Home » Eclipse Projects » GEF » Displaying some text on empty palette.
Displaying some text on empty palette. [message #157017] Fri, 05 November 2004 12:14 Go to next message
Originally posted by: dyx.gmx.net
I have no drawer and only the select tool in the palette, but the user c=
an =
add drawers and palettes via the customize dialog. So initially the =
palette is almost empty and i want to display some text on it like: =
"Right-click here and select customize to add palette items."
Similar to what the palette view does when no gef editor is active: =
there`s a display of "A palette i not available".
So where do i have to look to to implement this?
Re: Displaying some text on empty palette. [message #157033 is a reply to message #157017] Fri, 05 November 2004 13:39 Go to previous message
The only way I can think of is to add a bogus entry on the palette (perhaps
a template entry in a separate group, and making its editpart not
selectable). Perhaps you should try some other approach. Tooltips, maybe?
Another option would be to add an empty drawer named "User-Customized Parts"
or something like that. And then, as tooltip, you mention that the user can
add new parts to that drawer.
"Frank Dyck" <dyx@gmx.net> wrote in message news:opsgz4u8yl0i05et@celeron...
I have no drawer and only the select tool in the palette, but the user can
Previous Topic:Adding Label to PolylineDecoration
Next Topic:Directed Cyclic Graph/Tree and Draw2d
Current Time: Tue Jul 22 12:56:17 EDT 2025
Powered by FUDForum. Page generated in 0.06110 seconds
