Home » Language IDEs » Java Development Tools (JDT) » Is there a way to import many eclipse projects at once?
Is there a way to import many eclipse projects at once? [message #157227] Tue, 04 May 2004 15:34 Go to next message
Originally posted by: chris.nospam.genly.us
Hi, All.
I there a way to import many java projects at once given the existence of
the eclipse .project and .classpath files in the root of each project? I
have an existing directory structure with many projects.
Importing them by hand will be tedious. But it is easy to locate the
directories using the Unix find command.
A team project set is not a good solution. Loading from a project set will
fetch the projects from CVS, and will put the projects at the same
directory level. In my case it is important to preserve the relative
placements of these directories. I want to fetch the projects using the
CVS command line, to preserve releative paths between projects, and then
tell eclipse to import all the projects I just retrieved from CVS.
Any help would be appreciated.
Chris
Re: Is there a way to import many eclipse projects at once? [message #157268 is a reply to message #157227] Wed, 05 May 2004 00:35 Go to previous messageGo to next message
Originally posted by: linnet.nospam.users.sourceforge.net
Hi Chris,
Yes, it is indeed tedious. I have made a plugin for this exact purpose.
See http://eclipse-tools.sourceforge.net/projecttransfer .
Jesper
Chris Genly wrote:
> Hi, All.
> Chris
Re: Is there a way to import many eclipse projects at once? [message #157274 is a reply to message #157268] Wed, 05 May 2004 00:53 Go to previous messageGo to next message
Thanks very much. Looks like a really useful plugin. Unfortunately, I'm
using 2.1 so I can't use it.
Chris
Jesper Kamstrup Linnet wrote:
> Hi Chris,
> Best regards,
> Jesper
> Chris Genly wrote:
>> Hi, All.
>> will fetch the projects from CVS, and will put the projects at the same
>> Chris
Re: Is there a way to import many eclipse projects at once? [message #157332 is a reply to message #157274] Wed, 05 May 2004 10:00 Go to previous messageGo to next message
Hi Chris,
I'll take a look at how complex it would be to "backport" it to 2.1.x
(if I can find the time).
Jesper
> Chris
>>Hi Chris,
>>Best regards,
>>Jesper
>>Chris Genly wrote:
>>>Hi, All.
>>>Chris
Re: Is there a way to import many eclipse projects at once? [message #157727 is a reply to message #157332] Fri, 07 May 2004 09:24 Go to previous message
I have now released a version (v0.9.4) of the import/export plugin which
works with Eclipse 2.1.x to the SourceForge project
(http://eclipse-tools.sourceforge.net/projecttransfer). It is also
available on the update site (http://eclipse-tools.sourceforge.net/updates).
Jesper
> Hi Chris,
> Best regards,
> Jesper
>> Chris
>>> Hi Chris,
>>> Best regards,
>>> Jesper
>>> Chris Genly wrote:
>>>> Hi, All.
>>>> existence of
>>>> project? I
>>>> the
>>>> then
>>>> Chris
Previous Topic:code folding feedback
Next Topic:Extending JavaProject?
Current Time: Mon Jul 14 05:07:17 EDT 2025
Powered by FUDForum. Page generated in 0.36774 seconds
