No local variables when debugging java.lang.Integer [message #157088] |
Mon, 03 May 2004 18:35  |
Hello Experts,
I have Eclipse and JDT 2.1.3 on WinXP, and using JDK 1.4.1. I have a
simple test program that calls java.lang.Integer.toString(int). I set a
breakpoint in my test program before this method call. I launch the test
program in JDT debugger. Then I step into the
java.lang.Integer.toString(int) method (JDK source is available.) When
inside the java.lang.Integer.toString(int) method, however, the
"Variables" view tab in the Debug perspective is empty. How can I see the
local variables when stepping into such "standard" Java source files?
Thanks.
Re: No local variables when debugging java.lang.Integer [message #157111 is a reply to message #157096] |
Tue, 04 May 2004 01:15   |
--------------050601040704020003070604
Content-Type: text/plain; charset=us-ascii; format=flowed
use this ant build file
And you should be OK.
I use it all the time (now on 1.4.2_04)
johan
Rich Kulp wrote:
> You really can't because the standard rt.jar is not compiled with local
> variables turned on.
> In the latest 3.0, you can at least see the parameter variables, but
> even there you can't see the local variables.
> You could try recompiling rt.jar using the src.jar but I've had problems
> with that because I've had cases where the src.jar actually is different
> than the rt.jar and things didn't match and you got a different output
> because of it.
Content-Type: text/xml;
name="build.xml"
Content-Disposition: inline;
filename="build.xml"
<?xml version="1.0"?>
<project name="rt_build" default="default" basedir=".">
<description>
Builds debug version of the JDK runtime jar library, rt.jar, using the
sources supplied in the src.zip file. Class files in rt.jar for which
there are no java sources, as well as other non-source files are obtained
from the rt.jar library currently in the JDK's JRE lib directory.
</description>
<property name="builddir" value="${basedir}/rt_build"/>
<property name="libfile" value="${basedir}/jre/lib/rt.jar"/>
<property name="srcdir" value="${builddir}/src"/>
<property name="dstdir" value="${builddir}/dst"/>
<property name="libdir" value="${builddir}/lib"/>
<property name="srcfile" value="${basedir}/src.zip"/>
<property name="dstfile" value="${builddir}/rt.jar"/>
<property name="manfile" value="${libdir}/meta-inf/manifest.mf"/>
<target name="clean" description="clean up build directory">
<delete dir="${builddir}"/>
</target>
<target name="init" depends="clean" description="prepare build directory">
<mkdir dir="${dstdir}"/>
<unjar src="${libfile}" dest="${libdir}"/>
<unzip src="${srcfile}" dest="${srcdir}"/>
</target>
<target name="compile" depends="init" description="compile sources">
<javac destdir="${dstdir}" srcdir="${srcdir}/com/" debug="on" debuglevel="lines,vars,source"
compiler="javac1.4" source="1.4" target="1.4" failonerror="false"/>
<javac destdir="${dstdir}" srcdir="${srcdir}/java/" debug="on" debuglevel="lines,vars,source"
<javac destdir="${dstdir}" srcdir="${srcdir}/javax/" debug="on" debuglevel="lines,vars,source"
<javac destdir="${dstdir}" srcdir="${srcdir}/org/apache" debug="on" debuglevel="lines,vars,source"
<javac destdir="${dstdir}" srcdir="${srcdir}/org/ietf" debug="on" debuglevel="lines,vars,source"
<javac destdir="${dstdir}" srcdir="${srcdir}/org/omg" debug="on" debuglevel="lines,vars,source"
<javac destdir="${dstdir}" srcdir="${srcdir}/org/w3c" debug="on" debuglevel="lines,vars,source"
<javac destdir="${dstdir}" srcdir="${srcdir}/org/xml" debug="on" debuglevel="lines,vars,source"
<javac destdir="${dstdir}" srcdir="${srcdir}/sunw/" debug="on" debuglevel="lines,vars,source"
</target>
<target name="copy" description="copy compiled class files to library directory">
<copy todir="${libdir}" overwrite="true">
<fileset dir="${dstdir}"/>
</copy>
</target>
<target name="jar" description="generate jar file">
<jar jarfile="${dstfile}" basedir="${libdir}" compress="false" manifest="${manfile}"/>
</target>
<target name="default" depends="compile,copy,jar"/>
</project>
--------------050601040704020003070604--
Re: No local variables when debugging java.lang.Integer [message #157254 is a reply to message #157111] |
Tue, 04 May 2004 17:46  |
Thanks for all the responses. Clicking on the build.xml attachment gives
'Object not found'/'Error 404'. Can you please re-post the build.xml or
email it to me?
> johan
> > because of it.
FUDForum. Page generated in 0.06888 seconds
