Home » Modeling » GMF (Graphical Modeling Framework) » Timing for PopupBar of ModelingAssistantProvider
Timing for PopupBar of ModelingAssistantProvider [message #157158] Thu, 25 October 2007 17:29 Go to next message
Originally posted by: renee.steiner.intervoice.com
Hi all!
Where can I change the timing for the PopupBar of the
ModelingAssistantProvider?
When I hover on the canvas, it displays really quickly and I would like to
increase the time before it shows.
I am sure this is something really simple, I just haven't found the
property yet.
Thanks in advance!
Re: Timing for PopupBar of ModelingAssistantProvider [message #157335 is a reply to message #157158] Fri, 26 October 2007 15:22 Go to previous messageGo to next message
Renee,
Try overriding these methods in a subclass of the PopupBarEditPolicy and
installing this version on your shape editparts:
* Gets the amount of time to wait before showing the diagram assistant.
* @return the time to wait in milliseconds
protected int getAppearanceDelay() {
return APPEARANCE_DELAY;
* Gets the amount of time to wait before hiding the diagram assistant
after
* it has been made visible.
protected int getDisappearanceDelay() {
return DISAPPEARANCE_DELAY;
after
* the user has moved the mouse outside of the editpart.
protected int getDisappearanceDelayUponExit() {
return DISAPPEARANCE_DELAY_UPON_EXIT;
Cherie
Renee Steiner wrote:
> Hi all!
> to increase the time before it shows.
> property yet.
> Thanks in advance!
Re: Timing for PopupBar of ModelingAssistantProvider [message #157358 is a reply to message #157335] Fri, 26 October 2007 15:43 Go to previous messageGo to next message
Thank you, Cherie!
Has anyone thought about making this information a configuration parameter
in the gmfgen? It seems that it is a variable that may require "tuning"
depending on end-user preference.
Thanks!
gmfgen team: Re: Timing for PopupBar of ModelingAssistantProvider [message #157514 is a reply to message #157358] Mon, 29 October 2007 11:42 Go to previous messageGo to next message
Any thoughts from the gmfgen team about this?
Thanks! :)
> Thank you, Cherie!
> Thanks!
Re: gmfgen team: Re: Timing for PopupBar of ModelingAssistantProvider [message #157545 is a reply to message #157514] Mon, 29 October 2007 13:26 Go to previous message
Hi Renee,
Please file an enhancement request.
Thank you in advance and
Boris
> Thanks! :)
>> Thank you, Cherie!
>> parameter in the gmfgen? It seems that it is a variable that may
>> require "tuning" depending on end-user preference.
>> Thanks!
Previous Topic:GMF and RAP
Next Topic:Request/Command infrastructure
Current Time: Wed May 07 15:04:01 EDT 2025
Powered by FUDForum. Page generated in 0.03023 seconds
