UHLj1isqvAzCu4Yv H7oEuTjGh1DrEeBK
OHkC8DLN02ZA4XoIPqCwAGrrAYEYFXFvyqwHKvdMPk5Bprz0BjJVkKkBbhsn dYB/DzI/HOkxJHNE
wegB8o8jCnn8DGU2lDUeOLKPxcMG8bAwHrNC9E+CeJ4O4lky+5PA9gbVMgRj kG1jUoY3RzPsI8N6
coZNMQcRbQV3vvsHUEsDBBQAAAAIAKp7cDSdp4XHPwIAAIsEAABOAAAAb3Jn LmVjbGlwc2UuYmly
dC5yY3Audmlld2VyL2Jpbi9vcmcvZWNsaXBzZS9iaXJ0L3JjcC92aWV3ZXIv Vmlld2VyUGx1Z2lu
LmNsYXNzpVPbbtNAEJ1NnKQxLqVJKTThlvSC4yJbSLwFVUBLpUoRqijkfeNu 3C2Oba3XbT+Ly0MR
D3wAH4WYXadNWiIBIlI8s7PnnDk7Xv/4+e07ALiwScCOReAxP+RJyrwBF9IT fuKdcHbKhNfXYT/M
Ah5VgBDYmEZn3Ev0lvdykEpBffl+7wJbJFDONwk4vb/t0UXWcx5xuUWgaHf6 BIzt+JBZUIE5Ewww
LShBuQoFsAgs9HjE3mSjARPv6CBkBGq92Kdhnwqu1uOiIY94SqCUSiokgXVb u4nTgHtDQUfsNBYf
vFdZdBiy7TiS7Ex2VWPz9ZnPEsnjCMn1Y3pCvZBGgXdRxjMuWbAINeVrmUDF 12Ts0P5zA3SVyjix
oJHzm9gvYHKHDWkWosQTu/MvM6shd29EA7bDUl/wRMaCwAu7N3F9IAWPgu5V 1eMh9ZknWBpnApNr
CqjbRLQ7RrvKg4se3NzDHLQIrPCrnF0Rj/bHb/3tjP7/6ciCVVhT81rHASZU HuHRf5fEWR5o/i5X
739xeliuQkMLL5CBHwAi1X3CrIQ53jF8VnHVxUgwVp1zuOF8gflPuCjATQD8 F/FZQ3od4UuwgCsr
B8MtLUXUpUB0HXMDV7e15BZWChjLzuY53JnombraQANNrbWco3Itnd2FFW2n MUN1d6xqKtV7ZIbT
Fiq3Ebs6pW5eqpu5Ou7fhwfjw69hVD/jM8x/vFQr62pHqxT0aR/CozHjKVbU bqXWdr7CxnXSs8mQ
cMaPwdZD6miU8wtQSwMEFAAAAAgAqntwNAGQDBSRAAAAOQEAACwAAABvcmcu ZWNsaXBzZS5iaXJ0
LnJjcC52aWV3ZXIvYnVpbGQucHJvcGVydGllc22OsQ4CIRBEexL+gQ9Q7gss LDSx0MpYmZg7bkUM
B5tdUD9fErVQd4st5k1mhnMlB5YAM5VDgDuQvfZkFobJdVrlWrAWiQ8hNd6+ DcnFOgI3EWP1TXlM
cXbUynzfb4hgCS4n7v7BJxgpI1AJwIKnwbG6core+nAWDIyx54sdJhTgdrVf zje7tdRODm+v2e8O
rZ5QSwMECgAAAAAAqntwNAAAAAAAAAAAAAAAACIAAABvcmcuZWNsaXBzZS5i aXJ0LnJjcC52aWV3
ZXIvaWNvbnMvUEsDBAoAAAAAAKp7cDS83AluzgAAAM4AAAAsAAAAb3JnLmVj bGlwc2UuYmlydC5y
Y3Audmlld2VyL2ljb25zL2Jvb2suMi5naWZHSUY4N2EgACAAoQAAAAAA/v7+ AP7+AAAALAAAAAAg
ACAAAAKnhI+pi+EPo5y02oszbpVbA4GR6JAjQKGPKpmGwLZlB6MADK9B7O4r /rrZRiVVzCesAXU8
nq8ETA5DxRlVKmWGnCzs8mg0Er1C7Yr7E2bB1Sczupw1r2llmb0TX+Fl+ZYO pfZFlGf1JtiH9Ge2
w5eDJ8JGltNxNOJouZiCeXbQllAX9HgjUDraaFrTiKhUilATdGAqGpvKYxti q7bQ4nmioBEsPEws
XAAAO1BLAwQKAAAAAACqe3A0HiSsnN4AAADeAAAALAAAAG9yZy5lY2xpcHNl LmJpcnQucmNwLnZp
ZXdlci9pY29ucy9tc3RvY2suZ2lmR0lGODdhIAAgAMIAAAAAAP7+/gD+/gAA /v4AAAAAAAAAAAAA
ACwAAAAAIAAgAAADqwi63P4syEmrvRXqvSTAYBh8o2hm3qkOJKmGA5u+WDyU OE3ZAUG0usqtRxAA
g5KYpGj0CATIoQ8KhIaeWOxtOiNZL08LlkA5BsKVsO2m9JVnkmw2oKS3ye/c xeeu9PMuFn1/RBdm
O313fBiHST5sQyeNhTwvjYQ6LTaLSCNmeEgfCimYliWjI6UhLqMRepItrR05 gXCnsQ4eoqyeuLIP
uhHAHK7Exg3Bx8YBCQA7UEsDBBQAAAAIAKp7cDRpsdAY+wAAADoBAAAwAAAA b3JnLmVjbGlwc2Uu
YmlydC5yY3Audmlld2VyL2ljb25zL3JlZC1idWxsZXQuZ2lmrY8xS8NAAEa/ QJAQqtxSuAaEXKrW
QAZvaxCk3lDxphoEJZMSty5KFyGL0AwdQqaMHSrS0dGxBJc4mTE4uTpWcHI6 yX/wG95763dyOuz7
1yZMLIGiKMo4rcS4IrKK4hpCIVCQa4gSfhnnFXxFQsVjZQRfEHO4Kq3Vcq1I sIKfw00IVyyqDZHA
DUE/IV7AI9AV+DN4CCZBJ4RPmiBzGVVRMgZLucR/jP3qWmOvQfMJGxcD2DZt 6Rp7GB3QrZmuLS4p
3XzramdGK5vdBItzbzp9unsd2Z33q58Pr/+dDQeP90e3NnPMNml3uts7bBd7 vZ7F8n1pOpblZDjG
4R9QSwMEFAAAAAgAqntwNKsp9yn/AQAAUwIAADgAAABvcmcuZWNsaXBzZS5i aXJ0LnJjcC52aWV3
ZXIvaWNvbnMvcmVwb3J0X3BlcnNwZWN0aXZlLmdpZsXR7U8ScQDA8R9yLEIi U8yHKWVbD2490IML
M5WoQMxVQ+B6mxsdvm8t4XcX3EHFQeYGC1avmr2KN4z1ytnWW1qbphcsTJI4 iJNos3kajzX7J/q8
+77+6vRaVf/tJtAEcijwhJy5jbL97o1U8TcdooBnIc2xbIFbynz8yVeKndrI 9NDn3Apfri1mt9h1
ji3k55bm6KAz+RbGvvGr+TW+VIvnt+Pcdt+LW/Fsgg4536f5zXIt9aMU9qo9 AUeqWKrWqziB2QnL
p+hk7lf5+0bFF6SSuRUbgUFowSHmd4wwmeWAQ+eDo+6pMTuBvfaqY2meYZch blnIbtEBgmEZ+jmV
YBNMdNJ9f8z91EaHXEzUGktv+qAeEtbZx5fXOLZSrUemh1fzX73PyEqtDnHM ht/JruftOEbg1jib
gBADpuCDe9fpIPlmZvDPP+A/6SkhAgBQcHwndp6AXREHSlIu90PU5KFNj0iT ecZ80dT4RDdq0Bpa
DjdeIY2us/v3vOpuUR8gwUvy1G6DIRI9QQ6LEVIjmJ8/clQZFoub0UFhj0Ik /HA63Nd/Ehlvk7SJ
2jvax0mk88LATeM+yXmRrEP2BW3u1auk0sy5S3J5VwG0Hjw01DpiRMRypaVb IjyjVfZOvFOHNUDR
pVpEGlzCvQpZUq1x+49dM0unJqirs36qQQAG/gJQSwMEFAAAAAgAqntwNJDb 86COAgAA1wMAACwA
AABvcmcuZWNsaXBzZS5iaXJ0LnJjcC52aWV3ZXIvaWNvbnMvc2FtcGxlLmdp Zu3TW09SAQDA8cPK
RrOYueqhWaKtZpsPWm3m/S4HJDqIKSAqF+clr4iKHFFPgcbFDNtURCTCy9Rp smVOmg+JztuoXGbN
YTOJW4lTl9lsGs1P0Uu/t/8H+OPwSbdCWV6AF/ALABKjYk36jwe77hXNwbtX q3sOt0FkXhiwO60u
MIb8fsFcmNAlyNA8rTX1Ns0NaAyy4vGxNgecqxrueAMXKaghLYk3ORV0DRRd TIrjDCqWs3FN/apJ
X08COboqBZcPF6rIIMcwtOSwbtJwIjrhPpUgmNUfTo+vZRJlSPHoUPdUn06f eF2YHMEHw8opCQiL
3EK9Db98Pk/FyxlERQapAeGOxIXTzJ++ESKFaaCMTmy2WXbAsEZyvKKALeOV yOmk1ixKFwNqz6ao
aZCEkSquKpdr1WNvTSsOu4tDe7a8ZLFZNyBQzqLqMtOUd0ntOZkjHMYwO6Of SdflMftysl6kpag4
zN6CvMGe3j2LZcticabTRkq5EziirrTazBN+pmf3cCsHqhu24Ic7/Aeuynpn Zb29ou4rr3adL7Kp
dK4nykV8ilIg2eU3btdIf8KSH3zxJl/8nStclrTu10nXSqqNko5DZd9hcKQw na222Tfcbjfw37/j
t38cBQAIEHgUR08A6FEAddIH1GsnRegaIqLXGj0wlzF2LBNrfOQbRQchSJ8M xHjMvZ73t0kxXmg0
fBaaeXw+IF7sKttBtBIU83eRwdiDPnMpKODUtCjvjk8oz6kOpsySOiMEJ+59 8bZ7tl1LHaRK2dY5
KES4KMF3557uDObvTghulM2gzl3M/wCy4pPQQCD6TyzXv9HD+wpRCCI5+Mmr AReCthG/Y81YAgam
rTOnPLF4NXbVJODFAED4X1BLAwQUAAAACACqe3A0wAXQIY8iAADliQAALQAA AG9yZy5lY2xpcHNl
LmJpcnQucmNwLnZpZXdlci9pY29ucy9zYW1wbGUuaWNuc+18aVAbV9put3Qy /lz3pjLfv/mRW56q
z1VfZapS9sQ2sY1jvBtjGwxGC1pACCQkgZAwi1gMnO6WrA0ZhFgksS8GI/bF mM0GG2y8xMbxQrxk
Yiee1Hz31+Tn/Ejd3Lcb8BZvGdtJZkpH9PK8z3POe/r0OWqd7rfRJqVnEoT9 O21S5n8RBBFOQOJP
LXzCflj4LGGWexWvzVzzCUGQW1sIKsFO8BMePGA3srt35bAR370rthB8Qawg lrpGxVIEcYA5h86f
P3cuCvYjcDe/q7u7C3cTEQB34J38xqbGRmonZNlSVbUFCtjkcoXCZr3Ltd5O UOtaCHDTB4a+775j
N13ffNsFm/Zvvm23EEQzbqLuUU0Uscw/P3/rFvzhecJPEe95ZmfPz56nZwkP RfCdzpISaopfAhvw
YxkdtUAJRUNDRbDJHxrKAz85nJ8CMBSo1ewmT6XKg022SpUNeTKMGRlUEpVB Eb9LUygS4Y9SEGkU
wdNIpVhCsisiBTwpk5RKSsxXKpOSIFe8QBgPZUhiD0pgI4o9KAJPsS1E5np9 KjTgfxCvlX6E9M/i
H59I/wwmfqa/R/i10p7tkf/13Hb44PuXLh/8+OP3L1telf+V6Rf2r01jB9R7 /+d/CFIQzcSQ0QIP
QURb4oloD7E8Jl6pNxr1yvgYDujPzM2d0S8Cw9z9+3OGBSBNu3zv3mW9bBFc unv30iIQaligEcY4
ofxwJmK5UJ1z6c6dSzlqIRNBhgsY4j/DY2MPHoRFOTg998UXc9ODSvNBIpwh lkfEihTQmZWGM8xV
8oyBUvIVgugIhuBHRMo6qZPk6Dlq9n9dmD0/dnLk5MlOWSRLbY2MH7Sdpabx Wf5gfORW1rJH3EL1
Le/t61v8o/r4LaJwjtodW0k18poCnVQXrzPQRDXyK2N3s8yGHbsPUDFIVt3U DMOcrJZRMfwD4Ts3
MAQvZPt2esfyKHtlfUN9XaU9yryDCGHg4EKYDcu37BUe9XqPCvduYTaQIQIn sfzPmyMclZWOiM1/
9gDYtNt89Kh5VygHQncxLhezcyMHQraxYFsICz4K2ZpL07lbQz5iwbr1m7ds 2bx+HQBy5TpmLblu
ZQVBfMx8RHz8fwk4a4FupovsDsBZa7H0EC0egtfV00cN8/p6uiB7V8+Ju/fv 3z3Bgdae4a+/++7r
4Z5WFnQO3f3m23tDnRzoGGDBQAcH2npZ0NvW6oTi/Uzt8tauE3cefHP3RFcr U0v6A9AK7qZGumF5
++e37n311b1bn7czDWSjG+y1DU10O9lzg7lL3uih23mN9bUM8b8rfM0Xr12b u3bt1vyXX1Lz9DX+
xWZfBbRzRXXjFXyTukHehBV9k3+lsZo1O8trzuKL7124cPHihQtHLvLP1pQ7 oRhnmXdsampyagq+
Xs9Ts/QUf8xbBgRiHC53OfaQvjFmavmYz1Ne7ik/WsIwBFFM2bGDV94/Qk2+ N9Jf7rADJJ3FDBxY
McMst5R4hsbGhjwlFoYhiwNwwgpoZ//ISL+TLoCWyCw60nPiRM+RokwWFFq6 h4a6LYUcyKVYgE0c
MBW3dXW1FeWwQJeTW1hUVJibo4NTordkE3o4cQI9oyP1gv9hT5ggh8kkcwRg 1eczeWQ+8LzMvAIq
l1eQx5WWl5eq1abmLYJcrVqtzV0AphyNSqXJWXCak82C7AWn2VkpKlVKVrbO ueBsOVw0WEtGhpHz
DI2UbDCkp2MDL12lopJ4KlW62UAkg12XbjCAnUxPZpLI5HTKwDca0nVwFpRp aUlYSSYlUQp+Ilx3
aCU/KS1NyRAfKFN1iQkJikd/TAI/UatVsnnU6ngsY6SUjJby5Wo1a5Oo1XIs gwsVJTki5cvUagl4
lSTC5Qonkoo4RkzGKXAiggtXIstEJyoS4RK3TCQSc38UkKQymh1jUrNkmVwu EorEcrkZLn3sCIuR
y4UCoUgu575vxHGC2IOxcWIOiMQsEIsWvolELBAJWRAhFLFfOiJhBJyFiINM LHkQ9ohwC3zxeBa+
qMhwOFtp3MUSvebF8q0k/ocruPQh//n8hzMPuDTz4fP5FQ9+5NKDFf9a/NJx hz5c4B+GLrXD08f9
8IcF/oeHS+3wqNxn0pKffw3+xcf3eu1DvGH7/1b4x/37nxsf7yRpkzTwY5EX TrxWCvvhTdfF/w8O
lG2lqTdfs6W92uPrrN9Weh1f/57to9WwP7b/4+iPxA9wlZFY40iJoIEgJXJr PCmXwF5cvDWBjI9r
IFBcfILGRGFk0iQsYVM7NYnaTY8wnqQeoEn8CBefpr5Gp4sXsUR2eIL6Ck0U yqWLuGCcuovGDy9g
gURaMMbiApmEw6K4PBaP5cWJBCwWinM5nCsWwm8VuwCpDuWUTlK30WRpziGV XWAlsOD9GMHix1g3
MHaJuo4ujQ3UGa0xpCDCSlACHIsF/NjYzH7rNbI/0xpLxkC23wliYqVaoxFn 8I1G67D1CjlsNRuR
RhITvc9KoH1R0SkecwfZP2W58N7Fi2cGAgG6A3lSoqM4NvKA/vjRc8x5+hxq 10dFhoMtfH+krsU1
SU5NUlPk5BQ0Uosucj/HROxT+S2DeICBxTKIfKq9ETvAvmNPRFKFpRt3MbBY ulFFUsQezr57j5Qy
e/i+lo4OJsDv6GjxmT2Iku7ZzbJbtu/cG2dOWGYsb2llP1QLWW40J6C4fbt2 brHCTYRtO3ZYdvJl
9sZG3EQ3knaZdSe5HRi0cfu27dvM298X59lcvvr6ujqvy5Yntm0nwqwEuSPM ugVFCsQaO+VDdo1Y
EGndQobt8BBo0+YtAoqqQpRgy+ZNcE7Wbw4TFFEVqCh282frWRz6WXQBVYoK oj8L5fDGTQfyKBfK
PRC6cS3gtRtDD+Q+iT/dEMnh/etDOByyfv+TeHXIp7tTKBNK2f1pyGoWrwsJ 3UXtRbtCQ9YBJlev
sa4j18Aescq+hlgFljWrrKvJVWvY/sz16fGAtYcMjIMiYO8mAqDo6bb2kd09 UFpPd9/gGHUKjQ32
LeGxq9Cfro49wqduU9+h26cWcKC799Q89Vc0f6q3G0p6P9DZPXbr228fPpwf 6+7kDIGu0ZvffPPt
t7dGuwJgwIFlIzdYfHMEc3x7x8kFfLKjnTU0tbUPX2cNN4bb25o87OTGWvd+ oH/o9K37D+4/uDU5
1B+w1sEEB06mH24NWRpQ9/TV63eov6A7169Od9saCD9QdY3NzZYmsveK9R55 pdfaRDbUwTmuq29s
6TT3kKNz1rvk3Ki5BwVaGup9wPj8te2naXY6c/nG/Dz+kp4nb3xuvohOt9f6 Wb7S6++YpeeZWxgW
yzya7fB7K1l7lbdthr7OfIFhsVxHM23eKtbu9lQ2n6Yv40sYFudldLq50uMG u6vc0zhGz+LzGBbn
LBpr9JS7YLy5St01PSMjePS9kZHx6fPn8Tn6PH96YnQUj/xudLS3trzMBbnt TldZtdlPtp60niFP
tpr9qLrM5bRDB7U4KCdZ4qRKSN+gdWrZoK/ECR8WO4AmzDYHqmrvHxqnTqPx of72KpuDMEM2m5m2
0HZU5q6oG6DGfzdQV+Eug+kX2EiHDXo3xVjKu6hR1FVuYSg434U04w5QIyjg ZuhCFhdh13HqBDru
wkUszjtcVNJGDaG2kqLDeSwuKHRy2FlYwOLs/ALHMcDH7Pm52SzOzbdz2JZn 4rApz+yjWpGPyc1h
cUaOqYCmjiC6wJSTAT01I8uaQ2bBHmGwZxEGsJgM1gzSYHrUu01Z1mwyywSK LHs+kQWK7HxrAZmf
veA930TlIBNsF7HJQKUig+kRzkml1Cg156d4sXZZOkqFdFlcbX+Kc3IzOZy5 WPusnENawNpDOVkZ
LM7MzuBwRnZmhgfqqrPqUXq6UZ9CJaMUvTE93aondSY4XzpswOm0Aek1mhQV kKoUjUZvMxA66Np6
Q0YGNtIZpD7FmkSm6Nnj10MX0qcbDfq0NBqKUAOh1pmhcIMxHTikTdWnqulk vkqVnEjDXI0PdyiT
zMlIDXYty+vStEkswcBiU6AkbZqOtat0qZpEOh4nMLDY4lFiik6jYu0pWrWC lh+RMXKLDCWotSmc
Va1JTqClRySM1CJB8uQUdSJYE5PVYJXzZTKplJbQUlImNctQPFiB/V2iMjlJ mQiVIuMlVjEpiacV
v0tMVCYlK4HlyxUwAU2ilaSCI2F6SyeRSjkwEpjsYiWtQPFxcWIxJUJicVwc ZAZtkgR6tlpilb8v
lcmlYqFQJIqTymVSq5yUqD3E+3GyeJlIIBAKxbDDXleBlYooARJJH113JQIq dmEL30kCsYSbsh6E
HTFnEMWJOQPsiDiDUCziDLAjXDCI2OkrfIQi1sBnDUwsX8QhUhBDxS47yPEx CxguvNxehIC7MjcQ
TgHbnzXc7Hb5Lzm7/W2mD1aHPUqrPyBemVaXTT1KZauJV6awqR8fpakw4pUp qP/t65/sM4a5x/o5
w7N96ad9Zu77x/rv557pS4/r8Mo0FRbU/6vqf25/+Ln97ef256D+X1f/c69H P/d692+etFnsXZmP
NrD7P77wUwa/3VYKBNHeGBQtiFopuE2glYIYidQbh6QSkWAlYEFMnEzulSH4 PRgDPF8gkcn98Xy5
TAKIFy2V18bz5NJoUIIwPt6bgOLj5XExr4txAlIma1L1NiPSp6YkK/FP+WSN 0VRgwwjmHprk5/Aa
Iy6ttjWi6tJio+Y5fKqptH3QNokG20tNqc/h9QXVg2dsc+jMYHWB/jm8ETdO ztkeoLnJBmx8B7yh
uAH4+yxfbHg+f/qq7Wt09XT9s7xMjuNRelHdqSu2v6Arp+qL0gHDmVrkJRIp lqG0w7UTn9u+Qp9P
1BbqsRzJpM/wBTUTl2330OWJ2sMv4Mcv2e6iS+M1vyzPTiOwFKUW1Iwt8gVp oJdK4lgefv5jMZYg
Xb5/gR7zF6SCPA7mHlx2dgaB45A2b4n35WlxHBaRgsXcQixGmlzfEpurASwU Ct4xPbIw5sK9EUgo
V6rUOAXlmBsnLtnuoEsTjeYcwGpVklwIfLggbKXAy47JCBijAiRXpR/KxDmI KW2fvGy7jS5Ptpcy
gDMP6VVy4GEMC1aCHuTcmFboC+1HcQWqbR06d8V2C105d6K1FvBRe6FesTDm I6B8iwDDFApWWEDG
wGoRIaXRXteGB9Dw2NlLV23X0dVLZ8eGAbfVWY1KL6uOCPMS/PD90QJzrOWg JZY+iJQZJW2D+Aya
PnfxypztCzR35eK5acCDba4Mpe8gXxC9PxxqGAH3V2MZgSXWIqBjUXJmef+U 9xqa6i/PTPbGooMx
0YKId6HCMGcVy+DZrtICk2RkKPQOnvFehZHvLTSUKZEiHr708EEUDXdtF/PE HMSxSCxVatMYoyWD
NqICa/3wWe8VdHa4wVpQZkRpmkSJEBrrQHTUQp59B2KioQyJ0lhoYUosLroE VdR0jp/1XKIvo+mJ
rtpKxuUoQZbCdIUYR+MocjFbZFQUjkaylEJPfVkH6u4fnZrxXKAvonNnxgZ6 6ICzA9V7ClNkj7KQ
EftwJD6AZFqmvrPsJBodn5w+VzaLL5CzsELnZ6YmxvAIPkmOjNhOos56s1YG 6sjI/U9mjtc7jp8M
nHOdd55Dw+0OfTyOYiXhW9+WBG0N3xcZCTg+zX5ssPOsa9pxFg0es6U9o9m/ H0cime5IS//xSQx3
vCdtUxjufk/B93Z/i1UnA3b//r2L6oi9+/B+JNXAgV8YhUNjNFLA+/Y+4iP2 4n0oTlXsb/MMWgZc
sJQPojZfsUqM96I9cF+c0+0Ij9gDWKwqqmop68O9ZB+scB/Z22t7CpX1oZaq wmQRhhG5Z/dS3j3h
gIVJBRVNnm5LlwuW8m7UVHE4SfhOdbt278Z7UGxCtqOyrBE1NR/rCFCdvK6u TgeE+3R2UZ0o0NHW
3ARcpSMrIRbvwbvJp7LGSNMpR5kHVfnqW9roDleA6UBtLfW+KrA5qHRpzOMs G7bs2LUL70aRsYq0
Q2V5qMhcVtPEtLna6TbUVFNqLgLboTRFbCRodsHzgg1cnm3bIQwRhe+F61MZ e3Wmyv1UC6+1tYVu
5bW0tNpbkL+cMmqAk8Ud3LcH70I7d25/Ku/u8H1RB8ogVEmd56qmmyzNziZU 7cpXy8B2IGrfnvCn
82zbzuwo34miZZn2CqbR0uRoRBX2Q7Jo7060Y/tbV/FDwrbBc4/yHShKko7t 8HVaWeWrq2ca6HpU
V+urqgSLHeslUTU7yLAQ0K/bGLad3sbbvn2bezuKEuvyirENOVweXy1dz9Sh Gq/H5QBLcZ5WHOXd
Dm62ha2Dyqz6FPwwW8u3o0hhYkoqNqLsgiPuaqqWV1NTS9WgKveR/GywpqYk CCPZfDu3f7qKvVjs
2BAW5t2C9kQKBOxFSKHJtbttPuS252kU7EVIEB25x7sFh5E7uGvFyh3rQrwb 0JZde7hRI0w4ZDlq
86KjlkMJQsB7I/bs2gJ8yLpVKwUjBLlhE96Mt8BXYypVYqtCJVSqIALw5s2f bdpw+w1p9Of1mzZv
xmHA64odtkrkKNYBH8by6//8NF9kt0E7F2lj9+DN6LPPQpf4zz4DvOdgyuEj Njc6cjglJhx/hjaF
LvEbQzcB3h2tLrDYSpGlQB29+/l8vtl2FJnzVQd24U0odOOGJX5jKOBdB5Lz GJsLMbnJB3biULRx
44a1vwi/FgSAdx5Izn0Bv2E93oh2RCUt8VE7AK/f8OkiH/Lpp3gD2h65xCft 34bXo5CQdSxP/nkt
DgG4bb/yF6fRR6vXhoTgT9HWCLkh10ajXIMsYitg4Fd/9AQftluUYrCZkCFF tDvsaX7dOhyCNm3d
K5TaEpFUuG/rJsDr1q15it8QumVXuG0vCt+1NXTDT3loq9DPNtugT34WumH9 U/wna9Z616G1a14P
r/z4k3XrvGsh/9qPV8JU6U+rPqldw/tk1Z+AW/Hfq9at9a5Ba9et+e8Vdwj+ mo9WfeJdzf9k1ao1
9wjemj997P2I9/GfVvxIvPjjfvm0LuAeD3R7uxA8ZXQHwKN7vAtwD+D2cTfg 8a6eLg53dXaNA4bn
jt093m54YAmPHaG2Lce7a3t43cdbgOvq6QGuD7junq7XxVQfr3/whGOYd2Kw n3qGw32of3B4bMJ2
Ck2MnRzsxz/lB4dPzczaLqHZmVPDg8/hT4zNXL0BP4FvXJ0ZO/E8fnz25l2Y VN29eWH8efzwqUu3
79u+Q/dvXz41/Bb5VrYdcS/Lf/k18F9/eQn4XpYPtD7Nz//F9lf0l/mLz/Jd 3bgH6n9h/ivqIe+v
f31IcaqJE5g7W4uqQGcn7kZDYxdu3WO+pR+ir+YvjA3hbtxJPiOAZqC/Yb5F 927NPiEgWqkA7kKD
o+cf06ODYAkEOt4GDxU4HujAnWhg9PyNRcXN86MDYOl4QnEcB1D/yLnHipF+ sBwPtC8q2trbcQfq
O/lYce5kH+7A7eRrCcjWAG7Dx1Hv8MxjfrgXLG1tx7gSapta29pwO6u4fodT 3L0xA4p2VtFU+zYU
I+xgDFT4vbVQ386uLu7kzt64wzygv1nonmDpYk8sKPwVpe6AF4ZroNbv99ZB jp7+ATyERk9fvHUX
38cPyPuwQndvXZocA/NAf0+gFWR+f3XADdkCtXUNDUxjeT061jk0fgrmXTMX rn15D24e3Pty7sIM
4FPjJzqPedlfKjW14Ihf4W9oYho9Daite2z6Ar6Krl2/dece3E24d2f++jXA F6ZHuttqGkh/BVst
f0NjE83K23vGz3+Ob6Jb87fv3oObC/fu3p6/Bfjz8+M97d4G1NjQ4IcakbV1 uJFu9jSh472nr9z0
3kM3r5zuPe5twg1kXe2b86i2rr6hgWriNbe2udtRz9CZKze8d9GNK1NDPe52 XlsrxL8jCE5ZKqse
w2/mlvbO7rIeNDQ6M3cTxDfnZkaHAHcF2lqgXFbuYw+2wlfL5kDNbd1DI/YJ 3vj4BDWOJqcvXbvJ
3LbccdxGN7+4ND1VNoFGhrrbmjHXqGxOssKH/bgWNbcPnJ52XqQvoIuX527c YuYtXzrm0a0bc59f
KruIpk8PtjeDyu/3LbiDkAkfrkHNHcNnL9qu4TnyGqzQtS9u3OSyOud5t258 4b6GLp490dEMQp/f
V8l5q8Re7EdNHSOzc4551y0LLJ55NDc70tEEdq+3+u3LoLZV1dXYhxqPnzx3 xX6Td+PGTccN3s2b
N+gn9t034ZbD8PFG7MPV5FLpVdiLGtpOzFx2XHd9YYHFcx1dnjnR1gD2qqpK rnSnu4JVorrWganZ
C1fR7NRAax3gygqP28nx5R4PrkS1zX2nZ5yXLZcssDRfRjOn+5prcSVEzbMy 0unG5fBrvKapZ+Ks
86LlggWW5ovo7ERvUw3Yy8vdC6W5ysrd2IN8jd1jZ5yzlvMWWJpn0Zmx7kYf 2N3lbtc70JFOFy7D
5chb3zE0tjDdhRWaOjN97jwDOZyzvPMzZ9xTaGyoo94LwrKy0sXyj5aWYjeq qjnWM8iMWEbpkYXZ
P33ecs55Hp2bnpwYY0YtI/QoGuptq61+Ii9jLzl6FJciT1Vt8zG6w8LO/rr6 Tp46Q83wpqdn6Gne
zMy0fQadOXWyv5sOWCBkDLW31lV5cBk6etS1WIbDWYJdqLSsotpb5kcNrd0n J7xn0MTJntYGwN5q
T1kp8CVOp52B42Tg/QRcglwQs+Nmyh3QMA2BoTEvd2ANPsZjKac9cDLKjh5d ysQ6sdjgxQYnr6TE
aS9BHl/b4CjkGB1s83moEh68gUYvcQ6H/ZfKwS+GwKASu8OByr0tnf3UCG90 /LRjknd6YhSCfPo7
m7zljMPC8k6nw1zsJXjFZqvfgcqqGts7cT8aGBoZP2U7Dd/CJ4cGAHe2N1SV 1ThIVgr3ea0OhxeC
izwwncTN6FhH74lR2wQaPdHbcQxwfZ3XUwa8w2EtNoBeb2PMZqfFYUclZW43 29F9de0Dw7ZxNDxw
vM7HdnB3WVkJY7ewGpvDatOzlwi9rbjYyyCL3cmdRI+3tXfINgYdpcXrWWx/ i5fBxaQ+AJeuAopm
zNiCSsobugZso2igq6G8BLCZYaiC22/MkwUUprEZBnR9Z7+NbcJ6txMwTVML 2QsxTWEGOdz1AY4P
1LkdgCmaKmSzA48xjWyltUCfZOlSG2CMi5foIozREZf/eK/tBOo9XuM6Ahhe ZWFplAnhV0W4mOXb
e4DvafcDX8zyeZkL/GEoAVlKfG3dtiHU3eYrsQAuPFzwC/H5BYdxITI7l3iv 0wz4cAHHk5l5OB8f
hjeFvAv0sWoHjQtQXn5eNpcdosXyANMO77FF3k7hfJSba8rmsmfjXICUvXqR rrJhnIdN5LtloV45
JhPOQ8VHPA1tti7U1lBuKcK5KCcn+ym+yFzqa7C1ogbfUaZwgV8qPQdgQfGR o+Vwk6D8qLW44Ins
Oggjy8EmiKUrps22I8hMFxWAb5bP0D3B5+YVHC60sa2dn5f7NJ+V7c1B2VmZ r4P5esD+bH5WVoYe
Jk46w6G6LNLAChNSDFlZ3kyUlZWZkgDCcJPO4M/gGwymcPbBGkC9V4f0uoRw wctmeqUvm+lx5WTl
gJecLEM4+wAv3JQJOBsw54dvysw2+XP5JlOmia1elqkun8xiq6fPyc3L9+Yh OPoc/VJ38S52n9fF
dAGRX5JLwPYn3S4/P89kskH0oCk3Px8/h8/LyTxky0CHMnPynsfnmTINelsq 0hsyTXnP5Q/pU21a
lKo/9Fw+NycjVWtTQyyfMSf3t8MvDQ5TtkGnsamQRmfMNj0alY97f07WEm/I yuEGz69NLw287Mz0
JRYs3MB7DXpp3LG8NgX4FG068M+MO3ialXVIv8QfysLcOHtN/lBmFs5GmRlL vD4jE3BW5lvgRx4P
WKPBeCgDZ6IMY5qG02nSjBw+dMhgXBrQXm6463x6wkClw13adL0uRW2DANIU nR4wlU4YfHq+LsXE
Pg2DctP03nSUpk9LTcVpKFWnUatADPGhOg6nAgM80DoT6BN0aQYjY7CkOw18 fapGjTUoJUWt4rKo
1CkpWMNXa7R6nwHqatAlQF2SNXqjGTI44FVJvZZR4WRHEk5mVDytPt3Hvhyp SYZyoWoGA5NhMToy
kAEqrPImIRVU2ODNgHcp9bq3JSF1egyNQBsYqBBKT9Oqk0GTrNampZcZsJE0 wArifPVPaJHBAJhJ
c+hRmk6zqNfo0sr0JPsC6GM9UkIp8MInD4o1axxapElRJyd5lSgpGYKC3Vqe Lg1YVq1VcmpdahqG
QlO1apWTbZHkpMQShQUCe3kQVevmTsKiIvXpHBDZm+RUmpMIpQv0ZgWRWA5e 4EifUXOnEIpPSnSC
jtX6FSgxSa1dONXad6pjK5loS8AKMgFWOIFUKJ5GEJCRqFRptDgVgpq1KjYv QB2HNapEhTPekuCC
xR+PFInJKRqsQxBjzepIpQpzMCVJkeCQW+JdsNTIUYIiSZ2CtTiFXCiN65Fa lKIGmVNeKXPJyyGc
OUG5KFoqiu3FapUyId4u40mlsnIpDwKgHdy+W4rkCcpkTqFWPZUhOTFB7pRW SlzScgmSyhUgSmFF
iZK3KUISCMoGzFYwXr5QQbPUJWmWIll84rPKZCgRqaC8eKeckWFpicTJHYwb omhAvcAmLajZyG2s
QmxMt8KZwLCxNBJnXImEB6HY7nhoy8RF/pFemUQl8+A9Y3OiQ4ES4uFNJ6+Y fRMqPsGpYBJ5yiTg
ERS3oIeA8EQmyax0JiJFgnxJm6BwJB6B0HA49YlythEkcsw9FHcoUaJiUQZ5 E51KxzsQoWhpQiKM
MAv0YH68VCzCYgjLEIttsEOKYMUXiaXxJQoH+wJ1ojSafUwlWcih5HLEiXEc DXIatnxxnAy0TniR
WymB711elEhqToCiIVIGQmEkEBIikcRBMLmQ5oLeJZxFKpXHOxJKEvnKBFEU lB+ulkDYk5wlZDIu
CEUiXsgCOaScRQanBhQQGKUOZ2sUrhZI/RKeTC7ngm4e6+HUYTiRcpkfOpIg KlwwshCss6CLEwlp
ASOEQAQJWJbCdX45xeLRSEFhEyChCKr7nKAc9vCFDARUsC/NLVringrLkUBo v8AGvEAkkSzF3TwO
y4mDQH94J4AH/waDOohiBSJxHFjFYtGvIFqKBQL8lAqsYi4i6LVFS5E98FrC 0xqhaCG+5+2K4EFn
rBA6FSFkOAV9kAcKSsTxEb8kXxJLCOin7AIBLSQEnF0IneAg2BcjZuyPyoo9 SHEROI857z+NuTgj
/0IEEbBhEVECwWIQEpBhu6ME/mi+IGo3oIWAqaWAqNuLAVeLAVWvmGtlcS+Q bAm+QBJMwRRMwRRM
v/3EX/bBHz5c8eL04R9+v+xd/m+RZR+sWL0+7MVp/eo/frCMeHfpgxVhCmPx i5NRsWXFu3wn5A+r
FWXHp16cjpcpVv+BeHfpw/XG4zMPXpxmjhvXf0i8u7QirHjqwY8vTg+mcNgK 4t2loP+g/6D/oP+g
/6D/oP+g/6D/oP+g/6D/fxf/r5rfh4pKZx++xP/D2VJR6BvcH3jV/F5kaJj7 20v8/22uwSB6g/sD
r5rflzZM3v/7S/z//f5kQ+kb3B941fx+du7+9/94if9/fP9gbvYN7g+8an7/ 8G9//8cPL/H/wz++
/9vDN7g/sNC/313ixkfQf9B/0H/Qf9B/0H/Qf9B/0H/Qf9B/0H/Q/68+//u1 57+//+MWhRG/OMH8
/8H3L/H//YOphtKX5If5/x9//xu+//Fr3/8hfuX7X0TQf9B/0H/Qf9B/0H/Q f9B/0H/Qf9B/0H/Q
/2vdH5h5x/Hff/iV49+5+wNvML9/07TsV37/gf8rv/8RTMEUTMEUTMH0b5L+ P1BLAwQUAAAACACq
e3A0NBICFCkBAAA+AQAALQAAAG9yZy5lY2xpcHNlLmJpcnQucmNwLnZpZXdl ci9pY29ucy9zYW1w
bGUyLmdpZqWPTUvCYACAX8uP2sH0kqUdCoIiPQXBwoosV3OXhLZc7/rYNKuD Bw0KLPBUJ5UImQch
2EbRZYMOXqTLLm6dIoh5WJc+L/2CPC39DT2HB57jsxpbQWc5D/AAA4CZExI9 TaD5RLgA5wpw8WIn
WkxipRTWcTGFlZJE5YCoHK7VMvFahhRzlJgjxSx9d0xJuS05v3t/ti3ny/X1 cp2sNqhqY0NQaVGl
ZR3KOqPoUNGgojPNFqu12KbBakbH3PNryvxIm+/pt+99y7LAPxhr220ABEGo G90n4GRUPouH/Jc4
l96MuYNT1EtDuokP/hBH/OiE9/EzujD/NCAtj09fmbfeh8je+ZLgnvxq//qi zn4ECYwEAkify4U7
hv0OaB/y9UIb3wPBNYCCEAHhP1BLAwQKAAAAAACqe3A0DYf/8K0AAACtAAAA LQAAAG9yZy5lY2xp
cHNlLmJpcnQucmNwLnZpZXdlci9pY29ucy9zYW1wbGUzLmdpZkdJRjg5YRAA EADjAAD///9/WFBQ
WFDQuKAAAAD/+P//+O//+KC/2L//2FD///////////////////////8h+QQB CgAPACwAAAAAEAAQ
AAAEWvDJSau9NYixO/8C8QhFaRbGkaaiQJ6FKhNiULzlEbNIW76yGOEwqJmA wkOiNzoJdIdhguj7
3VxRJTOgExhSSuWw2PSGp2gCUxBAuN0DRDweetDu+LwIw+9TIgA7UEsDBAoA AAAAAKp7cDQ40W3C
nQAAAJ0AAAAtAAAAb3JnLmVjbGlwc2UuYmlydC5yY3Audmlld2VyL2ljb25z L3Njcm9sbDIuZ2lm
R0lGODdhIAAgAIAAAAAAAP///ywAAAAAIAAgAAACfIyPqcvtH4CctEIkb9TA dEttHTSO5FGZXsZt
KFNmIcuujQqbpYMntX6aRD6v4qPnSip5CyTyNiQqaxec1INtYXzG6nDK1a6E 4SqQqY3JhM/mEnpL
heA5+Trqao/nR57d27QGwkb2JGjRFxiFiKZwyAcTZzdJVvengZlpUAAAO1BL AwQKAAAAAACpe3A0
AAAAAAAAAAAAAAAAJQAAAG9yZy5lY2xpcHNlLmJpcnQucmNwLnZpZXdlci9N RVRBLUlORi9QSwME
FAAAAAgAqXtwNOBWAut2AQAAzwUAADAAAABvcmcuZWNsaXBzZS5iaXJ0LnJj cC52aWV3ZXIvTUVU
QS1JTkYvTUFOSUZFU1QuTUaVlMFOwzAMhu+TeIc+AI2A4xCHgXYDNDFpdzfx Oo+kCYnbDZ6erqWr
BiXrLlXl/8tvO7byAgWtMXC6Qh/IFtPkVtxMHstCaUw78ajddcorGJwmK8Id +mShyzylotOWnyaz
mmTLWJ8LlJpcQJGRZ+GlE1Vz8D4JVOQaubZ+YF/ij8NJLX01TxpCWABvpolH Zz236cUWfIfMJFMF
bH00r2gPHsruq362EjR9ATeJXavN94c86QLkO+TxZiZv+FGSx7Tx+8WWdH01 OYlI61H4smAy+Fvb
oHZDMQGu/vUV+kE1gzBo1Wb/G95hVhv2Ut/WUEzIDdRfhRVJFLhnLA4zOo+G Ko9AWNT3jGeBUQnb
rSBGE4FKiorxRM3YBgUFDP8Kwqq4KECB43ozFQ8M5Nhaz6818Jo0XgTX7Y3i tyqTo8GxpgGM06iy
i+Cx5nujx3Ixy+O6nScEGuLDxDZs9AW4U+sYbazCmF332MxbKZ2VbJdcr+40 aR7Qb1BLAwQUAAAA
CACqe3A0esrm6PoAAACRAQAALQAAAG9yZy5lY2xpcHNlLmJpcnQucmNwLnZp ZXdlci9wbHVnaW4u
cHJvcGVydGllc1WQMU7FMBBEe04xHVU4ABLFF9BH6Je/2dibxODsWraTAKdn nRRAY8me2TezpkHX
euXP+nSdQ8Hbc49LSjE4qkEFOxVMLJypsseYdbnJ7a7OjP7lFX1cpy4I+qzv 7Cr28E3ZP5jFTAev
0JIio8y6F9iBqo9N7EDeg+yausgbRywsK0i8PWkcKBusziDXapTfkQ/+GoL4 IFMx53/dZbaa2ALv
Js5U4UjuKwaGi1rYN36zAssaa2jNgpRK4rhAR5vh1vhEnMzEuSS2lM0sR6UU yfGs0ZuCUTOE9zPz
nFgLHyDPI1kKjh+GDxR1+tvTtk9Z/epqswYJbZOb/ABQSwMEFAAAAAgAqntw NPzZypPzAQAAiwcA
ACYAAABvcmcuZWNsaXBzZS5iaXJ0LnJjcC52aWV3ZXIvcGx1Z2luLnhtbMVV y4rbMBTdD8w/GG9L
5T42XdgTpoFCoC0hpKW7osg3nsvIkqqHk/59JceJ5diEurOoFsa6ukdH51w9 8sWx5kkD2qAURfqW
vEkTEEyWKKoi/bb99PpDuni4v8sXwDgqA33ue5/bDinuKhT+7/4uCS2HowUR knzg3LAsUqoUR0at
H0mjISVR2CKVuiIdCWFSA9FOWKyBRDCTPpyBeRQ+Bbu4h3XdvjFOjRlS7FBb opkiDcIBNHmMFjeY
L/MT9qzZkLYNnfT2gUv/tkiHRHkzFTCLDcTSovBQiqA1FOn3dsXJus/yds6U Owb3lbqNVBEy8iUK
v9yXQBUbEvpTTmxASW2vBFDO5eGL4xYV9zlWu5FEFjZw+JrM0NqnvSMV7ue7 +JU2WLV7IdRkppFi
AI69DAl/Kz5ZU+271tv//3y4rOEfbFA9duzCnK0UiJSWpWN2zvXSQeLt1oWG OqKDf1vQ8Job1+3j
arNNNst10hXwdJw7+n4F/kDZ321sPAXdSWdXNa0uFe1bQ7mDc1V1S/EzOpxt gbM5ZAcUpTy0bOal
dHnWeTunsNN3xA5FeKXiuj3DlQYm65qKclWO0HvkQOCI15eHYU9QwwSghD31 Z+mRMeCgqZV6KcUe
K6enKm3gl/PvqDdmud18fvUjzaYE+8czu7yefwBQSwMECgAAAAAAqntwNP04 HY9XJQAAVyUAACoA
AABvcmcuZWNsaXBzZS5iaXJ0LnJjcC52aWV3ZXIvcHJvZHVjdF9sZy5naWZH SUY4OWFzAKQA5/8A
AAEAAwYBBwoGEBIOFRYUGRoYHB0bHyAeIiQhJykmNRJ9NxN/NhZ4MBh+OBSA MRl/KywqORWBMhqB
MRx6OhaCOxeDNBuBORt2PBiENRyDNCB3PBt/PBqGNx2EPhqGOB6GOyB0OR+H MjMxOiCIMzQyOCZ3
PCGJOyZxNDYzPyKEPSKKRB+LPihuPiOLRSCMNjg1PySMRiGNODk3QCWNOy1w Qyd8QStxQSaOSCOP
Ozk9OTs4QiePQyiQQC55RCiRQjBvPD07RimSPz1BQzVnSyuIPj5GRyuUPkA9 RTRtSSyVQEI/SDhg
Si2WRD9ISDGLRDthRjpmQ0BPTC6YSD9PRz5ZSTptST1eRT9fR0BVTjCaRUZE TzKcUTOdSUpIUzWf
VTahUjuQVjeiVTmcTU5MUElfWTmlUkODWTygWjumVT6nUFJPWzynXj6pWEGq U1VSYD+sW0StYEWj
V1lWYUakXkawZEasYUiyZEuiY0u1XV9caEyqakuxZk23Z065bU20Y2VibFOq b1C2cVK5Z2lmc1S7
dlW9c1myc1ytd1e+a21qdlm5elnBd122b3FufFvDfl3GfGDEfWK8fGS3dHZz gWDIf2i0g2LLf2bM
hmTNenx5iGbQg2nQhG+7i2jSimvNhmzTf4F+jWvVjW3QiW/XjXO7i3LGjXHN i3DYhIaDjXLajnPc
jXjFjXvBkHXdiYuIknfglnrkjY+MmH3ml4PMmoPEm3/pnYPZmInInYHslpiV n4PuoobxoY/QpYjz
o47ZnJ6bqIv3oKKfrozyqZLhq475ppjSrZD7qprOspD2paeksJP/rpvgtZP5 qauot5X8uZf+ra+s
tpz/uKTTt6PftanWvp7+srSxu6T/waH/xqL9vK/ct7m2wqb/xKj/wbDly6v+ vsC9za3/yLD/zbH9
xLvjw8XCzcHiycvIz8Ls0NLP2Mvs09bS2NDq1tHw1tjV39jk293a4Njy3+He 5d/02erj5Ofj6Orn
7uf07e/s8fPw9vj0+fb7+fv4+/36/v/8////If4VQ3JlYXRlZCB3aXRoIFRo ZSBHSU1QACH5BAEK
AP8ALAAAAABzAKQAAAj+AP0JHEiwoMGDCBMqXMiwocOHECNKnEixosWLGDNq 3Mixo8ePIEOKPBgg
wMiTF0uqVLmw5ECXKF+uLODmnEF+ubQQCDBAByh4MksSUGPT4cqVLU0KhBnT 30oAUAFsIygPQtSr
AIJeBWdU6UOmTQm63LdvnRwAIgbus2rgVz1++M65giBT4LuzOboi5IcKAs8u zZZ6ZVpS3h8CAnQU
1TcJyIAABdQEFthMy+MDifApZEo2AIB9AnMBMGCPrGnTgv3187cPgNekB/cJ waqU8GCsAATA2zcJ
t9I/uBPkS8i037sABljLBvALNHGl/erx7HrUpKsABKzl2wcNSOrvTgH+5EnH z50MAH/8Qd2Wj9+7
Xyj2/QJwANr2dFoAZHouUF85HQBMMhABANgDW3mzjUHdUf5YBQ1oZNX1XWuf mZYOffsQmAuEEOYA
gDyrkWUPAAk855lrAXTBj0AUrrjZiZ4RkI5eBVEYYUG2DeQaQft4tk8ung2g RSZFCeDZU56ZeCQo
qGUYgIEvxqjGO84xBBaLrulD0mBKtfZaawKQ5Q4qXRAYQCzqoagSVK/haNI+ sQBQgDxqAcEcbGSt
9lWbrDm4pYROedUPNAHkpRxZzQBAAD8eAsVjlQbBtM8gAECgmUCujFbPiwTp 2dCVrGUipzX65GPN
EeDZtg1Z4BQQgCv+/pDwizz87GMNVP6IhkAwb+mzTi4o8McaP10AAISW++Rz wGhu8ZPPObHQBR6k
Vlb3plVYpcolilDpQNZVR47RDz/A4ZYVQpztIwIAcgz0zrLmAhqRtQH0k2wm fhGghTXaytSIAchN
4pw1Y7haqcCmbTMGwAEkMAhX6Aq6jz0GANCIasm6ksNOBOSACp3gZcThadRu SbJaJFeZMmoPRagy
hKwpFxaNCLHDiyR6sBGGF16EEQYabMCxhyKlFBPPzEiD189q87BShxRMZLFF FmJwIcYXaZyh9Rlw
wEGHHXvsAYkv8yQdE2eriBEEEWtLIUUWWXBhtRhopMEGG3XkvQf+HWEHIggh Y5ds9kfk6IFDCjgE
gUMSbku9xdVfhJH1GXXgvccbe/Thh9+ECKIIJKaoMzhI2pwBww48BBGEEUYk wYQYRHDxeM9n3E15
5Xv4obvfihBCCCKLLAKJJ+iMvhE7ps8Awwyoq946EVLIXnXWa+D9Rh2Y74FH IH308TfwwV9CyfCm
HG28RYy00AIMLswQQwpsr974FlvwHMbWetuBhx97fI9IH5dYhCMccQlHQMIS l/CEL843EWkEoQMm
UMEKYHADHvggcURgHNweJwYxpKF6eGMD38JGiD4oog/BC5/4LoGJS2hCE5sg HgMfcogImiAFKmiB
C1KQugsyoXH+YshCz8SgtTq0oQ57qAMfuPc74A2wgARE4Cam2IlPbEIUtpjh Qu4hBhN4wAQrWMH6
boCDHfggCElwHRGC6AUiAu1ueVOiH7yniEUAcBGXeMQlLmGJTXTij5/4RChC MYpRiOIeWjTIPrTh
gS96AIJhpGAMdqA6IuBgC2+zGu0oRzk7+GGJguiDEyFBwEe0EIaBHOQnTjHI U5yiE8VL5EB40YFa
diAFJsjl+mYQhBT4wAhue1sHaRe0M/jhDbsTJSJI+cQ9biIUqRTFKFJBzVaI IhTU/MQ0ZOkPVizA
BLXkADhxuD7UsQ0HjRNmGtCgtTdgrg5gE8T3BLhHSrxwE4L+nOYpRGHNVrTi FfwMxStSsYxEcmIB
HchAB1bQAQ+EcZc32AEOjMAEDcrNC1+oHd7qQAc+zLGOd6znJVKJTVWEohWw EEVKX8HSV7RCFSYd
BgP3wYlweiADucxlGNt3gyCcEXpSCGIH71cHyiVxc30gRAoLeIlO4HMUp0iF KqwJi6paFRYtVSk/
lyG4sLAioRiwpS11OYMUNA+YUiAC1bggOTac4Xp0mKM8L4HCPbown6eA6Suu yter/rMVodjm4I6B
gQpsQKENTQFDI9iC9/nAB0QApuPaSES88e0NTFRqAR/RxyqGAqb/3KtVayGL qtbiqi2FqTfMZo4P
ZOC1HGj+qGxVEMEZ8OBwiqMo3Kz2BaAVdQ+eDIRSUUjAS/gRqgAVLSxqYYta 1EIYphAGLITh3NNi
laWEbEfSXGCBCmBgA2HdACQjOEHU/dII0JMaFyL3QTYgM7hKLSUmNBFIqaLU tNWtLnVh0dznTlel
LgUs0s7wgQW89rViXagYl9dL1UGtam3En96Sakc8GvcTozipSmuhUulS98PP 9XBfq8pPUYSFEw3I
gIExwAHxNrKW5HVBBVeHztcJMQxraAPewMY94BWQEpbQxGfvu9wPTzfEz01y iKVrXVj4MxUyRQk5
HrAAw2IAto+EYC5zCINJru6HbvMgOykHhzmakLh7xPD+KazJYee+4sPCgHOc 5+zcI1d1r9cUhehO
EoQMWODP3kWsF2u5ghzeoII/fZvU6OZW7O2Be+FzBCb8yErTwnnJwthFL3bB aTmTVhh7bWkrTvGJ
k0jCAgvoroE30OJabiCMHVDB6Xgov91erZ1IzNxw7dqJUwDUtEeecy+EAQxk GDvOwwYxdIVR2pSq
YhSdWGBI2KEAFVsgAwyoQAa+K85a0laHOOAB/FxHNarhuHId7fEiHkEJ405z r85V9i6EQYxoCEMZ
xsA3MuYc51rMW7mv+KxTzfcRMajYzxi4srazfEtywsAHKTDCRNMqRC+soYh9 O6Ej9FjFvN5ZzsAQ
RjT+kBENZZB85CUPOZ2TTGJrhqITpvjIPo7BABVL4M81v7J4vejQBVuQdVGL mxfWuVE78AHNBCSk
KODtYWIjQxlQV0Y0osGMqUtdGMYgRrKpS1pT1MKlpxiFJjCxWo/g4OCp9i63 M8CB2ILTBGM0I3qF
GWGNfhTNncgwSt8c4pBP/e9/d0bVqz7yfhveuqFgpRUv4ZFbVNvAqf7ztVsN TtpGEtHozEJQveDb
vM3RxxzfZ1U9PO+o//0ZzwB8yaVODGIY3qq/HsUnNGEJSgh2IyuwgAQysHtV V0DbChVnTlvgvjMy
4Yf0620Rj/43em5iFCgVRdNLTvJqPKMa1bjGNbD+gQ3sR6Ma1I+GypVcVUI6 dY+P6KpE9uF4BTBg
AZH387Y74GIPbEAFErxBCir5tvqJoXpwgETdAzyUgAmdcFL4lWkiJ3XYh33c x33eB35TR2z9dlrC
sHTY9AmdgECQcHsYgQOA9loLkG0bYGWCtgKMhWhJgE5BJQaSczt4IAiIgAjO NAq/1ncLCH7XkH3Z
0IPcwA3bhw1WB3UK2G9WJU2dgH4GpBHUsAAK8AAKcG0V8H5/xnaIpWA3FAMz xgRqJURncHHIhAd4
AD5BhoDxFmfGMHXgxw3ZwA3d8IZumA0QKIFSN2+ndVoYyEqYQAmPEDzkkBFi 8GdRCH+71wFVpm3+
4gVB3hYDvBRxQWc17LRRfnBCFvYJqZBSzrULwJCGatiGbviGb5gN3cCG3kdy KleBTpYKi7dHi0CD
GDEPEhCFD2ABG0CI8sdilEdbOWRbbKNB9cNO2KMHSQU8fRQKG8ZsIicMzJB9 1yCK3xAO0BgO4gCH
2bCD0eAM9jZsVeV1otCNs0cJBIQIvoNIFlEJUagA6PgAr7V7BnZgLwZGOTRJ E+U6VcNoZ7AHR/c7
e6QJ0FdVshBn9fZ92CCKoBgO3/ANoQiEdKgMp8h1WPVy6Bc8/yNtFcEDUfhn DyAB8IdQC/BdtvSO
KpACM/BYbRM3HsQGRzSANDhS3ZhkWKcMqYf+DdfQDc8YjdE4jd3Afd9XeMNW ZwHXCtCGQJcwgyck
CBZhDueIjgpwWK9lAR2QbQk3VoXmPnL3YBhVRGBDiZx1Unv1j72ADNjIg28I jeJgk6Aoh+AndeNn
XapwClNUQBLpPX2wZxLRD4fAAJIXixqpkdfGlGEFTgu1i2aEA8cXNzi2BvCE B6K0R5ZgjK8gC88F
DAxYDWNZk+NwmWUZDqIoh1aHDMAwb/+oVS8nlMCDCIIQCHuwChTRDzswgkoJ hQfXXRJgWIiFggtF
fJSURsJ0P1qDVEr1CM90X3NWctHAfWM5DjYZjQgJgVVnDKiYUoS0CXkUPJ3T B/jYBxTBDqj+VnMW
cI4qtgAa+Vob4AGthkuCmTqvkwQuWD1vYAd+gwiOQAnPpFKwIAvAQAzOcH1s GI2X2Z/QiJA5mZae
+ZxA+QktFEB2dEJhQwcEBxGscJHo2J3Yto6G+HuI9WIStAO0RgRRw1a3oz1J tUfGKAqy8I/CUH3V
gA0FGQ6XCY3ICYpC+HeZpmTXFArS6QgSWUKBYAd5wwsRsQ/9IAboWHPnOIKp 1nvblojj1QK4RZhv
g1H3IzTDKDwHWJ/+Rm9Shw37aZMtWpZyyH3PAHWut18ABm2asEczmFRhw6N1 oAgT8QEZKQF4GYUZ
oG3wd3DbplCAaQLLgwO/lF63tmMxKAj+LPQJqqBSXokMqZeib2iZyGmQNBmg 4Ldv/1hn1rR4ltAH
kCCO3MMHeYOSEoGU6OiE3fmE1aZihnhYLYYBiyVGZaU4wXQ1WSOAorQI8mmM n7YLT1ecbNgNySkO
z9gNbQh+zAB10fBceBZwZ8qK/9MHgeAHeUM5aaBdDvoA1npzEIptBrZ7s8lq CQWYKjAD4UZRXfgF
YnA3+iODeKQJqfBPJUpv0RCTK/qfoLh912hvyGip0LQJloCj4kgIqGkHb3A3 7OSjLTMHStkAFsAA
RboBfGlg16ZQDrVlM8A8KeA2swOM1wk8kIAJxlhkxCZ116eiBUmQnJmWDBln JJZSoyD+nZQQPEkV
CPsTR7UjBpEQEUFgrVBIZd35Z+HJkXUaWwkFSY11RhT1pOfKNfloq5uwT48p C/NGnNEQhKD4hjKp
k1dXgXg4mlCUpnxwOdHqVmFQBxCxD05oqhIwi+moe7ynYqoqXisQW7LGPKmj VlzgBV84YYIgQJjw
CS35j7qKjc/wgMY5kGAKk1nHaZCpVa3wCSvUiiYUNpfzVmeABjvjBRDBDhKQ tqb6hIJopCPIe7Q5
tBK0PhAXBD8kRBnVSTG4TE1lTU8bsiJLuCmqesowZ5X6kKGACQhUq31wdHRA B9jzhVojBl7QoOOi
JQdRDOn4hLHIsH+2AIdlpwjXYnv+qgIuEAOWhANiwATrhQZoQKs+hgmGtFxL BnWod32ohw2opwzM
gAzGMGwlulL7mkcBxKm5E0di+wVyIwbUoBq1MjHvgBCkYK2dy5cRupdAi2AZ gIIpiEFpNVS1Awfd
s7dJd6hdqYnEIHVTl3rxWnLMcIqQeWfSdKZ9mKa/iwdvUDtaY7le8DhSMAv6 MDHykA7gAA0H0Q+A
YKoGnLaCOIvcWouG1QFX1lArkAK4mTixypsCGAiI8AiQwI+q0JXCtsFRh2/i JwybJgvNlVIBxa/t
9j8KGjbXwwZrkAYdFESaJwny8A43/AuoICAHIQY727zud45UppHq2F1FnGWF RkH+ziMF9PMzkkhh
7XZFS/e0mgYM9+mcxMDIxGYLu1Bn5dcJvPuyrRhKn/QGAbg1V8MFcKN5d2AN v+AKk/AHctAFsZEE
O9vKRtqz1faz2xZWKQBjgml8LUg3bcA3AwgJ9uS3S1efcjZvmcZpuzC/XkxI nsCsomSdYVNUKHm5
9ahWUgAGmTAIctAETSAEMoAQMNC5UBiF2Cqh7zehTFmnhAZ3FJQ6jCPIqwtP m/M7BJR3VEWfJfqP
kElapdVsAWWgj4CjrYgI+8MHXcPCPmOucPM2aUUEYyAE3IwCOWAoNeIBT9jK 6KiwRapiGJBqCHVl
j9TAKNhl8IO6JjlmX6OS7Ob+sSWGVfV5z5QMUAEVCss6lP9zml/7qXVwcWnw wlbjNseXBETAzTlA
AiggAmlxEBkQzkq9sz3Ltkj6tgy3Ai6wA5SERkYgBr9oOY8mXJCgR5cwSNaU yLBgCrKwdGYNWPV7
wuIYSp5Ks5JjrlgdTECtOj6AAkWdA0Yt0QVR0Xzdue+nlHv5fu04VhCEvWXV i4I8VGgAB0Y3gMKz
j1DVjStt1oPUsrUHxZBbQs5cOdVzBi4IylTzQysoBT41A3gtAqd91AYRi+C8 szcneRJaZQe2bVm2
ZaeDA4nDOmx0Bm3woaGkVLbKRwdYSKo0SPtqCbXX1cok0NZJBzq2NWlQBsb+ G1THd3xGcEYpAANG
vd1GjRAGbMCdqwANEM6oxnsLW1gZwGpCq1MWawTy43/AOEJMNIOXAAm+HGSb AEN21W72LZHiqJjA
pb8600GPo3lcyAR0HXE40AI5AAHcrdcEYcffDd6CqHvwVwFVGLGN9EV8KlH7 p1tbwFbgWzn6wz3+
g0f2bd98mEeQ4N++0wcAzqYXpzU7Qz8KfXxrszY8cAMwkAIQkNrdfRAWHd4Z 6bkRynsjWAELwAEI
1gFuF67v496AajVExVGZ0z2/00QpFNAzaJqh1D1+gAc8ysJmHAbGKztTk1aE mTi4zYha+OAOjhCt
XdFKHaHdSWV16pQMEFb+UilGHq44rhM9XHAGaXBuwvto3YPlf5PlL57oeLCm +vuFHvQFXlBuUPND
7h0EVD0DPN7jPy4CDo7aCAGedZ6OULi5UNizeAmer/V74oVgKOg+KQDUrdN/ VoM/XWN0V57ovN49
3KM90UrmZ7Az9YgDmkcElmQE+7cDN1BWMdACRwzqQI4QHdAAfK2zdjynFg55 1gZeHMBwcHcDWuin
cyc19rMGwJg3YIOPkouPXxvgeQMHd+NW7MS/aqx5brM47l1Gzd5lLYB/Pg7k qs0jK1Dq105lGH2R
NQex7ZgBWTaxhrZ/i2NRc2O5vAlHXvM1cdTJcFBELRwGlA7aYgDUaZX+BO4d cf0OA/+Ogi1QAw2O
2p+OEEkw3q1c6rGosBZAZamWAUv5lMDHcF8ka2WUBPsHVFNzt0TU2fjDSVzz hW7FBpbrwljdQfj+
0376WMw+Ay4A7SGZSx3QA5/+6QNPEGLQAOP9mhYdznaOjjzfjoEmtOkckuKa 7ByqaEjvgmiwBmuA
Y29EvJVr5h3Ev1Jz6RzKNmzjAzyQ9S4AA4UmQUa8AkiQ16EO4QMBCAxL86Xe ytgKode28zXnrQsF
Y1svrmeEAxyaurtlrpEz7C4YBtLtM8PEBS1Y9Ti+7z6wA4wIAyqPf2AUa+AU Akjg4GE/9gPBCXLK
AAw74eHdAJvfnez+aGBTuG1Mrohbtku3tTZ1r2iJTTUcZLzGSz9YrXmMo1ZA PVGIr+mHpvXqQ1tv
52q19AQRLe1BbhA095oSTufoKKewvHt+ZgFXdmAA0aHCig4rVqhoAWMGjx04 cAQhwiSiFIpZpFis
eDHLFhwUpTABGSTJQ4Y7bsyYAaNFixUpTKRYYcIDQZkmpogQASFHzhz+fP70 14+dBQkSGjB4oOBB
0qQKlCZdIMGCgqkKGCxYYKHCgg4YMGTIwCFDwQ4pEMLYwYMHDh84khBJkoSJ R7oU51IkYoQIRB9B
gqTwcRKGyhYqTMT00KGDiQwrxnLoUEQECZw5IIgAmnlBgwYKjDb+ZbrU6QMJ VqdayLAArAUGGVCP
Hau4sUEVKxLGUBukbRAcRHoz6S2lt16IRh6yxbHDB48bMVyoNGhCeofEMmVD BssTZ+XMQHkwYGAV
PFOnT0cvoOq06oKtDLZm+Aq5A9iCLhEmnHGDRwrjvP3ikAjAh3Tzy4e0TkoJ OhUMa2mx6RSDkAMO
NgBhp8u2w6w7n+LwrKnSQgMtKQkeYMCC00yUAL7WKtAqLAghlM6E2lrID4cb /jICMB/aUitHhm5A
cIbnWDKrNhMUmykx6qjz4KsMNqgAicos2ylDDVk5qqijlCpPNC4V2KzE8kxL zb3WMqhAQiQ5qE66
g1aaIQb9TIr+YQeUahQMBhdWKszII2U8cgMkXwxrA9QquAInnS7sSUN/zFGK sw6R8lK0pUpb4AET
UUNPNdfQ9HQDsSBcITGaZFyQJdtSSIgwPg9akMEYpdugug5qnc+DDTDYAM0K MGCgCQwpu8xRn4AF
T1KrzPtSqdKOeiArE7GSIKvUWIQPrF5ls+4wB6WDIdbaYnUpRpqYJEtXCEXt FcoKemWggwkqW7RK
Y/0Rw6nSGJAgvBCfAg3MEpsiqldrtVLNq/lwVazUxTyYLqaX/pzJXEGXhDA2 yDwAC00MXkuxgwVs
UHQnCxt1lJUHtmxAy0q7ZKrazkzscoOookotAwa8ElTCbV/+3ICgxGw90gOj yTpyBUGV7DU+Xju2
QDX2XHtCBMu2u9rYfdjprCgGOEvW0pc961BTC5JqIGepegWrxI7nGysx7AYd +kXZuppPsV1H3RWs
Cq7lSjWpFhACJxRywtrYfvyZQdnwrOKsKfMsHTOpqTRVYAOlsLIAg/fg80os juWzu3TFJuyVAwwW
9vw117hCLXacL6jMagytdPQQq/r1bF+rlgqYS+AtTy+9nFMrSuS/z3QSLDUh mxADnyV0sgOx0Pw0
NSgPruCqqFNbAApFb8fp3n0gbdmolrnsbHLyupw0g6emSjGqFN3z3FAGVHfy 3XefbNoGmuY5v+3K
U/Lj1JP+HvA3wYElAlGw2oUwhDJj3UABYPtavz4UPBC9bwFiUo9TwMceqYTn V5vq3qc6Z6LVuM4C
NovaC7fytw20plPfq1ZRNMAondzuXkGpxJi+tjISQWtylXNWtahCMxOZbQM5 BIvXzMSBGUqtiu+J
YWpE5poaVkABf/uU1FqjryVc7WqLKt8P7xE5342nZQ0I2PCaNaLRVKU8cIza zRbQOha1xgJbjF32
VNO9J2agWg8wJFGopRobSmUqMphgvXRivsXlC47CWxa03jcagI0GbaxxTVXM ljlD5lBwRXldDAfn
GglUwJTgq5ZqbPbEqNjRAiSjUg+plEbzUaN9JPqQUpD+MkSAbXJsIwIPzdRz yczVb5FSG6EhF6k2
sKjmbA2wwMzUQzMI1qtk2/mhT/rBg/bBkV+Pu+BRtiS8SsXMKVhJih/LY6LO mO2FrZFADTuGlV6l
KJ+lUcrZxpQeZVIFBCI43PgsxJ0f7mMftEjnBYk4It4BlHKe5ORTikKVTNlz ngMlyubQs8RLom2J
89zUabZ5tkTV7mq242U4V3DBMakTcvwyIvAw6qXRrI+Tm1oiitRjTzsStHhA HdOJwhMeDWDoMi9F
HO4Ux49bdIYzYANmaYwSHmYyK0Q81alFL4fSgQZVpSdC6aYwZ8oHUKFKME1o BCmotX30w4JlBduW
+kX+qX/xtJOc9JJWx2iVUBbUqFUBJYmAl0GyleagEuzhBGMazmNc1artA6hR hDnEx31Vcjrta2Oj
BjAG6DM8rIlaiaTyzvKMlDwNwAJMexhZCYbTJ3XtR75oGlGc8uspnEEmszz5 Wa+SDW10fGfLSDOV
zRzSkyO6FOWSwgKsffOpibOtT/jBtcs6BY4sa8rXsgSeYsLsfdJtFvAA2qXM Cresry3CGXcZ2fFl
V5z8OEQ52zea8cQzUsHsLFiLSx6d3lGORyzm8AisgCHI1XazdbBUG+oTHyjr ql0Cj+8u2K/QmPdL
6P1sgWEGWMm9l0snsK52Hnwy+/6kH+SIqHf3u+H+4H5XfYqF38sI7FcF73S4 Cn6tAoRlxsls57oR
lLBt+xHEdOpXUmDbK+SgDC1/+diYIsYoO8uaYwWI78j0rZIE55rdfuT2jjPe 7/riSd4NK5dSgGVn
iXuMYCCD9oI0kC2SjQxTcLY4Myaw8IUv7Bnf6otENxUPiZCCyR8PVMcldrRS aCdmelXprRjyM1D6
gT40n9m7RdnqHJdS6Cpjec4XrTPlgnVpHkYVqlbL9E/2wY9jyPjJgZYxUjSI 0ztSVLHiPfCItbxl
4VFBgrXjyWzpO9kWl5kfWLqjp2Ps3ZVt9VIXBHb7vha2A6M61ZG6wltfqkue LPSlsZZ1mSshaFz+
N1nbW0rWeJbFL//m+ihIgRaVy8NmfFsh2Spe6O3MOEl0u3jJu42xsmRcHuiS mn2+LcqhGc4yXg8T
o50RX6WjumysPbVYBU83J5q8cHefOc0U3XW1wbY7XnvGqvwyCqjH29Jv8nm+ Yd4JZcZc8H5ANOFo
VnjksB25d49HS5rtLUDzitXOUEGyx6YXkmdbJRKAXEO+JLllTR5tIdIRnXnN MMV55xQ2X6CbAc+l
fD1uaauhYOeZLnNQ9vEOIpDc1lu3bDlFFNyJh0eDnTmnoU9gsiPL1Zu7JF8O jjAGq9/2J/yQhzXM
4OQ0B32gymoK4P+ur5cfvYQZ97hTd4lzZOf+AAU60IIcJtF4oPADH+n4xSCw oIGaBv3Wg771b1e2
uyzZ+ygluAlMX8pqxL26MkIYwx9QkQzW/0Qf9wAHKuSgBBEMYdAj9+7ly5n9 mpa4ZejcgPiIH3Db
Ed7wOUB/6ieRi228o/kOfX0yGtEF04ugCSy4Prtx3928L9yqEt2AH4ivqJIt 4os6k0EoJVCDQUCF
ZniHdciH5vMHyHuHWMgDITicy4CAKGAB7EO4rOM+afs/ErEBCJKsZLu0B6sd nXC7LsiDTGC/dLCH
WXu/uWuGSRgDIcgBEngrCGiCHxCvy9q/iOo/IrwgCxDAw2E1S9NAqLo0FHA7 LRiDRHAFaHj+h3fY
B33YBwn0h3xIh2BIhC54AT6bDA18AhD4wIQLwaxrgBOwAiikDOsKs/MTOKvJ AeRTvmAAh3ewB33g
hy2UQH6wh3KIBTlogoSytPmyGiuggQnAtduzsAugASvIuUs7GUZxKVfDCRJA gcV7wVwwh3OYwXwA
RC7kh3vYBlBwAyDAuSa8HQiAxRyggiGgARBwxKW7ABBgASiggsIhn1dEwAsR xgK8wy6Qg0aIhWQo
B3hwqD/kQn9wqLmzBhyEJISKoDicIFbTQMSBuhOMJBUUPmSzQxKQASUYg0Zw hWR4BxnMB35YnGcU
J314BzCkv2BEP2/qRhKgjDjcwV80slz+0g5dEkYn1AkZkMJBAIVf2AYZdCjH g8cJfL3YE4IxXEGA
ND6q88eoO7/IejW2s7RyHAOE/AVzSId72IcIhMaHfDx7eIdf+AMtSEES8CaN +6abQyMIGz2F+jeB
u8Pkg0FoOAd46EN+UMnMiMZyyIU/0MHbiatv1Am120i227PCIzwEzAEdUAI3 +IOfZId3wIdZK8Wi
fLx6eIekhMlMjDAVU8uSmUmoQ8A90w7Ty4GDhEFrOAc+1AeHFEugcCjYSwSY ND6dLL4TFDdMfEUC
NBkEFIIumEJQyAVruEJ88MOw3MvMwId3uMExgKSqlKSOY8vxccoUtMp6QQEZ WDw5SAT+VPgFa0gH
vCRKyqxMcepCedgGV5ADDMwlnaND4Su86lI7qNIlt8PDSUhGcOhKUmzI2HSU LdyHeyjLQegCSNJH
FZQk4ExBuEw7O7TD0zvNRIBBdeTDdnxH5fwh10uHZgCF25QBHszEtMNHwxNH 86sMEniBxUy+SXCF
YIDMdJCHLOwH2CTP5bzCX2gEN1jKw5TJ7FwxcORJqwECKcyDRHBMaNhDPpy1 /wzQFsuHd9iGWEiE
MTiCe3zLptyzM7I5NEIoHRACORiETEjG9nuHeiBFDM1QP+MHskTPC1TCX3zL BT0ZxITCuTzGWAiG
K8RCUqzRWItGaEzOxYnGJeWHKF090oZ80iotMyqtUqIczyTlOaPcUr4E0wnr ji8FUC7NLtj80jBV
Uz+rKzN10zeF0ziV0zml0zq10zvFU2MJCAA7UEsDBBQAAAAIAKp7cDQXYZ2E 7AIAAEQQAAAtAAAA
b3JnLmVjbGlwc2UuYmlydC5yY3Audmlld2VyL3JjcHZpZXdlci5wcm9kdWN0 pVdLbxMxEL4j8R9W
e8ehrYR6aFoBUqXcUFW4oll7duPil/xIwr/H3t02IaJlnFysXfv75mXPeHxz t9Oq2aAP0pple8E+
tg0aboU0w7L9/nj/4bq9u33/7ubOCdzjrtjFOJ0XnLci8dgY0Lhsv6weHpuH r9+aB3TWx+aHxC36
tpFi2Vo/MORKuoCskz4yzx3bjAA2S2kbcE5JDjGreZtxAGybFPAeISaPYdn2 oAK2o3VN09xAZ1Nc
md7ejv9lSmoYsHEQ18t28YaSheTWhIUfffnpsvcOeZQbZIPs28XtpGBxqGGa yrReDisji2XLVmAP
ScXMeAYoSIav0X/2Q3gWczQ3zW6lEXa7KgaHJmhQ6lyTj02Yd67ImXdrH6hg FXgZZk9ne4pPK26f
Az2tzcuddgfgRUYfe/fimVNpkGb2fj/xclTAQcYzMDlu/wOpxNHgK7h9tEZp jFtPgZaAEGGMryGP
AjeSI8NdRFPy5CR22Ax1PDSDJPl+zDnZ0ulwyYi6jpdkLf4EC+mbO2IrjBIQ oQbLrKjGMxDgYi5v
Ijoqd5/8ZMa4gXulvYLYS0UO3Cv8mmAei3gSHT+He4bqANopFN25/DNMyJfw GdQTFGOQg0FflS5H
3HqtdZXqLxJDLWPJi3WsDtWRBCf6SgHaCqxVSk7IvANl0BqMCFQ87lxudUpd JFMy3ibPsZ5QrHO5
0eqkkvF3PT03AVeXZFoyUWrKITmEn2biJvc20ClSSEq+RWtViYYxY0uVNRFL /L/JtaVXeNheCgIQ
NeWEZ9R47kh3awEjsVi8YHNtopSIASnmrlFRbsQCy11h/vQbUv6NhA4CxbOC pZW9EbnFDhzF6Kce
OEX/iGMRd5TG1IaBYmnYUoRl1JTH87i7/kRgRQRNvWKIXkWrOVCApG1KMrea +eEY1oiRUgYyobde
E6HlEiBCt9b/6jC/kCrhY9xQyGgphz25XIqQTc/T5OFt1lMyMu6fudPq9DTN f9OLPf/9AVBLAwQK
AAAAAACqe3A0AAAAAAAAAAAAAAAAIAAAAG9yZy5lY2xpcHNlLmJpcnQucmNw LnZpZXdlci9zcmMv
UEsDBAoAAAAAAKp7cDQAAAAAAAAAAAAAAAAkAAAAb3JnLmVjbGlwc2UuYmly dC5yY3Audmlld2Vy
L3NyYy9vcmcvUEsDBAoAAAAAAKp7cDQAAAAAAAAAAAAAAAAsAAAAb3JnLmVj bGlwc2UuYmlydC5y
Y3Audmlld2VyL3NyYy9vcmcvZWNsaXBzZS9QSwMECgAAAAAAqntwNAAAAAAA AAAAAAAAADEAAABv
cmcuZWNsaXBzZS5iaXJ0LnJjcC52aWV3ZXIvc3JjL29yZy9lY2xpcHNlL2Jp cnQvUEsDBAoAAAAA
AKp7cDQAAAAAAAAAAAAAAAA1AAAAb3JnLmVjbGlwc2UuYmlydC5yY3Audmll d2VyL3NyYy9vcmcv
ZWNsaXBzZS9iaXJ0L3JjcC9QSwMECgAAAAAAqntwNAAAAAAAAAAAAAAAADwA AABvcmcuZWNsaXBz
ZS5iaXJ0LnJjcC52aWV3ZXIvc3JjL29yZy9lY2xpcHNlL2JpcnQvcmNwL3Zp ZXdlci9QSwMEFAAA
AAgAqntwNAZkg6mDAQAACQMAAEwAAABvcmcuZWNsaXBzZS5iaXJ0LnJjcC52 aWV3ZXIvc3JjL29y
Zy9lY2xpcHNlL2JpcnQvcmNwL3ZpZXdlci9BcHBsaWNhdGlvbi5qYXZhlZLR auMwEEWfra8Y6EPt
sKt8QCg0dPOQLrSL16V9K7I8cdQqkpDkuGXJv++oUUhLA6VgLGEd3XvnYifk s+gRrO85Sq1cQN4q
H7mXjm8VjuhnjKmNsz5+gKT1yP1gotogX/7RIq6s39SDMaLVODt1JYyRj6rr MQb+SwWnxetJblD8
oHe3JPfpZMJgAs1aBZBaBHpbE73VAYTWIIJDGQPYFcQ1gnBOKymisuY8AL6g HNKeFKbMDS2dZZH5
EQRKoXGDhmQ+zQL/GCumEyiNNT+vxVZ0VlasoESXAfEbpZzRSflEAlwL0/Pb 9olyk1JKVuRo+4+Q
yLwVvg8VTebtGGDxItGlxBSqKHKJ0OX1Ao69celRRMxIWc2Ij/717V6hDFlg HLy5sh2eujc3HcW+
t/65RSPXZbb4AQbHd80diXm3VcH6siKn5LCC8r3DB4t60dzVN4/14m8zr5tq n6nY45/754uHZXOA
38R37Ev89ncid7BShv6RPHYegqfVBkylJDF6duw/UEsDBBQAAAAIAKp7cDQ+ dC+fwAMAAJwLAABc
AAAAb3JnLmVjbGlwc2UuYmlydC5yY3Audmlld2VyL3NyYy9vcmcvZWNsaXBz ZS9iaXJ0L3JjcC92
aWV3ZXIvQXBwbGljYXRpb25BY3Rpb2
FUDForum. Page generated in 0.04107 seconds
