Home » Language IDEs » C / C++ IDE (CDT) » Managed C project with several main() functions
Managed C project with several main() functions [message #157087] Mon, 31 October 2005 11:33 Go to next message
Originally posted by: fbarsoba.verizon.net
Hi all,
I'd like to have several files with their correspondent main() functions
under the same project. When I try to do it, I get the error 'multiple
definition of main'. Could anyone tell me what paramtere do I have to
change or how do I have to create the managed project?
thanks,
FBM
Re: Managed C project with several main() functions [message #157129 is a reply to message #157087] Mon, 31 October 2005 14:18 Go to previous messageGo to next message
What does give the error? The CDT or the compiler/linker.
I gues its the linker, which is normal if you compile multiple main's
into one executable!
Try if you can exclude one or the other file from the build process.
Right now, the interface for the following is a little awkward.
Create in the Project Settings multiple Build Configurations for each of
the files with main(), e.g. Debug1, Debug2,..., Release1, Release2,...
You can copy the settings for the new configurations from a given one,
e.g. Debug.
Select a build configuration, then exclude the file containing main()'s
you don't want to use by clicking on the specific file and say
Properties. There go to C/C++ Build settings tab, select the build
configuration and mark the checkbox "Exclude from Build".
This is all for "Managed Make"-Projects, in standard make projects,
adapt your Makefile accordingly.
Fernando Barsoba schrieb:
> Hi all,
> thanks,
> FBM
Re: Managed C project with several main() functions [message #157137 is a reply to message #157129] Mon, 31 October 2005 14:29 Go to previous message
> e.g. Debug.
Thanks a lot. I've done it as you said.. and it works nicely..
FBM
Previous Topic:The CDT can not work!
Next Topic:why before launching external tools, eclipse will make the project again
Current Time: Sat Jul 26 17:57:26 EDT 2025
Powered by FUDForum. Page generated in 0.03349 seconds
