How to fix several Java errors on the same line? [message #157286] |
Mon, 19 June 2006 03:55  |
Originally posted by: mikael.staldal.ingen-reklam-univits.com
I have Eclipse 3.1.2. I have turned off the "Report problems as you
type" option in Preferences->Java->Editor because I the default
behaviour annoying. That gives me a problem.
When there are errors in my Java code, Eclipse puts a lightnbulb in the
left column, and when I click on it I get advice on how to fix the
error. This is nice.
However, if there are two or more errors on the same line, I can only
get advice about one of them (Eclipse choose one for me).
How can I get advice on the other errors on the same line?
The only solution I have found is fix the first error, force rebuilding
by saving the file and then fix the other error. But it would be nice to
be able to fix all errors before saving/rebuilding.
FUDForum. Page generated in 0.11431 seconds
