Home » Eclipse Projects » Eclipse Platform » File to IFile
File to IFile [message #157401] |
Sat, 15 November 2003 22:34  |
Originally posted by: rc316.shaw.ca
Does anyone know how to map a java.io.file to an IFile? I create a file and
I want to make that file into a type IFile. Thanks in advance.
Raj
Re: File to IFile [message #158160 is a reply to message #158075] |
Tue, 18 November 2003 03:15   |
Hi Bob and Rich,
Thanks for your help. The thing is that the file I'm creating is done on
the fly as my plugin runs and so it's not in the workspace.
Basically, this is what I'm trying to do.
I'm trying to create a newsgroup client plugin for eclipse and I create a
view in which the messages are displayed in. When I double-click a message,
I would like to open it in the text editor.
The way I'm going about this is that I'm grabbing the information from the
doubleclick event and writing it into temp file and I want to display this
temp file in the editor. From what I've read and what I've tried, it seems
that this is not possible if this file is not associated in the workspace,
as you guys have pointed out.
In your opinion, is what I'm trying to do possible?
Thanks again,
Raj
"Bob Foster" <bob@objfac.com> wrote in message
news:bpbqol$kct$1@eclipse.org...
> Well, you could create a linked file in the workspace that works as a
> surrogate for the non-workspace file.
> (Also, when going the other way, from IFile to File, you want to use
> getLocation() not getFullPath().)
> Bob
> "Rich Kulp" <richkulp@NO.SPAM.us.ibm.com> wrote in message
> news:bpan7b$7rr$2@eclipse.org...
> > But remember, this only works for files that are in the workspace. If
> > the file is not in the workspace anywhere (i.e. some generic file
> > someplace else), you can't get an IFile to it.
> > Thanks, Rich Kulp
Re: File to IFile [message #158303 is a reply to message #158176] |
Tue, 18 November 2003 12:20   |
Thanks Tom,
Do you know of any examples of how this is done? If so, could you point it
out to me?
Otherwise, I'll try to figure it out on my own. Thanks for your help
Raj
"Tom Eicher" <eclipse@tkilla.ch> wrote in message
news:bpcntt$gl8$1@eclipse.org...
> Raj Chari wrote:
> > Hi Bob and Rich,
on
a
message,
the
this
seems
workspace,
> You don't really need an IFile if you don't intend to store anything on
> disk - you could just create your own IEditorInput and IDocumentProvider
> and provider your message in as an instance of Document.
> -tom
Re: File to IFile [message #158701 is a reply to message #158160] |
Wed, 19 November 2003 02:28   |
Originally posted by: bob.objfac.com
As long as the file is in the workspace, I think you can do it. Use the
..metadata area created for your plugin, which you can get the path of by
calling getStateLocation() in your plugin. toOSString() will get you a path
suitable for java.io.File and you're off and running. When you have a File
created there, call the following to get an IFile:
public IFile fileToIFile(File f) {
String p = f.getPath();
IPath path = new Path(p);
return ResourcesPlugin.getWorkspace().getRoot().getFile(path);
(I just typed that in; if it doesn't compile, fix it.) Then, I have this bit
of code lying around that will do the rest:
protected IEditorPart openEditor(IFile file, String editorId) {
IEditorPart editor = null;
IEditorInput input = new FileEditorInput(file);
IWorkbenchPage page =
PlatformUI.getWorkbench().getActiveWorkbenchWindow().getActi vePage();
if (page != null) {
editor = page.findEditor(input);
if (editor != null) {
page.bringToTop(editor);
else {
try {
editor = page.openEditor(input, editorId);
} catch (PartInitException e) {
//log the error or something
return editor;
I haven't tried exactly this case and there's probably shorter code to do it
(I try to avoid Eclipse's IResource, uh, stuff as much as I can), but that's
the general idea.
Bob
"Raj Chari" <rc316@shaw.ca> wrote in message
news:bpckbl$bvc$1@eclipse.org...
> Hi Bob and Rich,
message,
seems
> Thanks again,
> Raj
> > Bob
> > > Thanks, Rich Kulp
Re: File to IFile [message #158745 is a reply to message #158701] |
Wed, 19 November 2003 03:58   |
Thank you so much Bob!
Raj
news:bpf514$940$1@eclipse.org...
path
bit
> if (page != null) {
> else {
> try {
> return editor;
it
that's
> the general idea.
> Bob
> > Hi Bob and Rich,
on
a
> message,
the
this
> seems
workspace,
> > Thanks again,
> > Raj
> > > Bob
If
> > > > Thanks, Rich Kulp
Re: File to IFile [message #159080 is a reply to message #158745] |
Wed, 19 November 2003 14:14   |
I just re-read your post and my problem lies in the fact that I'm creating
the file when I run my plugin, I have choice in where to store the file but
it's not registered in the workspace. Will this still work if the file is
not in the workspace. The other person suggested using IDocument and
IEditorInput and I'm not sure how to use this. Does anyone know how to use
the IEditorInput and IDocument as mentioned in a previous post? I'm looking
for examples to see how to use IDocument.
Raj
news:bpfb7k$ff5$1@eclipse.org...
> Raj
> path
File
> bit
> > if (page != null) {
> > else {
> > try {
> > return editor;
do
> it
> that's
> > the general idea.
> > Bob
> > > Hi Bob and Rich,
> on
create
> a
> > message,
> the
> this
> > seems
> workspace,
> > > Thanks again,
> > > Raj
a
> > > > Bob
> If
> > > > > Thanks, Rich Kulp
Re: File to IFile [message #159251 is a reply to message #159080] |
Thu, 20 November 2003 02:14   |
I think you're headed off in the wrong direction. Please re-read my post
until you understand it. ;-}
Bob
news:bpgfbm$vfp$1@eclipse.org...
but
use
looking
> Thanks
> Raj
> > Raj
the
by
> > path
> File
this
> > bit
> > > if (page != null) {
> > > else {
> > > try {
> > > return editor;
> do
> > it
> > that's
> > > the general idea.
> > > Bob
> > > > Hi Bob and Rich,
done
> > on
> create
> > a
> > > message,
from
> > the
display
> > this
it
> > > seems
> > workspace,
> > > > Thanks again,
> > > > Raj
as
> a
use
> > > > > Bob
workspace.
> > If
file
> > > > > > Thanks, Rich Kulp
Re: File to IFile [message #159707 is a reply to message #159251] |
Thu, 20 November 2003 15:06   |
So I used your idea Bob and I wrote up the following code:
File myFile = new File("F:/ePost/workspace/test.txt");
FileWriter fw = new FileWriter(myFile);
fw.write(sb.toString());
fw.close();
file = fileToIFile(myFile);
openEditor(file, IWorkbenchConstants.DEFAULT_EDITOR_ID);
I wrote the two other functions that were suggested:
String p = f.getAbsolutePath();
if (page != null) {
else {
try {
showMessage(e.getMessage());
return editor;
My output was that the file tried to open up in the editor and
in the texteditor, it said, "Resource /ePost/workspace/test.txt does not
exist."
Can someone tell me why this would happen and/or how this can be fixed?
Thanks again
Raj
news:bphok5$6us$1@eclipse.org...
> Bob
> > Hi,
creating
> but
is
> use
> looking
> > Thanks
> > Raj
> > > Raj
> the
of
> by
a
> > > path
a
> > File
> this
> > > bit
> > > > if (page != null) {
> > > > else {
> > > > try {
> > > > return editor;
to
> > do
> > > it
but
> > > that's
> > > > the general idea.
> > > > Bob
> > > > > Hi Bob and Rich,
> done
> > > on
> > create
> > > a
a
> > > > message,
> from
> > > the
> display
> > > this
> it
> > > > seems
> > > workspace,
> > > > > Thanks again,
> > > > > Raj
> as
> > a
> use
> > > > > > Bob
> workspace.
> > > If
> file
> > > > > > > Thanks, Rich Kulp
Re: File to IFile [message #160044 is a reply to message #159707] |
Fri, 21 November 2003 09:40   |
Called my bluff, eh? ;-}
Well, first of all, does the file exist? Second, is it actually in a
workspace?
My actual idea was to store the files in your plugin folder inside
..metadata, which I know are ok to read and write, not just at the root of
some workspace, which I don't know are ok.
Anyway, check this stuff, do a little debugging, and if it isn't obvious
we'll go from there.
Bob
"Raj Chari" <rc316@shaw.ca> wrote in message news:bpj6ou$ke$1@eclipse.org...
> fw.close();
> if (page != null) {
> else {
> try {
> return editor;
> exist."
> Thanks again
> Raj
> > Bob
> > > Hi,
> creating
file
> > but
file
> is
to
> > use
> > looking
> > > Thanks
> > > Raj
> > > > Raj
Use
> > the
> of
> > by
you
> a
> > > > path
have
> a
> > > File
have
> > this
> > > > bit
> > > > > if (page != null) {
> > > > > else {
> > > > > try {
> > > > > return editor;
code
> to
> > > do
> > > > it
> but
> > > > that's
> > > > > the general idea.
> > > > > Bob
> > > > > > Hi Bob and Rich,
is
> > done
> > > > on
> > > create
> > > > a
double-click
> a
> > > > > message,
information
> > from
> > > > the
> > display
> > > > this
tried,
> > it
> > > > > seems
> > > > workspace,
> > > > > > Thanks again,
> > > > > > Raj
works
> > as
> > > a
to
> > use
> > > > > > > Bob
> > workspace.
> > > > If
> > file
> > > > > > > > Thanks, Rich Kulp
Re: File to IFile [message #160055 is a reply to message #159707] |
Fri, 21 November 2003 09:41   |
workspace?
Bob
> fw.close();
> if (page != null) {
> else {
> try {
> return editor;
> exist."
> Thanks again
> Raj
> > Bob
> > > Hi,
> creating
file
> > but
file
> is
to
> > use
> > looking
> > > Thanks
> > > Raj
> > > > Raj
Use
> > the
> of
> > by
you
> a
> > > > path
have
> a
> > > File
have
> > this
> > > > bit
> > > > > if (page != null) {
> > > > > else {
> > > > > try {
> > > > > return editor;
code
> to
> > > do
> > > > it
> but
> > > > that's
> > > > > the general idea.
> > > > > Bob
> > > > > > Hi Bob and Rich,
is
> > done
> > > > on
> > > create
> > > > a
double-click
> a
> > > > > message,
information
> > from
> > > > the
> > display
> > > > this
tried,
> > it
> > > > > seems
> > > > workspace,
> > > > > > Thanks again,
> > > > > > Raj
works
> > as
> > > a
to
> > use
> > > > > > > Bob
> > workspace.
> > > > If
> > file
> > > > > > > > Thanks, Rich Kulp
Re: File to IFile [message #160215 is a reply to message #160055] |
Fri, 21 November 2003 12:57   |
Well,
The file does exist but it's not in the workspace. I think this problem
can be solved by adding the file to the workspace using the appropriate
commands and then maybe calling this code although, I have no idea of how to
add a file to the workpace by using java code. I've got a rough idea, but
if anyone has a clear idea of how to do it, your help would be greatly
appreciated.
Raj
news:bpl74v$3h5$1@eclipse.org...
> workspace?
> Bob
> > Hi,
> > fw.close();
> > if (page != null) {
> > else {
> > try {
> > return editor;
> > exist."
> > Thanks again
> > Raj
post
> > > Bob
> > > > Hi,
> > creating
> file
> > > but
> file
> > is
and
> to
> > > use
> > > looking
> > > > Thanks
> > > > Raj
> > > > > Raj
> Use
> > > the
path
> > of
> > > by
> you
> > a
> > > > > path
> have
> > a
> > > > File
> have
> > > this
> > > > > bit
> > > > > > if (page != null) {
> > > > > > else {
> > > > > > try {
> > > > > > return editor;
> code
> > to
> > > > do
> > > > > it
can),
> > but
> > > > > that's
> > > > > > the general idea.
> > > > > > Bob
> > > > > > > Hi Bob and Rich,
> is
> > > done
> > > > > on
I
> > > > create
> > > > > a
> double-click
> > a
> > > > > > message,
> information
> > > from
> > > > > the
> > > display
> > > > > this
> tried,
> > > it
> > > > > > seems
the
> > > > > workspace,
> > > > > > > Thanks again,
> > > > > > > Raj
> works
> > > as
> > > > a
want
> to
> > > use
> > > > > > > > Bob
> > > workspace.
> > > > > If
generic
> > > file
> > > > > > > > > Thanks, Rich Kulp
Re: File to IFile [message #160451 is a reply to message #160215] |
Sat, 22 November 2003 00:31   |
Previously, I wrote:
Use the .metadata area created for your plugin, which you can get the path
of by calling getStateLocation() in your plugin [class].
The rest of the paragraph tells how to use the path to make a file.
Bob
news:bpljho$kpv$1@eclipse.org...
> Well,
to
> appreciated.
> Thanks
> Raj
> > workspace?
of
> > Bob
> > > Hi,
> > > fw.close();
> > > if (page != null) {
> > > else {
> > > try {
> > > return editor;
not
> > > exist."
fixed?
> > > Thanks again
> > > Raj
> post
> > > > Bob
> > > > > Hi,
> > > creating
> > file
> > > > but
> > file
> > > is
> and
how
> > to
> > > > use
I'm
> > > > looking
> > > > > Thanks
> > > > > Raj
> > > > > > Raj
it.
> > Use
> > > > the
> path
> > > of
> > > > by
get
> > you
> > > a
> > > > > > path
> > have
> > > a
> > > > > File
> > > > > > > return
> > have
> > > > this
> > > > > > bit
> > > > > > > if (page != null) {
> > > > > > > else {
> > > > > > > try {
> > > > > > > return editor;
> > code
> > > to
> > > > > do
> > > > > > it
> can),
> > > but
> > > > > > that's
> > > > > > > the general idea.
> > > > > > > Bob
> > > > > > > > Hi Bob and Rich,
creating
> > is
> > > > done
> > > > > > on
and
> I
> > > > > create
> > > > > > a
> > double-click
> > > a
> > > > > > > message,
> > information
> > > > from
> > > > > > the
to
> > > > display
> > > > > > this
> > tried,
> > > > it
> > > > > > > seems
> the
> > > > > > workspace,
> > > > > > > > Thanks again,
> > > > > > > > Raj
> > works
> > > > as
> > > > > a
> want
> > to
> > > > use
> > > > > > > > > Bob
> > > > workspace.
> > > > > > If
> generic
> > > > file
> > > > > > > > > > Thanks, Rich Kulp
Re: File to IFile [message #160468 is a reply to message #160451] |
Sat, 22 November 2003 04:06   |
Can you explain what it is to use the metatdata? I'm not understanding what
you're trying to say. So, are you saying when I create my java.io.file, I
should create the file in the .metadata directory? Sorry to be so dense..
Raj
news:bpmra9$t34$1@eclipse.org...
> Bob
> > Well,
problem
how
> to
but
> > appreciated.
> > Thanks
> > Raj
> > > workspace?
> of
obvious
> > > Bob
> > > > Hi,
> > > > fw.close();
> > > > if (page != null) {
> > > > else {
> > > > try {
> > > > return editor;
> not
> > > > exist."
> fixed?
> > > > Thanks again
> > > > Raj
my
> > post
> > > > > Bob
> > > > > > Hi,
I'm
> > > > creating
the
> > > file
> > > > > but
the
> > > file
> > > > is
IDocument
> > and
> how
> > > to
> > > > > use
> I'm
> > > > > looking
> > > > > > Thanks
> > > > > > Raj
> > > > > > > Raj
> it.
> > > Use
> > > > > the
the
> > path
> > > > of
> > > > > by
> get
> > > you
> > > > a
> > > > > > > path
you
> > > have
> > > > a
> > > > > > File
> > > > > > > > return
I
> > > have
> > > > > this
> > > > > > > bit
editorId)
> > > > > > > > if (page != null) {
> > > > > > > > else {
> > > > > > > > try {
> > > > > > > > return editor;
shorter
> > > code
> > > > to
> > > > > > do
> > > > > > > it
> > can),
> > > > but
> > > > > > > that's
> > > > > > > > the general idea.
> > > > > > > > Bob
> > > > > > > > > Hi Bob and Rich,
> creating
> > > is
> > > > > done
> > > > > > > on
workspace.
> and
> > I
> > > > > > create
> > > > > > > a
> > > double-click
> > > > a
> > > > > > > > message,
> > > information
> > > > > from
> > > > > > > the
> to
> > > > > display
> > > > > > > this
I've
> > > tried,
> > > > > it
> > > > > > > > seems
in
> > the
> > > > > > > workspace,
> > > > > > > > > Thanks again,
> > > > > > > > > Raj
that
> > > works
> > > > > as
> > > > > > a
> > want
> > > to
> > > > > use
> > > > > > > > > > Bob
message
the
> > > > > workspace.
> > > > > > > If
> > generic
> > > > > file
> > > > > > > > > > > Thanks, Rich Kulp
Re: File to IFile [message #160498 is a reply to message #160468] |
Sat, 22 November 2003 07:48   |
Maybe I've been cryptic. Every plugin is allocated a folder in the
..metadata/.plugins folder of each workspace. This folder is writeable and
AFAIK IFile-accessible. If your plugin's id is org.sample.myplug, that will
be the folder name. But you don't need to know that. getStateLocation() gets
it for you. You should be able to create a sub-folder there, write your temp
files into it and open those files in editors. More clear?
(I've gone a bit out on a limb because I don't know what sort of knucklehead
code there is in Eclipse that might assume/require that every file is in a
project - I believe Search makes this assumption - but I think that's the
simplest solution to what you want to do so I suggest you try it. If it
doesn't work, there are other options, which involve creating a new project
to put the files into. This is quite easy to do; a few lines of code. But
since the project would be user-visible, it's not such a good solution.
Hence, I have suggested this path.)
Bob
news:bpn8r0$831$1@eclipse.org...
what
> Thanks
> Raj
path
> > Bob
> > > Well,
> problem
appropriate
> how
> > to
> but
greatly
> > > appreciated.
> > > Thanks
> > > Raj
> > > > workspace?
root
> > of
> obvious
> > > > Bob
> > > > > Hi,
> > > > > fw.close();
> > > > > if (page != null) {
> > > > > else {
> > > > > try {
> > > > > return editor;
does
> > not
> > > > > exist."
> > fixed?
> > > > > Thanks again
> > > > > Raj
> my
> > > post
> > > > > > Bob
> > > > > > > Hi,
> I'm
> > > > > creating
> the
> > > > file
> > > > > > but
> the
> > > > file
> > > > > is
> IDocument
> > > and
know
> > how
> > > > to
> > > > > > use
post?
> > I'm
> > > > > > looking
> > > > > > > Thanks
> > > > > > > Raj
> > > > > > > > Raj
do
> > it.
> > > > Use
> > > > > > the
> the
> > > path
> > > > > of
> > > > > > by
will
> > get
> > > > you
> > > > > a
> > > > > > > > path
> you
> > > > have
> > > > > a
> > > > > > > File
> > > > > > > > > return
Then,
> I
> > > > have
> > > > > > this
> > > > > > > > bit
> editorId)
> > > > > > > > > if (page != null) {
> > > > > > > > > else {
> > > > > > > > > try {
> > > > > > > > > return editor;
> shorter
> > > > code
> > > > > to
> > > > > > > do
> > > > > > > > it
I
> > > can),
> > > > > but
> > > > > > > > that's
> > > > > > > > > the general idea.
> > > > > > > > > Bob
> > > > > > > > > > Hi Bob and Rich,
> > creating
> > > > is
> > > > > > done
> > > > > > > > on
> workspace.
eclipse
> > and
> > > I
> > > > > > > create
> > > > > > > > a
> > > > double-click
> > > > > a
> > > > > > > > > message,
> > > > information
> > > > > > from
> > > > > > > > the
want
> > to
> > > > > > display
> > > > > > > > this
> I've
> > > > tried,
> > > > > > it
> > > > > > > > > seems
> in
> > > the
> > > > > > > > workspace,
> > > > > > > > > > Thanks again,
> > > > > > > > > > Raj
> that
> > > > works
> > > > > > as
> > > > > > > a
you
> > > want
> > > > to
> > > > > > use
> > > > > > > > > > > Bob
> message
> the
> > > > > > workspace.
> > > > > > > > If
> > > generic
> > > > > > file
> > > > > > > > > > > > Thanks, Rich Kulp
Re: File to IFile [message #160596 is a reply to message #160498] |
Sat, 22 November 2003 16:48   |
I put in the following code as mentioned before to use the metadata
directory.
IPath filePath = ePostPlugin.getDefault().getStateLocation();
String fileNamePath = filePath.toOSString();
File myFile = new File(fileNamePath + "/" + "test.epo");
fw.close();
I still get the same problem with resource not found error showing up in the
editor. Where should we go from here?
Thanks again,
Raj
news:bpnkuj$ieb$1@eclipse.org...
will
gets
temp
knucklehead
project
> Bob
> what
I
dense..
> > Thanks
> > Raj
> path
> > > Bob
> > > > Well,
> > problem
> appropriate
of
> > how
> > > to
idea,
> > but
> greatly
> > > > appreciated.
> > > > Thanks
> > > > Raj
a
> > > > > workspace?
> root
> > > of
> > obvious
> > > > > Bob
> > > > > > Hi,
> > > > > > fw.close();
> > > > > > return
> > > > > > if (page != null) {
> > > > > > else {
> > > > > > try {
> > > > > > return editor;
> does
> > > not
> > > > > > exist."
> > > fixed?
> > > > > > Thanks again
> > > > > > Raj
re-read
> > my
> > > > post
> > > > > > > Bob
> > > > > > > > Hi,
that
> > I'm
> > > > > > creating
store
> > the
> > > > > file
> > > > > > > but
if
> > the
> > > > > file
> > > > > > is
> > IDocument
> > > > and
> know
> > > how
> > > > > to
> > > > > > > use
> post?
> > > I'm
> > > > > > > looking
> > > > > > > > Thanks
> > > > > > > > Raj
> > > > > > > > > Raj
> do
> > > it.
> > > > > Use
> > > > > > > the
get
> > the
> > > > path
> > > > > > of
> > > > > > > by
> will
> > > get
> > > > > you
> > > > > > a
> > > > > > > > > path
When
> > you
> > > > > have
> > > > > > a
> > > > > > > > File
> > > > > > > > > > return
> Then,
> > I
> > > > > have
> > > > > > > this
> > > > > > > > > bit
> > editorId)
> > > > > > > > > > if (page != null) {
> > > > > > > > > > else {
> > > > > > > > > > try {
> > > > > > > > > > return editor;
> > shorter
> > > > > code
> > > > > > to
> > > > > > > > do
> > > > > > > > > it
as
> I
> > > > can),
> > > > > > but
> > > > > > > > > that's
> > > > > > > > > > the general idea.
> > > > > > > > > > Bob
> > > > > > > > > > > Hi Bob and Rich,
> > > creating
> > > > > is
> > > > > > > done
> > > > > > > > > on
> > workspace.
> eclipse
> > > and
> > > > I
> > > > > > > > create
> > > > > > > > > a
> > > > > double-click
> > > > > > a
> > > > > > > > > > message,
> > > > > information
> > > > > > > from
> > > > > > > > > the
> want
> > > to
> > > > > > > display
> > > > > > > > > this
> > I've
> > > > > tried,
> > > > > > > it
> > > > > > > > > > seems
associated
> > in
> > > > the
> > > > > > > > > workspace,
> > > > > > > > > > > Thanks again,
> > > > > > > > > > > Raj
workspace
> > that
> > > > > works
> > > > > > > as
> > > > > > > > a
> you
> > > > want
> > > > > to
> > > > > > > use
> > > > > > > > > > > > Bob
> > message
in
> > the
> > > > > > > workspace.
> > > > > > > > > If
some
> > > > generic
> > > > > > > file
> > > > > > > > > > > > > Thanks, Rich Kulp
Re: File to IFile [message #160675 is a reply to message #160596] |
Sun, 23 November 2003 00:21   |
Well, you remember when I said I'd never tried this? ;-} It looks like
workspaceroot's getFile() will return null if the file isn't in a project,
so I'm really surprised you got anything as civil as file not found. I would
have expected NullPointerException.
I'm not an expert on these crappy IPath/IFile things, but I can't see an
easy way to make what I suggested work without a project. If someone else
does, feel free to jump in.
There are two other ways to open something in an editor:
- Use IStorage, but these aren't editable unless you replace the storage
provider (editing won't work with .java files and I don't truly know what
kinds of files it will work with). See Ed Burnett's fileopen plugin for
working code: http://sourceforge.net/project/showfiles.php?group_id=73634
- Use linked files and a project to contain them, as is done by Matt
Conway's filedrag plugin. You can read the code by downloading the plugin
from http://sourceforge.net/projects/sunshade. This works just fine with
existing editors.
- Eclipse 3.0 is doing something (?) to make external files editable. Can
you wait? ;-}
That's it. I'm out of "helpful" advice. Good luck.
Bob
news:bpolg7$gg3$1@eclipse.org...
> Hello,
> directory.
> fw.close();
the
> Thanks again,
> Raj
and
> will
> gets
> temp
> knucklehead
a
the
> project
But
> > Bob
understanding
> > what
java.io.file,
> I
> dense..
> > > Thanks
> > > Raj
the
> > path
> > > > Bob
> > > > > Well,
> > > problem
> > appropriate
> of
> > > how
> > > > to
> idea,
> > > but
> > greatly
> > > > > appreciated.
> > > > > Thanks
> > > > > Raj
in
> a
> > > > > > workspace?
inside
the
> > root
> > > > of
> > > obvious
> > > > > > Bob
> > > > > > > Hi,
> > > > > > > fw.close();
> > > > > > > return
> > > > > > > if (page != null) {
> > > > > > > else {
> > > > > > > try {
> > > > > > > return editor;
> > does
> > > > not
> > > > > > > exist."
be
> > > > fixed?
> > > > > > > Thanks again
> > > > > > > Raj
> re-read
> > > my
> > > > > post
> > > > > > > > Bob
> > > > > > > > > Hi,
> that
> > > I'm
> > > > > > > creating
> store
> > > the
> > > > > > file
> > > > > > > > but
work
> if
> > > the
> > > > > > file
> > > > > > > is
> > > IDocument
> > > > > and
anyone
> > know
> > > > how
> > > > > > to
> > > > > > > > use
> > post?
> > > > I'm
> > > > > > > > looking
> > > > > > > > > Thanks
> > > > > > > > > Raj
> > > > > > > > > > Raj
can
> > do
> > > > it.
> > > > > > Use
> > > > > > > > the
> get
> > > the
> > > > > path
> > > > > > > of
> > > > > > > > by
toOSString()
> > will
> > > > get
> > > > > > you
> > > > > > > a
> > > > > > > > > > path
> When
> > > you
> > > > > > have
> > > > > > > a
> > > > > > > > > File
> > > > > > > > > > > return
> > Then,
> > > I
> > > > > > have
> > > > > > > > this
> > > > > > > > > > bit
> > > editorId)
> > > > > > > > > > > if (page != null) {
> > > > > > > > > > > else {
> > > > > > > > > > > try {
> > > > > > > > > > > return editor;
> > > shorter
> > > > > > code
> > > > > > > to
> > > > > > > > > do
> > > > > > > > > > it
> as
> > I
> > > > > can),
> > > > > > > but
> > > > > > > > > > that's
> > > > > > > > > > > the general idea.
> > > > > > > > > > > Bob
> > > > > > > > > > > > Hi Bob and Rich,
I'm
> > > > creating
> > > > > > is
> > > > > > > > done
> > > > > > > > > > on
> > > workspace.
> > eclipse
> > > > and
> > > > > I
> > > > > > > > > create
> > > > > > > > > > a
> > > > > > double-click
> > > > > > > a
> > > > > > > > > > > message,
the
> > > > > > information
> > > > > > > > from
> > > > > > > > > > the
I
> > want
> > > > to
> > > > > > > > display
> > > > > > > > > > this
what
> > > I've
> > > > > > tried,
> > > > > > > > it
> > > > > > > > > > > seems
> associated
> > > in
> > > > > the
> > > > > > > > > > workspace,
> > > > > > > > > > > > Thanks again,
> > > > > > > > > > > > Raj
> workspace
> > > that
> > > > > > works
> > > > > > > > as
> > > > > > > > > a
File,
> > you
> > > > > want
> > > > > > to
> > > > > > > > use
> > > > > > > > > > > > > Bob
> > > message
> in
> > > the
> > > > > > > > workspace.
> > > > > > > > > > If
> some
> > > > > generic
> > > > > > > > file
> > > > > > > > > > > > > > Thanks, Rich Kulp
Re: File to IFile [message #160685 is a reply to message #160675] |
Sun, 23 November 2003 01:23  |
thanks for all your help bob
Raj
news:bppf3t$4nd$1@eclipse.org...
would
> existing editors.
> you wait? ;-}
> Bob
> > Hello,
> > directory.
> > fw.close();
> the
> > Thanks again,
> > Raj
> and
> > will
getStateLocation()
> > gets
your
> > temp
> > knucklehead
in
> a
> the
it
> > project
> But
solution.
> > > Bob
> understanding
> > > what
> java.io.file,
> > I
> > dense..
> > > > Thanks
> > > > Raj
> the
> > > path
file.
> > > > > Bob
> > > > > > Well,
this
> > > > problem
> > > appropriate
idea
> > of
> > > > how
> > > > > to
> > idea,
> > > > but
> > > greatly
> > > > > > appreciated.
> > > > > > Thanks
> > > > > > Raj
actually
> in
> > a
> > > > > > > workspace?
> inside
> the
> > > root
> > > > > of
isn't
> > > > obvious
> > > > > > > Bob
> > > > > > > > Hi,
> > > > > > > > fw.close();
> > > > > > > > return
editorId)
> > > > > > > > if (page != null) {
> > > > > > > > else {
> > > > > > > > try {
> > > > > > > > return editor;
and
> > > does
> > > > > not
> > > > > > > > exist."
can
> be
> > > > > fixed?
> > > > > > > > Thanks again
> > > > > > > > Raj
> > re-read
> > > > my
> > > > > > post
> > > > > > > > > Bob
> > > > > > > > > > Hi,
> > that
> > > > I'm
> > > > > > > > creating
> > store
> > > > the
> > > > > > > file
> > > > > > > > > but
> work
> > if
> > > > the
> > > > > > > file
> > > > > > > > is
> > > > IDocument
> > > > > > and
> anyone
> > > know
> > > > > how
> > > > > > > to
> > > > > > > > > use
previous
> > > post?
> > > > > I'm
> > > > > > > > > looking
> > > > > > > > > > Thanks
> > > > > > > > > > Raj
> > > > > > > > > > > Raj
> can
> > > do
> > > > > it.
> > > > > > > Use
> > > > > > > > > the
can
> > get
> > > > the
> > > > > > path
> > > > > > > > of
> > > > > > > > > by
> toOSString()
> > > will
> > > > > get
> > > > > > > you
> > > > > > > > a
> > > > > > > > > > > path
running.
> > When
> > > > you
> > > > > > > have
> > > > > > > > a
> > > > > > > > > > File
> > > > > > > > > > > > return
it.)
> > > Then,
> > > > I
> > > > > > > have
> > > > > > > > > this
> > > > > > > > > > > bit
> > > > editorId)
> > > > > > > > > > > > if (page != null) {
> > > > > > > > > > > > else {
> > > > > > > > > > > > try {
> > > > > > > > > > > > return editor;
probably
> > > > shorter
> > > > > > > code
> > > > > > > > to
> > > > > > > > > > do
> > > > > > > > > > > it
much
> > as
> > > I
> > > > > > can),
> > > > > > > > but
> > > > > > > > > > > that's
> > > > > > > > > > > > the general idea.
> > > > > > > > > > > > Bob
> > > > > > > > > > > > > Hi Bob and Rich,
> I'm
> > > > > creating
> > > > > > > is
> > > > > > > > > done
> > > > > > > > > > > on
> > > > workspace.
> > > eclipse
> > > > > and
> > > > > > I
> > > > > > > > > > create
> > > > > > > > > > > a
I
> > > > > > > double-click
> > > > > > > > a
> > > > > > > > > > > > message,
> the
> > > > > > > information
> > > > > > > > > from
> > > > > > > > > > > the
and
> I
> > > want
> > > > > to
> > > > > > > > > display
> > > > > > > > > > > this
> what
> > > > I've
> > > > > > > tried,
> > > > > > > > > it
> > > > > > > > > > > > seems
> > associated
> > > > in
> > > > > > the
> > > > > > > > > > > workspace,
possible?
> > > > > > > > > > > > > Thanks again,
> > > > > > > > > > > > > Raj
> > workspace
> > > > that
> > > > > > > works
> > > > > > > > > as
> > > > > > > > > > a
> File,
> > > you
> > > > > > want
> > > > > > > to
> > > > > > > > > use
> > > > > > > > > > > > > > Bob
in
> > > > message
are
> > in
> > > > the
> > > > > > > > > workspace.
> > > > > > > > > > > If
(i.e.
> > some
> > > > > > generic
> > > > > > > > > file
> > > > > > > > > > > > > > > Thanks, Rich Kulp
Current Time: Sun Jul 27 12:54:46 EDT 2025
Powered by FUDForum. Page generated in 0.10529 seconds
