Home » Language IDEs » ServerTools (WTP) » Where is the source code/implementation for Servers View?
Where is the source code/implementation for Servers View? [message #157177] Wed, 18 January 2006 17:18 Go to next message
Could any one point me to the sources for "Servers" view implementation
for WTP.
I want to understand how the TableTree view that lists defined Servers
and each of the deployed applications (with nice images) has been
implemented.
Thanks in advance,
Rahul
Re: Where is the source code/implementation for Servers View? [message #157194 is a reply to message #157177] Wed, 18 January 2006 23:58 Go to previous messageGo to next message
Rahul,
download wtp-sdk and import plugins org.eclipse.swt.rdb.*
search views extension point and you will find
Rahul wrote:
> for WTP.
> implemented.
> Thanks in advance,
> Rahul
Re: Where is the source code/implementation for Servers View? [message #157352 is a reply to message #157194] Thu, 19 January 2006 14:16 Go to previous message
Actually, those are the Relational Database plugins. You want to
look in the org.eclipse.wst.server.ui plugin for the
org.eclipse.wst.server.ui.internal.view.servers.ServersView class.
It makes use of the native multi-column tree support introduced in
Eclipse 3.1. You can find an additional SWT snippet here:
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.swt.sni ppets/src/org/eclipse/swt/snippets/Snippet170.java?rev=HEAD& amp;content-type=text/vnd.viewcvs-markup
- Nitin
Previous Topic:moving a Servlet
Next Topic:How to extend context menu to ".jsp" and ".js" file?
Current Time: Wed Jul 09 09:26:48 EDT 2025
Powered by FUDForum. Page generated in 0.29217 seconds
