problème while éditing plugin code in UTF-8 under windows [message #157677] |
Mon, 17 November 2003 05:56 |
Originally posted by: arnaud.siminski.infotel.com
Hi all,
I hope I am sending this message to the right newsgroup. If not, sorry for
disturbing you guys :-)
Here is my problem: I am writing a plugin that adds a Preference Page to
the Eclipse workbench. It turns out pretty well expect that when I switch
my editors setup into UTF 8 text encoding
(Window>Preferences>Workbench>Editors>Text file encoding) and then I
export my project using the Export Wizard as de Deployable Plugin (usual
parameters), the strings that contain accents (the language is French and
it contains accents ;-) ) are not displayed correctly inside the
preference page.
I tried this on several Eclipse version 2.1.1, 2.1.2 and 3.0M4 and the
result is the same. For information, I am using Eclipse under a french MS
Windows 2000.
Does anyone knows what I did wrong ?
Thank for your help
Arnaud
FUDForum. Page generated in 0.03950 seconds
