Home » Eclipse Projects » Eclipse Platform » "Resource is out of sync with the filesystem" ?
"Resource is out of sync with the filesystem" ? [message #157685] Mon, 17 November 2003 06:56 Go to next message
Originally posted by: tt.go.to.hell
I am getting this error on many files when doing a text search through my
workspace (Eclipse 2.1). What does it mean, how can I fix it?
TTimo
Re: "Resource is out of sync with the filesystem" ? [message #157693 is a reply to message #157685] Mon, 17 November 2003 08:27 Go to previous messageGo to next message
Originally posted by: hcs33.egon.gyaloglo.hu
You probably modified those files in your workspace outside Eclipse (ie.
using a simple text editor), so this file is newer on the disk than on
Eclipse workspace "caches". You have to perform a Refresh from Navigator or
Package Explorer views for the folders those file is in, and the problem go
away.
HTH,
Csaba
"Timothee Besset" <tt@go.to.hell> wrote in message
news:20031117125633.42bd43fb.tt@go.to.hell...
> TTimo
Re: "Resource is out of sync with the filesystem" ? [message #157812 is a reply to message #157693] Mon, 17 November 2003 11:52 Go to previous messageGo to next message
Ok .. files in my workspace get regularly modified outside of Eclipse by
the source control client (AlienBrain, I don't believe eclipse has a
plugin for that). Is there a way to setup my workspace so the refresh
happens any time the workspace gets loaded?
TTimo
On Mon, 17 Nov 2003 14:27:41 +0100
"Horváth, Csaba" <hcs33@egon.gyaloglo.hu> wrote:
> away.
> HTH,
> Csaba
> > TTimo
Re: "Resource is out of sync with the filesystem" ? [message #157827 is a reply to message #157812] Mon, 17 November 2003 12:10 Go to previous messageGo to next message
Window>Preferences>Workbench>Refresh Workspace on startup
HTH
Darins
"Timothee Besset" <ttimo@ttimo.net> wrote in message
news:20031117175214.7801173f.ttimo@ttimo.net...
TTimo
"Horv
Re: "Resource is out of sync with the filesystem" ? [message #157835 is a reply to message #157812] Mon, 17 November 2003 12:08 Go to previous messageGo to next message
Window->Preferences->Workbench->Refresh Workspace on startup
Jerome
TTimo
"Horv
Re: "Resource is out of sync with the filesystem" ? [message #157911 is a reply to message #157835] Mon, 17 November 2003 13:23 Go to previous message
Originally posted by: dj_houghton.nospam.ca.ibm.com
Also note that there is an auto-refresh plug-in available on the Core web
space on eclipse.org.
http://dev.eclipse.org/viewcvs/index.cgi/%7Echeckout%7E/plat form-core-home/dev.html#tools
We are currently investigating the integration of this plug-in into the base
Core code in the SDK.
"Jerome Lanneluc" <jerome_lanneluc@fr.ibm.com> wrote in message
news:bpav66$jj1$1@eclipse.org...
> Jerome
> TTimo
> "Horv
Previous Topic:Eclipse way of adding to ClassPath?
Next Topic:problem in wizard page display..
Current Time: Tue Jul 22 13:03:56 EDT 2025
Powered by FUDForum. Page generated in 0.08851 seconds
