Home » Modeling » GMF (Graphical Modeling Framework) » from emf model to GMF Edit part
from emf model to GMF Edit part [message #157382] Fri, 26 October 2007 16:06 Go to next message
Originally posted by: r.q.com
If i have a emf node how can I get its corresponding GMF editpart.
Re: from emf model to GMF Edit part [message #157408 is a reply to message #157382] Fri, 26 October 2007 16:58 Go to previous messageGo to next message
The problem is like this
In my emf/gmf model, some emf nodes are not represented in gmf model. They
are there only in project explorer. When we delete these nodes some other
nodes should also get deleted from emf model (as well as there
corresponding gmf part if its there). When I am deleting such nodes from
emf model, I am deleting other related emf nodes programatically but their
gmf part is not getting deleted from the notational view if it exists.
Please let me know how I can get the corresponding GMF parts (edit parts)
of such nodes so that I can delete them programatically.
Re: from emf model to GMF Edit part [message #157444 is a reply to message #157408] Sat, 27 October 2007 21:33 Go to previous messageGo to next message
Originally posted by: ijerez2001.msn.com
You can delete editparts from your classes editparts.
If you delete from a editpart class, also you delete the element model.
To do this, you have to override the method handleEventNotification.
I write the template:
* @generated NOT
* @param notification : the notification event
protected final void handleNotificationEvent(final Notification
notification) {
//your code to delete elements
super.handleNotificationEvent(notification);
If you is deleting a element, the editpart that capture this event is the
container of removed element.
I think that you want this.
Regards.
"r q" <r@q.com> escribió en el mensaje de
noticias:71a1d2569816cf0244d47338babf39dd$1@www.eclipse.org...
Re: from emf model to GMF Edit part [message #157507 is a reply to message #157444] Mon, 29 October 2007 10:42 Go to previous messageGo to next message
public class DeleteXXXActivity extends ActionDelegate implements
IEditorActionDelegate {
private ISelection s = null;
public void run(IAction action) {
if (s != null) {
doDelete(s);
s = null;
public void selectionChanged(IAction action, ISelection selection) {
this.s = selection;
super.selectionChanged(action, selection);
private void doDelete(ISelection s1) {
IStructuredSelection sS = (IStructuredSelection) s1;
EditPart sObj = (EditPart) sS.getFirstElement();
EObject modelPart = EditPartUtility.getAssociatedSemanticObject
(sObj);
//after getting the above model part we delete it in a subclass
//of org.eclipse.emf.transaction.RecordingCommand
/*TransactionalEditingDomain domain = EditingDomainUtility
.getTransactionalEditingDomain(target);
Command cmd = //my custom commnad class to delete emf model
((TransactionalCommandStack) domain.getCommandStack()).execute(cmd,
null);
Now here I have to delete some other emf nodes as well as there editparts
and figures(if exists) programatically but I am not able to figure out how
i can do that here?
Any help or if you need more information.
* @generated NOT
notification) {
Regards.
"r q" <r@q.com> escribi&#56130;&#56686; el mensaje de
noticias:71a1d2569816cf0244d47338babf39dd$1@xxxxxxxxe.org...
Re: from emf model to GMF Edit part [message #157563 is a reply to message #157507] Mon, 29 October 2007 14:04 Go to previous message
What I am trying to say is I cannot delete in EditPart I have to delete in
DeleteXXXActivity as mentioned below and I am not able to create Delete
Command which will take care of deleting the edit parts. Any help please..
if (s != null) {
doDelete(s);
s = null;
this.s = selection;
(sObj);
null);
i can do that here?
* @generated NOT
notification) {
Regards.
noticias:71a1d2569816cf0244d47338babf39dd$1@xxxxxxxx...
Previous Topic:Request/Command infrastructure
Next Topic:using emf functions in gef application
Current Time: Sat Jul 26 14:01:13 EDT 2025
Powered by FUDForum. Page generated in 0.28351 seconds
