Home » Archived » BIRT » problem with library
problem with library [message #157191] Fri, 28 April 2006 11:22
I am using a library to design a new report. When I first drop a
component from the library to the report, the library is included in the
report. Then when I want to drag another component I get the following
error:
Error.DesignFileException.SYNTAX_ERROR - 2 errors found!
Plug-in Provider:Eclipse.org
Plug-in Name:BIRT Model
Plug-in ID:org.eclipse.birt.report.model
Version:2.0.1
Error Code:Error.DesignFileException.SYNTAX_ERROR
Error Message:Error.DesignFileException.SYNTAX_ERROR - 2 errors found!
1.) ( line = 10, tag = property) (Element = Library, Name = null),
org.eclipse.birt.report.model.command.LibraryException (code =
Error.LibraryException.DUPLICATE_LIBRARY_NAMESPACE, message : The library
namespace "regieMySql" exists already.)
2.) ( line = 14, tag = oda-data-source) (Element = OdaDataSource,
Name = regieMySql),
org.eclipse.birt.report.model.api.command.ExtendsException (code =
Error.ExtendsException.NOT_FOUND, message : The parent element
"regieMySql.regieMySql" does not exist.)
The library I am using uses another library wich contains just the
database connection. This libarary is called RegieMySql. So should I
redefine the database connection evrytime I create a new library instead
of keeping it in a common library?
Alain
Previous Topic:Chart Serializer
Next Topic:Error when previewing a report
Current Time: Tue Jul 22 19:09:32 EDT 2025
Powered by FUDForum. Page generated in 0.03242 seconds
