Home » Eclipse Projects » Plugin Development Environment (PDE) » Class of a dependant plugin, "NoClassDefFoundError".
Class of a dependant plugin, "NoClassDefFoundError". [message #14740] Wed, 30 July 2008 16:10 Go to next message
Originally posted by: natgross.ATgmail.com
Hi;
In a workspace I have about 10 plugin projects with various dependencies
amongst them. Although all the required plugins appear in the plugin
registry view of the target environment, I get a "NoClassDefFoundError"
for a class that definitely exists in a dependent plugin AND it has all
its pkg's exported on the Runtime tab of the plugin.xml file.
Plugin project C depends on plugin projects B and A. When running C, it
finds the classes in B but not in A. A & B export all their pkg's.
Also to note that poject C builds/compiles just fine in he orignal
workbench.
Please advise. Thanks.
nat
Re: Class of a dependant plugin, "NoClassDefFoundError". [message #14770 is a reply to message #14740] Thu, 31 July 2008 18:59 Go to previous message
On Wed, 30 Jul 2008 16:10:34 -0400, nat G wrote:
> Hi;
> finds the classes in B but not in A. A & B export all their pkg's. Also
> to note that poject C builds/compiles just fine in he orignal workbench.
Problem solved! There was an error in build.properties.
Since this error was flagged "warning", I didn't notice it amongst other
"yellow" warnings. Nice thing was that "quick fix" fixed it.
-nat
Re: Class of a dependant plugin, "NoClassDefFoundError". [message #574936 is a reply to message #14740] Thu, 31 July 2008 18:59 Go to previous message
> Hi;
-nat
Previous Topic:Class of a dependant plugin, "NoClassDefFoundError".
Next Topic:Need help using 'adapt' in core expression
Current Time: Sun Jul 27 06:28:12 EDT 2025
Powered by FUDForum. Page generated in 0.04351 seconds
